Motorola P2k A-Series: A630,A668,A728,A732,A768i,A780,A835,A840,A920,A925,A1000,A1200 C-Series: C250,C26x,C33x,C35x,C370,C380,C450,C550,C650,C390,C975,C980 E-Series: E1,E398,E390,E375,E370,E378i,E380,E680,E770,E1000,E680i,E1070 P-Series: P280 T-Series: T280,T720,T721i,T722i V-Series: V60,V66,V7x,V80,V150,V180,V186,V188,V220,V226,V235, V30x,V360,V400,V500,V525,V535,V547,V555,V557,V635,V600,V620,V872, V3,V3x, V3i,V980,V975,V1050. other-Series: like L6,L7,U6. |
10-31-2007, 00:47 | #1 (permalink) |
Junior Member Join Date: Jul 2006 Location: Macedonia Age: 41
Member: 304994 Status: Offline Thanks Meter: 1 | Help motorola v235 unlock problem on the phone display when I try to unlock him and. I find new flash "R3512_G_0A[1].30.6CR_PDS00D_LP095B_DRM0201_JPJAVA_G_0A_V235_06_ 04_03R_GSIV235TMXTRADE09E_1FF_MotoFon.RU.shx". But the CG1 - firmware doesn't work to.the same critical error 84. What to do ? I tried whit the "Flash&Backup" to but the same thing. Help me please I'm in big hury. |
10-31-2007, 01:01 | #2 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Dublin
Member: 620439 Status: Offline Thanks Meter: 86 | unlock with smart clip Please, be aware of the new unlock procedure: 1. Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC). 2. Connect S-Card to PC USB port. 3. Connect power supply to Smart-Clip and power on the handset. 4. Launch SmartMoto. 5. Choose "Smart-Clip USB port" in phone connection window. 6. Press "Search". The software should perform the following steps: * SmartMoto detects S-Card; * SmartMoto detects Smart-Clip; * SmartMoto detects the handset and reads all phone information. 7. Log to bookmark "Prepare". 8. Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list. 9. For unlock purposes, please make sure that "Unlock automatically" option is marked. 10. Press "Prepare" button. 11. The prepare cycle starts. SmartMoto creates a Temporary Backup File* from the handset firmware. For some models, SmartMoto will popup the following instruction to be performed: * Remove phone’s battery; * Insert battery back; * Press power ON; * Press ok in SmartMoto; * The prepare cycle will continue. 12. At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein * Disconnect cable from the phone; * Remove phone’s battery; * Connect cable to the phone; * Insert phone's battery; * Press "Power on" key on the phone. Phone's LCD remains blank; * Press OK in SmartMoto. 13. The handset should be detected by SmartMoto as "S Blank..." with boot 2.00 (3.00). 14. SmartMoto restores the temporary backup file 15. If the option "Unlock automatically" was marked – the handset becomes unlocked. If the option was not selected then the handset can be served for Flash, Repair PDS, Unlock or Backup purposes. * Temporary Backup File is created by SmartMoto in work purposes and will be automatically erased from the Hard Drive as soon as unlock process is completed. If the handset was connected to SmartMoto, in boot mode the temporary backup file will not be created. In this case, after Prepare process is completed, the handset must be flashed with flash file and user data will be erased from the memory NOTE: If there was any mistakes made during unlock process, and the handset is in "MEM_MAP Blank" mode, then "Prepare" process has to be repeated and the handset has to be flashed with reflash or full_flash file. At the stage 11, handset screen might display a "Critical error" (Erasing flash memory error 80) message. Please, don’t be worried and strictly follow the instructions of SmartMoto. regards guide |
Please Help! Motorola V66 unlock problems | topicebox | Motorola P2k | 27 | 01-31-2008 18:35 |
motorola v235 unlock | jkakai | Phone Unlocking Codes & Maps | 2 | 11-16-2007 15:49 |
Motorola V235 Unlocking Error | bbmad | Smart-Clip | 9 | 05-04-2007 14:20 |
Motorola V235 unlocking | barrieb | Motorola P2k | 2 | 12-30-2006 20:49 |
Help Motorola v235... | steffannel | Motorola Hardware Repair | 0 | 05-28-2006 17:49 |
