Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
05-14-2007, 15:04 | #184 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 41
Member: 108687 Status: Offline Thanks Meter: 104 | Symbian Tips & Tricks Symbian Tips & Tricks Tip 1 : Do u know how to use the edit button (abc or pencil button)? Heres how... in the inbox for example; u wanna delete multiple sms, simply hold the edit button, scroll down, and then, press c to delete the marked sms. The edit button can also b used to copy and past text in sms, simply hold it and scroll across, choose copy. pretty good for placing song names in ngages Tip 2 : ….happens, on a smartphone, its inevitable u do something wrong, and tis calls for a format of fone. to format the fone, press *#7370#, then enter the lock code, which is the sec code of the fone. NOTE: batt must b full, else if format is disrupted by low batt, consequences will b disatrous I heard the code *#7780# works too, pretty much the same i tink. for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345. Tip 3 : TO NGAGE USERS; Did u know u can install .sis files simply using the cable given? Juz plug it in, place the .sis file anywhere on e: (the mmc), not in any folders, root of e:, disconnect, then look for it in manager. Tip 4: Save on battery and system memory being used by regulary checking the task manager which can be accessed by holding down the menu button!! Tip 5: Type *#06# to display your IMEI serial number, very valuable for the unlocking your phone to other sim cards Tip 6: Type *#0000# to view which firmware version you are running Tip 4a: Set the screen saver to a short time out period to prolong battery life. Tip 4b: Avoid restarting the phone, or repeatedly turning it on and off. This helps increase battery life. Tip 7: If you would like to avoid being "blue jacked", keep bluetooth turned off, or set your phone's visibility to hidden. Tip 8: Don't want to carry a watch and a phone? Set the screen saver to show date and time, then you can ditch the watch. Tip 9: Save memory when installing apps, by installing over bluetooth. This can be done using the nokia phone suite and a bluetooth serial connection. Only works with .SIS files, so java still has to be sent to the phone, but will save space when using .SIS files. Tip 10: Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels continuation.......... |
05-14-2007, 15:07 | #185 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Symbian Tips & Tricks continuation Tip 11: Check if the recepients phone is on Delivery reports or Type *0# your message in the message composer window space then write your message, the recipient will not see the star zero hash bit - just the message When they read it it will relay a message back to your fone showing the time they recieved it. (haven't yet tried it myself though). Tip 12: BlueJacking First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone. Tip 13: While you are viewing a picture in your phone's gallery, press one of these shortcut keys (definitely works on 6600, not sure about other symbians) 1 - turn image anticlockwise 3 - turn image clockwise * - toggle on/off of full screen 5 - zoom in 0 - zoom out #15 u can select all files in a folder by selecting THE folder and copy it then paste it somewhere. however u need to make a new directory. fexplorer wun let u copy that folder together. well seleQ can mark files to copy but it really takes time! #16: A soft and Hard reset A Soft-reset - the process of resetting all the settings of the phone to the factory default! No applications are deleted! A Hard-reset is like formatting a drive! It does format the memory. Everything that has been installed after the first use of the phone is deleted! It will recover the memory of the phone to the state you purchased it! It is done by inputing the following code: *#7370# NOTE: The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable. #17: Formats of images supported ones: JPG UPF GIF87a/89a WBMB MBM TIFF/F PNG EXIF How to copy & paste text in your Nokia 3650: Press and hold the pencil key and select your text using the scroll key. Left function key will change to 'Copy'. Press it to copy the selected text to clipboard. You can paste the clipboard contents the same way: press and hold the pencil key and press 'Paste'. Or, press pencil key once and select 'Paste'. Press and hold the Menu key to open the application switching window, where you can *duh* switch between applications. If a program hangs and you can't shut it down, select the application in the application switching window and press 'C' to kill it. It's also a faster way to exit programs. Turn on/off the "click" sound made by the camera by selecting the 'Silent' profile or by turning warning tones on/off: Menu > Profiles > "select your activated profile" > Personalise > Warning tones > On/Off. (This also effects the sound of Java games and apps). To change background image go to: Menu > Tools > Settings > Phone > Standby mode > Background image > Yes > "choose an image". The best size for background images is 174x132 pixels. Only got blue, green and purple in your 3650 colour palette? This free app adds 3 more colours: Palette Extender. Display an image when someone's calling: Menu > Contacts > "select a contact card" > Options > Edit > Options > Add thumbnail > "choose an image". Add a personal ringing tone to a contact: Menu > Contacts > "select a contact card" > Options > Open > Options > Ringing tone > "choose a ringing tone". Delete all messages from your Inbox at once: Menu > Messaging > Inbox > Options > Mark/Unmark > Mark all > Options > Delete. Send or hide your caller ID: Go to: Menu > Tools > Settings > Call > Send My Caller ID > 'Yes', 'No' or 'Set By Network' to follow the default settings of your home network. |
05-14-2007, 15:08 | #186 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Symbian Tips & Tricks Symbian Tips & Tricks part 3 If you often copy large files to your MultiMedia Card, I recommend a card reader. E.g. With a card reader it takes only 12 seconds to copy a 10 MB file! Record the sound of a phone call using the (sound) Recorder. Menu > Extra's > Recorder > Options > Record sound clip. Note: short beeps are audible during call registration. But there is a 60 second limitation so if you want unlimited sound recording get this app: Extended Recorder. While writing text, press "#" to switch between upper and lower case and Dictonary on/off (predictive text input). Press and hold "#" to switch between Alpha mode and Number mode. Keyboard shortcuts for zooming and rotating images in Images: 1 = zoom in, 0 = zoom out, press and hold to return to the normal view. 2 = rotate anticlockwise, 9 = rotate clockwise, * = full screen. In standby mode, press and hold the right soft key to activate voice dialling. To add a voice tag to a phone number, open a contact card and scroll to the phone number and select: Options > Add voice tag. You can customize both soft keys located below the screen (in standby mode): Menu > Tools > Settings > Phone > Standby mode > Left/Right selection key > "select an application". In standby mode. press scroll key center (joystick) to go directly to Contacts. In standby mode, press and hold 0 to launch your wap home page. In Menu or any subfolder, press numbers 1 - 9 to start the application at that location. 123 456 789 In standby mode, 45# + dials the number on your sim in memory slot 45. 50# + dials slot 50 and so on. If you have your keylock activated just press the on/off button to turn on your backlight to look at the time when it's dark without having to unlock the keypad. Never, ever, in your whole life, install WildSkinz on your Nokia 3650!!! WildSkinz screws up the whole 3650 system. It was never intended to work on the 3650, only on the 7650. Why assigning Video Recorder in the right or left soft key does not work? (Sound Recorder is launched instead of Video Recorder) It's a bug with firmware version 2.50. How to check your firmware version: A "Firmware" is the phone's operating system stored in internal Flash memory of the device (disk Z. Manufacturers release new firmware versions containing bug fixes, improvements and - sometimes - offering new functions. Firmware upgrade can only be made in authorized Nokia service centre (point). To check your current firmware version simply type *#0000# on main Phone screen. · How to check your IMEI (International Mobile Equipment Identity)? Type *#06# on main Phone screen. Start up in Safe Mode so no 'auto start' apps will be running: To make sure that no memory-resident programs start when you reboot your phone, hold down the pencil key when you turn on the phone and hold it on untill you have to enter your PIN code. (When you have trouble booting up the phone with the MMC in it because it got corrupted for some reason, this trick will almost always let you boot up the phone so you can remove the latest installed app which might have caused the problem or if your phone is "unrepairable" you can still back up your important data before you do a format.) Q: How to totally format your Nokia 3650 and remove all installed applications, user files and restore all settings to default like it's new out of the box? (OEM apps won't be deleted like Camera and RealOne Player). A: First Format your MMC: Menu > Extras > Memory > Options > Format mem. card > Yes. Note: It is very important to format your MMC before you format your phone! Then format your phone by typing *#7370# on main Phone screen. Phone will ask: "Restore all original phone settings? Phone will restart." Press 'Yes' and enter your Lock code (default is 12345). Tip: Formatting takes several minutes so you'd better connect your Nokia 3650 to a charger to ensure that your battery doesn't get empty in the middle of formatting. Note: All your created acces points and mailboxes will be lost so take a note of them. And all application settings will be reset. E.g. In Camera, image quality is set back to normal and memory in use is set back to phone memory. And also in Messages, memory in use is set back to phone memory, etc. Also backup your contacts with PC Suite or a program like Contacts Manager. To reset your wallet, should you forget your code, Type in: *#7370925538# this will reset the wallet code, the wallet contents will be deleted. How to free more RAM on your phone >>> >>> Method 1: Flight mode: Put your phone in "Flight mode" with Psiloc System Tools. Install System Tools, open it and select "Flight mode". This way you can restart the phone without your SIM card so there will be no running phone tasks in the background. Now you can have up to 3,5 MB of free RAM! Note: ironically enough, Flight mode doesn't work when Smart Launcher is installed, at least in my case. But i've also heard several reports of people who have both apps running without any problems. >>> Method 2: Smart Launcher trick: Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON. Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold). The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM). The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so you trick the phone and you have more free RAM! Note: when you unplug the charger, the phone will switch off. >>> Method 3: Menu : This method I found it by myself, it frees a little about 100~200 KB but I guess it's useful sometime Close your menu not by selecting the right selection key "exit", or pressing the menu key another time, they only hide the menu app but do not close it, to close it select the left selection key "option" and scroll down and select "exit" So when you open an app needs more ram reopen menu and close it, it's useful when play low bit rate video in realplayer paradise. |
05-14-2007, 15:11 | #187 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Symbian Tips & Tricks The Nokia phone Lock Reset Q. What is a Phone Lock? Answer: From Nokia's webpage: "The Phone Lock prevents your phone data from being accessed if Your phone is stolen. "The lock code is a number that prevents unauthorized persons from Using your phone. These control codes are for your protection." What is THE-NOKIA-UNLOCK: The program exploits a design flaw in the nokia mobile phones to remove The Phone Lock protection. The program was tested on Nokia 6630 and Nokia 6680. The program Should work on any other Symbian based mobile phones (including Sony Ericson and all modern nokia phones and many others). This tool does not remove the sim-lock. How to use: You need two mobile phones. 1) Do _not_ turn off the mobile phone! 2) Remove the Memory Card (MMC) from the locked phone and put it into a second mobile. Install FExplorer on the second mobile phone. Create the directory E:\System\Recogs and copy the-nokia-unlock.mdl into this directory. 3) Remove the Memory Card and place it into the locked phone. The THE-NOKIA-UNLOCK program should start after 120 seconds. 4) Remove the battery. Remove the MMC. Put the battery back and restart. The Phone Lock has been reset to "12345". Why does this work? The Phone Lock disables the key pad, Bluetooth and the USB port. This makes it impossible to access the data stored on the device without knowing the correct code. Nevertheless the MMC is not disabled. Nokia's OS has a lot of undocumented features. One of them are 'recognizer' that can be used to execute a program when the phone boots. A recognizer is loaded and executed when a drive is mounted. The MMC is mounted when it is placed into the mobile phone _even_ when the phone is locked. THE-NOKIA-UNLOCK is a recognizer that implementes yet another undocumented feature to perform a hard reset (by software) on the phone. Note: The same recognizer-autostart method can be used to quickly install a backdoor on a locked mobile phone or to propagate a virus: Get in, Get |
05-14-2007, 15:15 | #188 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Speed up your symbian OS 9.1 Speed up your symbian OS 9.1 We know that n73 with lastest firmware is a little bit slow.let's try it to make our smartpfone faster than before... SPEED UP YOUR PHONE UP TO 40%!!!!!Yes!! That truth guys!!!!! Its work on my 3230 and also 6600, n-gage and etc……… Just follow this trick……. First go to ur To-do List. Make a note and input as follows Subject: Speed Due Date: 29-01-2005(dd-mm-yy) Priority: set to High then press Done Go to option again and make a second note and input as follows Subject: Qoukie Due Date: 29-01-2005(dd-mm-yy) Priority: set to Low then press Done Do not exit yet. Highlight the Speed note, select Options and Mark as done. Then highlight the Qoukie note, select Options and Mark as done. Now, reboot your mobile. -Anyway in the menu of n73ME or n80 there wasn't an icon named to do list.Try to find To-do-List in Calendar\Agenda & proced with the same procedure i try it and now my phone run more faster. |
05-14-2007, 15:16 | #189 (permalink) |
Member: 108687 Status: Offline Thanks Meter: 104 | Important Information for People updating firmware! (For N73/other models) Important Information for People updating firmware! (For N73/other models) Important Information for People updating firmware! (For N73/other models) Hi guys, Just a piece of information which i would like to share from my personal experience... Before updating the firmware, please (atleast for my sake) (a) Turn off the firewall coz it might cause unnecessary problems.. (b) take a complete backup of the phone memory using the PC suite or else you might end up making the mistake i did i.e., losing out on the contacts/notes/msgs.... (c) put on the charger before u decide to update and let it be on... (d) Insert a dummy simcard which has expired in your phone and set the profile to general. (e) do not make/recieve calls or use the phone (it is better to have a backup fone which u can use for making/receiving calls while updating) because the firmware size is + or - 73.5mb for N73 internet edition/music edition, dunno bout other models... and it takes a long time for the firmware to download and update... took me nearly 3 hours for everything to be done on a 256kbps internet connection (f) enjoy your new phone or shud i say new firmware on an old fone hehe P.S. I know that most of these information is given while updating the firmware but in the excitement u tend to forget n zoom wid the updating process... __________________ |
05-14-2007, 22:23 | #194 (permalink) |
No Life Poster Join Date: May 2005 Location: Saudi Arabia - Jeddah
Member: 145783 Status: Offline Thanks Meter: 36 | Thanks a lot my dear Peterpete 82. Really you did a great job. Really its a very informative especially for those who knows littbit but not too much while your information made us an Engineer !!!!. Once again Thanks. NSHKW |
05-15-2007, 01:05 | #195 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Spain Age: 47
Member: 85082 Status: Offline Thanks Meter: 2 | Does anyone know if this apps run on the nokia E65? I'm conected now with it.. but it's new and don't tried symbian 9.1 or 3rd generation apps yet. Thanks |
applications for Nokia N73 and other 3rd generation phones | alex_center | Nokia Multimedia | 12 | 04-26-2010 07:17 |
Encrypt Calls Program For Symbian 9.1 3rd Edition Phones? | lynx77 | Nokia Multimedia | 4 | 12-05-2009 02:58 |
Most hot&Tot wallpaper for Nokia Mobiles s60 & 3rd edition | goyalamit123 | Nokia Multimedia | 0 | 08-10-2006 20:53 |
