Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
07-10-2008, 06:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Symbian Hack:broke Symbian restrictions Hack Symbian with HelloCarbide and ROMPatcher Of all the methods to toggle the broken Symbian restrictions on your phone on and off, ROMPatcher is the most versatile: it allows you to apply all sorts of customisations by dropping a simple file into the right folder, instead of having to edit system files by hand. Unfortunately, Nokia's latest firmware updates prevented the installation of AppTRK on your phone, and this used to be necessary to transfer ROMPatcher from your computer to your phone. But not anymore. A day or two ago our arsenal of Symbian hacking tools was extended by the HelloCarbide hack, which lets you open up Symbian just by running a .sisx file on your phone. No phone-to-computer connection through AppTRK required anymore. We already had a simple method to install unsigned .sis packages, and now ROMPatcher itself is available as a .sisx file which works on just about any Symbian S60 v3 phone that has been set free with HelloCarbide. Instructions (short version): 1) Extract the zip, copy the three files from the zip to your phone's memory card 2) Open a file browser like X-Plore and KEEP IT RUNNING 3) Run Run HelloCarbide, go to options, then choose menu1. HelloCarbide will crash after it's done its job. Don't worry about that. 4) Switch to X-Plore and copy installserver.exe into the c:\sys\bin\ folder of your phone. 5) Restart your phone. 6) Install ROMPatcher.sisx and enjoy all the freedom that ROMPatcher gives you. --------------------------------------------------------------- Instructions (long version): symbianism.site666.info --------------------------------------------------------------- - New version of ROMPatcher that supports more phones - New version of ROMPatcher with autostart option br,Amir34 |
The Following 7 Users Say Thank You to Amir-SkillZ For This Useful Post: |
09-01-2008, 14:22 | #2 (permalink) |
Major Poster Join Date: Sep 2006
Member: 345763 Status: Offline Thanks Meter: 5 | @Amir-SkillZ M using N80,after runnin HelloCarbide it gives 2 option yes n No , i press yes option many times the fone restarts after that i open X-Plore to copy installserver.exe into the c:\sys\bin\ folder but i can only see this path c:\sys. no subfolders inside i also try to creat bin named folder inside c:\sys\ but can't . yes there's folder named c:\system but no bin folder there. What should i do ? |
09-04-2008, 00:26 | #5 (permalink) |
Junior Member Join Date: Aug 2008
Member: 829126 Status: Offline Thanks Meter: 9 | Ok... Here's a scenario. I bought a brand new Nokia phone running Symbian OS. Before I mess up with it, I want to take a snapshot (complete clone image) of the the original OS and contents. How would I do that? |
09-13-2008, 07:57 | #10 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
6300 phone restricted (enter restriction code ) | seeta | Nokia Base Band 5 ( BB-5 ) | 32 | 08-25-2011 12:19 |
Phone restricted=>Restriction code: | didos | Nokia Digital Core Technology 4 ( DCT-4 ) | 13 | 12-05-2006 13:02 |
phone restriction off, after inserted sim, restriction on again | samguan | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-16-2006 00:10 |
About my Symbian Download Section: symbian.gsm.com.vn | DraculaNowAday | Nokia Multimedia | 26 | 10-20-2004 16:47 |
