Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
01-31-2009, 13:26 | #2 (permalink) |
Insane Poster Join Date: Apr 2005 Location: New Zealand
Member: 139977 Status: Offline Thanks Meter: 20 | Hard Reset (or Full Reset) Performing a hard reset, all settings, records and programs stored in the Pda (except the ones stored in Rom) will be erased. After a Hard Reset formats, preferences, and other settings will be restored to the factory default settings. You can restore any previous data if you got a Backup of your device before the hard reset otherwise you will need to reinstall any third-party applications. If you are hard resetting your device owing to some hard problem i suggest to restores installed applications without using the backup if you are not sure that backup data do not include the problem you wish to solve also. In few words a hard reset allows you to start everything over from scratch. Soft Reset A soft reset tells to your device to stop what it is doing and to restart. All records and programs stored in device will be retained after a soft reset. After resetting, the usual start screen will appear. Use a soft reset when your device seems to have crashed or hanged. This type of reset is the first to try, before any others, to solve the above problems. This kind of reset is, usually, well known by the user and really easy to perform. |
ALL Hard reset - Soft reset PDA SmartPhone | ahsan bhi | HTC & Smartphones ( WM Without Touch) | 42 | 12-08-2016 00:33 |
[New] Samsung i607 i608 i617 Hard Reset & Soft Reset ...Complete Procedure !!! | TsambakolTeam | QUALCOMM Models (3G) | 12 | 04-08-2015 10:44 |
A to z smart phones hard reset- soft reset updated | ..:::YMG:::.. | HTC & Smartphones ( WM Without Touch) | 1 | 03-05-2013 04:18 |
All Pda Smartphone Pna Soft And Hard Reset, To Remove Phone Lock Code | aikonmani | GSM Mobile Links | 1 | 07-06-2008 22:50 |
Atom can't boot up after a soft reset/hard reset | D4yw4lk3r | HTC & PDA WM( With Touchscreen) | 3 | 05-28-2006 08:16 |
