HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
The Following 29 Users Say Thank You to ahsan bhi For This Useful Post: |
04-14-2009, 09:48 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | S710 Hard reset Procedure: 1. Take out the battery. 2. put back the battery. 3. Hold in both keys next to the navigation button on the front keypad. 4. While holding in both buttons press the power button. make sure you only release the power button and keep holding in the other to buttons while the phone starts up. 4.once the phone indicates that it is resetting with a black screen with white text you can release the buttons. 5. Please keep in mind that if you do this all data will be lost. Make sure you save all your data before using this option. And all files on your storage card will be locked if they are marked for encryption on WM6. So this should only be your last option to hard restart the phone. |
04-20-2009, 17:39 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | IPAQ had reset: 1) Power the IPAQ off by holding down the END key 2) Then hold down the center of the 4-way navigation key and power on the IPAQ again while continuing to do so. 3) You will see a screen that asks you if you want to perform a hard reset. Selete YES. The IPAQ will reboot with original factory settings. |
04-20-2009, 17:44 | #7 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 46
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 874 | Quote:
A to z smart phones hard reset- soft reset updated | ..:::YMG:::.. | HTC & Smartphones ( WM Without Touch) | 1 | 03-05-2013 04:18 |
hard-soft reset all model | shashankmobile | HTC & PDA WM( With Touchscreen) | 28 | 07-12-2012 03:23 |
hard and soft reset htc diamonds | delchoni | HTC & PDA WM( With Touchscreen) | 0 | 12-09-2009 16:46 |
All Pda Smartphone Pna Soft And Hard Reset, To Remove Phone Lock Code | aikonmani | GSM Mobile Links | 1 | 07-06-2008 22:50 |
