Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Windows/Java/Symbian games and applications. |
04-02-2006, 15:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Saudi Arabia - Jeddah
Member: 145783 Status: Offline Thanks Meter: 36 | System Error - Nokia N70 Suddenly, I don't know what happened with my Nokia N70 phone, it is giving System Error -1, Might be I deleted some file. Could you please some body guide me what to do? Thanks BR NSHKW |
04-02-2006, 18:15 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Singapore Age: 36
Member: 235509 Status: Offline Thanks Meter: 6 | Quote:
04-03-2006, 10:48 | #5 (permalink) | |
Member: 145783 Status: Offline Thanks Meter: 36 | Quote:
BR NSHKW | |
04-03-2006, 19:22 | #6 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 161789 Status: Offline Thanks Meter: 6 | soft format is the easy way by the way can u type alphebets or does ur fon allows only numbers to type. i think if u hav this problm then i hav a software to cure it tell me about it |
04-03-2006, 19:34 | #7 (permalink) |
Junior Member Join Date: Mar 2006
Member: 241432 Status: Offline Thanks Meter: 0 | i also using n70 only. It also shows system error, if i install any software which doesn't support. I had a problem when i install taskman and some tracking software. After i delete that files and contains some files in sys folder. Now i am not having it |
04-04-2006, 08:03 | #9 (permalink) | |
Yes, I can type alphabets and alos numbers, there is no problem at all. The system error -1 is coming only when I try to send MMS, now I cannot make MMS setting according to the country setting. I run setting wizard but the same message coming system error-1. The other all softwares are working well. Also, my Fase Store software were infected due to this error, then I removed from the mobile. I am avoiding to format the mobile and trying to get the solution without format. BR NSHKW | |
04-07-2006, 18:56 | #11 (permalink) |
Member: 161789 Status: Offline Thanks Meter: 6 | mate it would be tuff job to find where is that error remove the mem card and switch on if still shows system error soft format ur fon ur contacts and all wil remain inur fon only some applications will be affected not all reinstall those apps if the problm is wit mem card then format the card this is the only easy way dont hard format ur fon not necessary |
N70 System Error and Freeze | simple79 | Nokia Base Band 5 ( BB-5 ) | 8 | 08-29-2013 15:30 |
A2 Initializating file system error !! Cant customize !! Help plz | Dany | Universalbox | 2 | 03-29-2010 12:35 |
N70 System Error and Freeze | simple79 | Nokia Multimedia | 7 | 12-14-2006 17:20 |
n70 system error problem | johntan | Nokia Base Band 5 ( BB-5 ) | 0 | 08-12-2006 06:37 |
