VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
02-01-2002, 21:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | Samsung R210S- it seems code calculator don't work Can anybody give me a hand of help here??? thanks,<br />greetings,<br />gobi<br />[email protected]<br />[email protected]<br /> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> |
02-02-2002, 00:15 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | IF YOU WHANT SEND ME THE EEPROM <img src="smile.gif" border="0"> BIN AND I GIVE YOU THE EEPROM UNLOCKED OR MAYBE READ BY CABLE WHIT RONG VOLTAGE I USE ALWAYS 2.5V IS THE BETTER WAY TO USE THE CABLE <img src="smile.gif" border="0"> |
02-02-2002, 12:06 | #4 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | hi, The bin file is 100% correct, since i have checked it by removing the eeprom from the phone and reading it by 100% workink Ponyprog.<br />So the calculated code must be incorrect. ...regards, <br />gobi |
02-02-2002, 15:11 | #5 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: Portugal
Member: 7425 Status: Offline Thanks Meter: 0 | Hi to all. You must use 3V (use two 1,5V cells) to read the phone's EEPROM. I have unlocked sucessfuly many R210s phones with SCR 3.5a by Pajo. First you have to do a custom EEPROM reset, then try to use the code, with #0111*, #0151*... |
02-02-2002, 16:14 | #6 (permalink) |
Member: 6328 Status: Offline Thanks Meter: 3,595 | HI,<br />i could read the EEPROM by cable (tested by removing afterwards the chip from phone and reading with tested ponyprog--->1000% CORRECT (i've readed thousends of eeproms last 4 years) HOWEVER,<br />- the calculated code (by Pajo sw SCR35, SCR36) seems to be ioncorrect sice i get all the time the ILLEGAL OPERATION message when i enter #0111*.....<br />Using all other combinations #0149, #0151, *0111, *... it gives me the message NOT YET PERSONALIZED, and<br />-E2P CUSTOM RESET, BEFORE OR AFTER, by entering that code didn't help either... Any idea about this?? <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> greetings,<br />gobi |
02-03-2002, 12:22 | #9 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | hi guys, can anybody tell me how to make a cable to read the eprom of r2xx & a200 , where can i download the scheme n pinouts ??? OR any send me this ???? thanx pete <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> |
02-08-2002, 16:09 | #12 (permalink) |
Member: 7425 Status: Offline Thanks Meter: 0 | How to read a R210's EEPROM correctly: 1- EEPROM MUST be read without the battery on the phone. 2- You MUST make a custom EPROM reset before reading the EEPROM. If you don't do this, codes will not calculated correctly. 3- You MUST enter the codes in the phone WITHOUT the SIM card (but of course the phone must be On). SCR 3.6 will calculate the codes correctly. But no software is bug free, you may send EEPROM's dump to Pajo. |
02-09-2002, 16:05 | #14 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Melilla, Espaņa
Member: 3389 Status: Offline Sonork: 100.1579083 Thanks Meter: 72 | To Extract the right codige in the r-200-210 <br />Only use this solution when it tha the Pajo soft give us and the soft in incorrect to pu the code in it.<br />Read the eprom<br />Look for three frecuencys to 4 bytes. These frecuencys have been stayed to eprom's start<br />Ej: <br />00B6 0039 0070 0009<br />00B6 0039 0070 0009<br />00B6 0039 0070 0009<br /> -- -- -- --<br />Put it to this form:<br />09 70 39 B6<br />Open calculator's windows and select the cientific calculator and introduce: 097039B6<br />Now select DECIMAL in the calculator.<br />This result, I etract the first number:RESULT PAST TO DECIMAL: 158349750<br />Now introduce the net code in the phone<br />#0111*58349750#<br />The phone put in it that the personalitation canceled an the phone will be free.<br />Best Regards<br /> <img src="eek.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="wink.gif" border="0"> |
02-12-2002, 11:10 | #15 (permalink) |
Freak Poster Join Date: May 2001 Location: Wien,Austria
Member: 4544 Status: Offline Thanks Meter: 4 | To ALLBARACIN :<br />Hallo,<br />I m writing you about my bin file and I m send you for 3 days.Whats about,have you my mail or you have no time to answer.<br />Please contact me it s important<br />Thx |
Do it yourself Code Calculators for Ford Blaupunkt Becker Clarion and more | gsm9l | CAR Electronics | 20 | 08-29-2008 23:45 |
read code but don't work | JAVA Good | Redbox | 1 | 10-14-2005 18:04 |
Samsung r210 don't make a call after unlock!!!! | micmac | Samsung Hardware Repair | 15 | 05-24-2002 08:24 |
Samsung r210 don't make a call after unlock!!!! | micmac | VLSI, Conexant, Skyworks and Old Models | 4 | 05-21-2002 05:58 |
