Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > VLSI, Conexant, Skyworks and Old Models
VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800.
VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508.
Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208.
Skyworks: A500, C100, C108, C110, P510, P518.
Old 02-01-2002, 21:40   #1 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Post Samsung R210S- it seems code calculator don't work
hi, about SAMSUNG R210S<br /> i could read the EEPROM by cable (tested by removing afterwards the chip from phone and reading with tested ponyprog, but the calculated code (by Pajo sw) seems to be ioncorrect sice i get all the time the ILLEGAL OPERATION message when i enter #0111*.....<br />Using all other combinations #0149, #0151, *0111, *... it gives me the message NOT YET PERSONALIZED, and E2P CUSTOM RESET by entering that code didn't help either...
Can anybody give me a hand of help here???
thanks,<br />greetings,<br />gobi<br />[email protected]<br />[email protected]<br /> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0">
Old 02-02-2002, 00:15   #2 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Post
IF YOU WHANT SEND ME THE EEPROM <img src="smile.gif" border="0"> BIN AND I GIVE YOU THE EEPROM UNLOCKED OR MAYBE READ BY CABLE WHIT RONG VOLTAGE I USE ALWAYS 2.5V IS THE BETTER WAY TO USE THE CABLE <img src="smile.gif" border="0">
Old 02-02-2002, 04:58   #3 (permalink)
Member: 7501
Post
1,5V is not enough?
my I2C work's good with 1,5V !!!
Old 02-02-2002, 12:06   #4 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Post
hi,
The bin file is 100% correct, since i have checked it by removing the eeprom from the phone and reading it by 100% workink Ponyprog.<br />So the calculated code must be incorrect.
...regards, <br />gobi
Old 02-02-2002, 15:11   #5 (permalink)
Crazy Poster
Member: 7425
Post
Hi to all.
You must use 3V (use two 1,5V cells) to read the phone's EEPROM. I have unlocked sucessfuly many R210s phones with SCR 3.5a by Pajo. First you have to do a custom EEPROM reset, then try to use the code, with #0111*, #0151*...
Old 02-02-2002, 16:14   #6 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
HI,<br />i could read the EEPROM by cable (tested by removing afterwards the chip from phone and reading with tested ponyprog---&gt;1000% CORRECT (i've readed thousends of eeproms last 4 years)
HOWEVER,<br />- the calculated code (by Pajo sw SCR35, SCR36) seems to be ioncorrect sice i get all the time the ILLEGAL OPERATION message when i enter #0111*.....<br />Using all other combinations #0149, #0151, *0111, *... it gives me the message NOT YET PERSONALIZED, and<br />-E2P CUSTOM RESET, BEFORE OR AFTER, by entering that code didn't help either...
Any idea about this?? <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0">
Old 02-02-2002, 20:20   #7 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Post
so send bin to pajo <img src="smile.gif" border="0"> <br />it will help you<br /> <img src="smile.gif" border="0">
Old 02-03-2002, 12:05   #8 (permalink)
Gobi's Avatar
Member: 6328
Thanks Meter: 3,595
Red face
i have send bin to Pajo since friday; now i am waiting for an answer...
regards,<br />gobi <img src="eek.gif" border="0">
Old 02-03-2002, 12:22   #9 (permalink)
Member: 3383
Thanks Meter: 3
Unhappy
hi guys,
can anybody tell me how to make a cable to read the eprom of r2xx & a200 ,
where can i download the scheme n pinouts ???
OR
any send me this ????
thanx
pete <img src="redface.gif" border="0"> <img src="redface.gif" border="0"> <img src="redface.gif" border="0">
Old 02-03-2002, 15:46   #10 (permalink)
Member: 3528
Thanks Meter: 5
Hi.<br /><a href="http://clientes.netvisao.pt/jorgef04/fotos/r-2xx.jpg" target="_blank">Scheme for I2C Samsung</a>
Old 02-05-2002, 04:40   #11 (permalink)
Member: 8843
Thanks Meter: 117
Thanx mate
Any more schemes for A300 pinout connector?
Old 02-08-2002, 16:09   #12 (permalink)
Crazy Poster
Member: 7425
Talking
How to read a R210's EEPROM correctly:
1- EEPROM MUST be read without the battery on the phone.
2- You MUST make a custom EPROM reset before reading the EEPROM. If you don't do this, codes will not calculated correctly.
3- You MUST enter the codes in the phone WITHOUT the SIM card (but of course the phone must be On).
SCR 3.6 will calculate the codes correctly. But no software is bug free, you may send EEPROM's dump to Pajo.
Old 02-09-2002, 11:27   #13 (permalink)
Member: 9006
Look this adress <a href="http://www.gsmactua.net/" target="_blank">http://www.gsmactua.net/</a><br />box samsung all unlock and repare .The price is chip
Old 02-09-2002, 16:05   #14 (permalink)
Member: 3389
Sonork: 100.1579083
Thanks Meter: 72
To Extract the right codige
in the r-200-210 <br />Only use this solution when it tha the Pajo soft give us and the soft in incorrect to pu the code in it.<br />Read the eprom<br />Look for three frecuencys to 4 bytes. These frecuencys have been stayed to eprom's start<br />Ej: <br />00B6 0039 0070 0009<br />00B6 0039 0070 0009<br />00B6 0039 0070 0009<br /> -- -- -- --<br />Put it to this form:<br />09 70 39 B6<br />Open calculator's windows and select the cientific calculator and introduce:
097039B6<br />Now select DECIMAL in the calculator.<br />This result, I etract the first number:RESULT PAST TO DECIMAL: 158349750<br />Now introduce the net code in the phone<br />#0111*58349750#<br />The phone put in it that the personalitation canceled an the phone will be free.<br />Best Regards<br /> <img src="eek.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="wink.gif" border="0">
Old 02-12-2002, 11:10   #15 (permalink)
Member: 4544
Thanks Meter: 4
Red face
To ALLBARACIN :<br />Hallo,<br />I m writing you about my bin file and I m send you for 3 days.Whats about,have you my mail or you have no time to answer.<br />Please contact me it s important<br />Thx
[IMG] code is Off
Do it yourself Code Calculators for Ford Blaupunkt Becker Clarion and more gsm9l CAR Electronics 20 08-29-2008 23:45
read code but don't work JAVA Good Redbox 1 10-14-2005 18:04
Samsung r210 don't make a call after unlock!!!! micmac Samsung Hardware Repair 15 05-24-2002 08:24
Samsung r210 don't make a call after unlock!!!! micmac VLSI, Conexant, Skyworks and Old Models 4 05-21-2002 05:58
Page generated in 0.20675 seconds with 10 queries
