Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-14-2014, 03:58 | #8 (permalink) |
Freak Poster Join Date: May 2007 Location: UAE
Member: 513874 Status: Offline Thanks Meter: 178 | Here is screen shoot download firmware from this link http://forum.gsmhosting.com/vbb/f200...-file-1712757/ Download odin 1.85 press home + volume down + power and after screen appear press volume up |
The Following User Says Thank You to greeney For This Useful Post: |
03-14-2014, 05:18 | #10 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Fix Steps: First Method: - Remove your SIM card again from your device. - Try to Hard Reset your device, Then test it again with SIM card inside. Second Method: - Try to Flash your device again, But with another firmware version, Or use another source to get the firmware files from. Third Method: - In case the above two methods don't solve the restart problem, Then you should get a full firmware package (Boot + Modem + PDA + CSC + Pit) and flash the device again. - After flashing test the device again with SIM card inside. | |
03-14-2014, 05:28 | #11 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Firmware Update Steps: - Run Samsung S5360 Galaxy Y Downloader. S5360_Downloader - Download - 4shared - Check This Options: Re-Partition, Auto Reboot, F.Reset Time ( Re-Partition if you have 3 files ). - For PIT file select: totoro_0623.pit - For BOOTLOADER select: DefaultCalDataWithBoot_S5360xxxxx_REV05.tar.md5 - For PDA select: PDA_S5360xxxxx_REV05.tar.md5 - For PHONE select: MODEM_S5360xxxxx_REV05.tar.md5 - For CSC select: GT-S5360-MULTI-CSC-Oxxxxx.tar.md5 - Put the phone into Download Mode: Volume Down + Home + Power Key and connect USB to phone. - After the Program detect the phone Click Start button and wait. - When the Update complete the phone will be restarted. - Do Full reset by this code: *2767*3855#. S5360 Firmwares: Android 2.3.6: Download S5360XXLA4 S5360TSCLB2 TSC zip |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-14-2014, 07:33 | #14 (permalink) | |
Junior Member Join Date: Nov 2012
Member: 1834315 Status: Offline Thanks Meter: 0 | Quote:
how i find the .pit file ? | |
