Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 09-16-2012, 21:24   #16 (permalink)
Member: 1811744
thx for the help , after 5 hours we finaly fixed the samsung GT-S5830i witth your post
Old 09-25-2012, 17:25   #17 (permalink)
Crazy Poster
Member: 1780530
Thanks Meter: 9
with Re-Partition is enabled or disabled !!!!
Old 10-07-2012, 22:51   #18 (permalink)
Member: 1821758
Thank you so much
Originally Posted by gsm_jatt2 View Post
Download file from this LINK
Hotfile.com: One click file hosting: S5830iXXKL1_S5830iXXKK5_OXEKK4.rar
PASS: sampro.pl
open Odin3 1.85
and put all files in correct place.
BOOT_S5830iXXKK5_REV00.tar --> BootLoader
PDA_S5830iXXKL1_REV00.tar --> PDA
MODEM_S5830iXXKK5_REV00.tar --> Phon
GT-S5830i-MULTI-CSC-CSC OXEKK4_RST.tar -->CSC
thats it!! 100% TESTED!!
If I helped you,press the thanks button.
Try this, it worked like a charm. First i've downloaded PDA.tar and flashed it to my Samsung Galaxy Ace gt-s5839i. I've had rooted the phone prior to install Clockword Recovery. My phone went into brick status and after a few other flashes the bootloop appeer. Learning of other treats, ther is for now not a ROM availeble for the s5839i. With PDA.tar i've changed the phone into Samsung Galaxy Ace gt-s5830i. After restart flashed the file accoording to the quote. AND THE PHONE WORKS WELL!!!
So thank you very much GSM JATT2.
btw where can i find the thanks button?
This is what i've done
1. Google and download S5830i_pit will give cooperve_0623.pit
2. Google and download Odin3 v1.85
3. Google and download PDA.tar (cleans up every action and bring the phone back to gt-s5830i) Is fine for me, there are no files for the s5839i at the moment. And files for s5830 (without the i) won't work.
4. Unzip everything to a new directory on your computers harddrive.
5. Run Odin, bring the phone into downloadmode by pressing vol down+power, connect with the original usb cable.
6. put cooperve_o623.pit in Odin --> PIT, checked the markers Re-partition, auto reboot, f. reset.time and checked if the com turns yellow.
7. Press start and wait. After Odin is done and the box above the com.box is GREEN and displays PASS. wait untill your phone reboot.
8. Disconnect the cable and bring your phone again in download mode.
9. Follow instructions from the quote section made by gsm_jatt2
, and goodluck.
For me it works fine.
The Following User Says Thank You to Foodlover For This Useful Post:
Old 10-27-2012, 22:09   #19 (permalink)
Member: 1333784
Sonork: 8888
gsm_jatt2 flash issue
hi.
This is my first post, and first I must thanks to all with their advices and instructions.
I have Samsung Galaxy ACE s5830i and I had problems with availability in my netvork (which is in Slovenia-EU) because and sometimes during the call the conection was lost,...
So I decided to update my firmware, but could not find any update. On thos forum I noticed gsm_jatt2 description on how to do it and I did it - successfully (thanks gsm_jatt2). BUT after 2 or 3 days I noticed, that the battery is discarging veri fast - it last only for 1.5 day, even though I had turned off all connections. o metter what I have done, battery did not last longer. My gues is, that some program must run in backside. I also deinstal all app s but no success.
So after a week I decide to download firmware from samfirmware and i downloaded the one named GT-S5830i_PHE_S5830IXXLH3_S5830IOXXLH1_S5830IXXLH3.zi p.
I tried flash telephone with odin and with one file only, but no success. Downloaded cygwin and "extract" original file, and then flas telephone and it fla**** normal way.
After testing telephone with new firmware I decide to keep it, battery consumption vent to "normal" - like it was before. In this flash program was also SI langue for me.
I decided to write this message, if maybe someone of the members noticed the same problem.
Anyway thanks for all help.
Tadej
Old 10-31-2012, 19:31   #20 (permalink)
mamun_q's Avatar
Member: 844892
Sonork: 100.1618521
Thanks Meter: 151
pls screen short .........................
Old 11-03-2012, 13:47   #21 (permalink)
Member: 683579
Thanks Meter: 225
need usb driver or which driver same
Old 11-18-2012, 13:01   #22 (permalink)
Member: 1840991
odin file not working
Old 11-20-2012, 18:44   #23 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,087
1000000% success
successfully flash
Old 11-25-2012, 09:52   #24 (permalink)
sumeet922's Avatar
Member: 400755
Sonork: 09226491934
Thanks Meter: 81
new link
S5830iXXKL1_S5830iXXKK5_OXEKK4.zip
Old 11-25-2012, 10:08   #25 (permalink)
Member: 489290
magic trick all gsm samsung phone code with out box >>>>>>>
use insert CDMA sim ,, set says INCORRECT sim . dial use reset code 2767.......injoy
Old 12-18-2012, 18:50   #26 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
Samsung Galaxy Ace (S5830i) Update Flash Successfully
PASS: sampro.pl
open Odin3 1.85
Really Its Work Fo Me
Old 01-17-2013, 19:52   #27 (permalink)
Member: 223859
Thanks Meter: 35
I have problems with update
after finish updating the screen turns red
Old 01-21-2013, 18:38   #28 (permalink)
Member: 223859
Thanks Meter: 35
I need help, someone help me.
Old 01-24-2013, 10:20   #29 (permalink)
Member: 296999
Sonork: not avaible
Thanks Meter: 83
i have same problem red led , but ny phone is s5839i
Old 03-07-2013, 12:07   #30 (permalink)
Member: 1895711
PASS: sampro.pl
open Odin3 1.85
it requires password what is it?
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
Page generated in 0.30446 seconds with 10 queries
