Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
07-05-2002, 20:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | c35 show charging,doesn't poweron Today I encountered siemens c35 which is show charging appears when connect charger. If I try to power on only blink then power off. What is the problemm? Changing good bat also doesn't help.Bye. |
07-06-2002, 00:09 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Vietnam Age: 57
Member: 13356 Status: Offline Thanks Meter: 2 | c35 problem Hi - resolder Flash chip and Ram chip ... if the same - change new power IC ....if the same - change new flash chip and full flash repaire erom goog luck |
07-06-2002, 01:12 | #3 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Malaysia
Member: 5381 Status: Offline Thanks Meter: 0 | @gsmsalers If you can charge the phone, it shows that the hardware is still alive! All you need to do is flash the phone and if it still doesn't power up, then you use the CMS35 Imei Changer/Repairer that's available all over the net!! You can also do the procedure in reverse - Imei (and if it doesn't power up) then full flash. See the results for yourself!! Hardware should only be the LAST RESORT!! |
07-06-2002, 15:04 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Man !!! Change Dialog IC and u solve prob if u r lucky !!!! Otherwise, u can try to change CPU... Good luck BR Vule |
Nokia 6111 shows charging, but.. just shows | mahcin | Nokia Hardware & Hardware Repair | 0 | 05-08-2009 19:58 |
C100 shows charging but doesn't charge | GSM SNIPER | Samsung Hardware Repair | 1 | 07-08-2004 19:24 |
C35 shows charging, but not actually charge. | sat | Siemens Hardware Repair Area | 3 | 12-04-2001 12:27 |
3210 shows charging, but not charge actually. | sat | Nokia Hardware & Hardware Repair | 6 | 11-02-2001 01:28 |
when connected to charger siemens c35 shows it's charging, but in fact not charging.. | sat | Siemens Hardware Repair Area | 0 | 09-03-2001 18:06 |
