07-01-2005, 07:31 | #33 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 53
Member: 128808 Status: Offline Thanks Meter: 0 | Quote:
referenced here http://forum.gsmhosting.com/vbb/show...1&page=1&pp=15 i couldn't make neither v4.0.1.1500 nor v4.0.1.2101 work on my IBM ThinkPad R51. (same internal dongle as you - tried INF-patching, too...) well.. who cares? since the *.700 works fine... there's no real problem, is there? cu ed correction: the "Yolly Zubrick" method does work for VID=1668 & PID=2441 ... one just has to do it correctly *ggg* i've just made v4.0.1.2101 work. thanx 2 all contributors! Last edited by ertandum; 07-01-2005 at 09:04. | |
07-01-2005, 13:54 | #34 (permalink) |
Junior Member Join Date: Nov 2004 Age: 44
Member: 92152 Status: Offline Thanks Meter: 2 | suggest me my bluetooth software not support my bluetooth -------------------------------------------------------------------------------- any body help me to solve my problem i have bluetooth type BT210 having driver (ISSC Bluetooth usb device) my bluetooth software cd broken so i m helpless know so plz tell me which bluetooth software version work with my bluetooth plz help |
07-01-2005, 20:56 | #35 (permalink) | |
Freak Poster Join Date: Sep 2003
Member: 39443 Status: Offline Thanks Meter: 2 | Quote:
I think the better way is to select a similar device from the file, dublicate the line with the pid and vid settings and modify matching them to the values of the own device. Or perhaps copy only the line with the own pid and vid from the older inf file and insert it into the new one (should also work). | |
07-04-2005, 13:59 | #36 (permalink) |
Junior Member Join Date: Oct 2003
Member: 42973 Status: Offline Thanks Meter: 0 | Alternate D/l ( Patched ) http://*******.com/c55mx 1) Add/Remove Programs - Uninstall existing Bluetooth Stack 2) Reboot. 1) Disable Device (Unplug) 2) Run above patched exe 3) Enable / plug in the device when prompted later in the install 4) Reboot. Enjoy... Last edited by int03h; 07-04-2005 at 15:58. Reason: tested procedure working. |
07-05-2005, 05:29 | #37 (permalink) |
Insane Poster Join Date: Jun 2005 Age: 42
Member: 151745 Status: Offline Thanks Meter: 1 | Hi There plz suggest any software that supports I have Cambridge Bluetooth Dongle its hardware info is Hcl Version I.2 Hcl Revesion 512 Lmp Version 1.2 Lmp Sub Version 512 Csr Bluetooth Usb Drivers This is the only info I have about my device,i don't know much about blouetooth. Plz show ur little concern towards me also Last edited by DEVANK; 07-05-2005 at 05:53. |
07-06-2005, 10:10 | #38 (permalink) |
Junior Member Join Date: Apr 2005
Member: 141581 Status: Offline Thanks Meter: 0 | Any idea what to do with a Logitech USB-Hub (from BT-Mause MX900)? I only want to install the BT-Function without the mouse-software. How do i have to install it? I have Widcomm 4.0.1.700 patched and 4.0.1.2100 patched. But it doesnīt work. Can somebody tell me how to do? |
07-06-2005, 16:25 | #39 (permalink) |
Junior Member Join Date: Jun 2005 Age: 47
Member: 154375 Status: Offline Thanks Meter: 0 | Hi Guyz, PLEASE URGENT There is lots of info on downloads & installing, but could you plz repost a link for 4.0.1.2100 patched, so that we can download & install without all the hassles. The link posted by int03h is blocked url. |
07-06-2005, 20:43 | #40 (permalink) |
Junior Member Join Date: Jun 2005 Age: 74
Member: 154818 Status: Offline Thanks Meter: 0 | hi mr.jaffarmohamed, the link posted by mr.int03h works fine and it installs just fine.anyway many thanks to all who posted and helped many of us overcome various problems reg.this particular subject.thank u allmy friends |
07-07-2005, 06:54 | #41 (permalink) |
Member: 154375 Status: Offline Thanks Meter: 0 | GUYZ, I cannot download it b'coz i am currently located in Saudi Arabia the URL is blocked here. could you plz post it at a different site so that i can download. Many Thankxxxxxx |
07-08-2005, 05:02 | #42 (permalink) |
Junior Member Join Date: Jan 2005 Age: 45
Member: 108636 Status: Offline Thanks Meter: 0 | Just wanted to say thanks! I am now up and running with the internal Dell Truemobile 350 on my Inspiron 9300 notebook! For anyone who is interested here is the 'btwusb.inf' file that I used: http://home.comcast.net/~mlpaschal/btwusb.inf All I did was add the VID/PID for the Dell Truemobile 350 device. Martian |
07-08-2005, 09:08 | #43 (permalink) |
Junior Member Join Date: Jul 2005 Age: 44
Member: 159217 Status: Offline Thanks Meter: 0 | nice to hear that you got the widcomm driver to work with your 9300. mind if u describe the steps in detail? i got the same bluetooth ( dell 350 with same VID and PID). Tried installing with the setup.exe after modifying the btwusb.inf. Didn't detect the bluetooth . Repeat it with the bluetooth disable in bios then restart after installing with the bluetooth enable, still didn't detect the bluetooth . Repeat it and patch the four files, again fail to detect the bluetooth . help please. |
07-08-2005, 13:41 | #44 (permalink) |
Member: 154818 Status: Offline Thanks Meter: 0 | thanks mr.jaffarmmed,i wish i could repost it in another site. i am having an 56kbps dialup connection which is virtually difficult to upload about 55MB stuff.hope u'll excuse me at this juncture.regards. |
07-11-2005, 18:22 | #45 (permalink) |
Junior Member Join Date: Jul 2005 Age: 42
Member: 159790 Status: Offline Thanks Meter: 0 | Found a way on T43 Hi folks, I finally got it. Yeah. My onboard IBM bluetooth IV advice is working. I had problems connection to my Nokia 6230. So I got no connection. But with the Widcomm .700 drivers it suddenly worked. But my Thinkpad didnīt accept the new patched Widcomm drivers (.2101?). Donīt know why. So, if someoneīs out there still having problems with IBM and bluetooth try the older drivers or send a PM. Cheers Last edited by herr.nilsson; 07-11-2005 at 18:33. |
Widcomm 4.0.1.900 | Phantasm4489 | Bluetooth-Software | 223 | 12-14-2017 10:29 |
Which ones better? Widcomm 4.0.1.2101 or IVT BlueSoleil 1.6.2.1 | crellion | Bluetooth-Software | 5 | 10-03-2005 23:22 |
Widcomm 4.0.1.2101 problem | ][No_WaY | Bluetooth-Software | 4 | 08-20-2005 14:50 |
widcomm 4.0.1.2101 with older drivers ? | MUSANI | Bluetooth-Software | 0 | 08-05-2005 02:09 |
Widcomm 4.0.1.1500 | billyx | Bluetooth-Software | 16 | 06-30-2005 23:42 |
