Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Bluetooth > Bluetooth-Software
Old 11-30-2006, 17:52   #16 (permalink)
Member: 102577
Thanks Meter: 4
Originally Posted by solnyshok View Post
Adi
I have IBM Thinkpad builtin Bluetooth. How do I check bt firmware version and where I should look for update?
Solnyshok
First of all i suggest you do some more reading in this forums as the first part of your question has been answered many times already, but since i'm in a nice mood this morning here's how to check assuming you have the Widcomm stack installed : Right click on the Bluetooth icon in the system tray and select bluetooth configuration or advanced configuration depending on your version. There, click on the Diagnostics tab and it will tell you the details of your device including the firmware revision.
As far as support goes, simply go the the IBM site (now lenovo) and follow the instructions in order to get driver updated for your laptop. You'll have to enter the model number etc. The Widcomm stack that IBM provides usually includes a firmware update as well.
Adi
Old 11-30-2006, 22:05   #17 (permalink)
Member: 260350
Adi, I am a bit surprised that my firmware is not following the numbering scheme you discussed in this topic (broadcom 2.xxx). mine is
csr
version 546
HCI 1.1 rev 222
LCI 1.1 rev 222
Could you explain what this numbers mean?
Solnyshok
Old 11-30-2006, 23:02   #18 (permalink)
Member: 79741
Idk if this is of any relevance, but Logitech firmware revision is 2.1.199.0 (released about a month ago along with custom 5.0.1.2703 stack).
Funny enough the desktop I got the dongle with sux balls big time (MX5000 Laser). As soon as my new keyboard/mouse arrive is going straight to the charity shop.
Old 11-30-2006, 23:03   #19 (permalink)
Member: 102577
Thanks Meter: 4
csr
version 546
HCI 1.1 rev 222
LCI 1.1 rev 222
Solnyshok
You don't have a Broadcom based dongle. Yours is by CSR (Cambridge Silicon Radio) and therefor at the current time it will only work with Widcomm 5.1.0.1100 max with the patch applied.
Adi
Old 11-30-2006, 23:04   #20 (permalink)
Member: 102577
Thanks Meter: 4
Can you give me a link ? I just used the autoupdate function on the Logitech software and said i was using the latest version (5.0.1.2500). I have the MX5000 combo. What do you have ?
Adi
Old 11-30-2006, 23:36   #21 (permalink)
Member: 79741
http://www.logitech.com/pub/controld...C_GM_32bit.zip
http://www.logitech.com/pub/controld...C_GM_64bit.zip
password: btimprove
Source:
http://forums.logitech.com/logitech/...essage.id=1416
Old 12-01-2006, 04:56   #22 (permalink)
Member: 187700
I've done some testing of this version on Vista x64. On first install I didn't make any changes to the btwusb.inf or patch the license file.
The following reboot I was given the typical license error.
So I uninstalled and patched the license.dat with widcomm license patcher 1.8. I also edited the btwusb.inf to add my device to [ControlFlags]. The device was already listed in the [WIDCOMM.NTamd64] and [strings].
I think this inf has already been edited somewhat as it is a bit of a mess and has the 5.1.0.2400 tag, and some files are 5.1.0.2500.
I then rebooted, and changed the USB Wireless Bluetooth device to my Air2u device using the update driver method (by selecting update driver, browse, let me pick, Air2u device).
In device manager:
Air2U Bluetooth Device 5.1.0.2400
Bluetooth Bus Enumerator 5.1.0.2500
After another reboot the WIDCOMM configuration seemed to be working. It detected by Bluetooth. But, I am unable to add a device - "No local Bluetooth device was detected." Which is quite interesting as it clearly listed under diagnostics.
So I have been unable to get it to work. My mobile cannot detect the PC and my PC cannot detect my mobile. Maybe it is just not compatible with Vista x64 yet or is this a license patching issue?
Old 12-01-2006, 05:58   #23 (permalink)
Member: 102577
Thanks Meter: 4
In device manager:
Try unplugging your device in Vista and replugging it in a different USB port. For some reason that did the trick for me.. or at least i think it did. Also, your device is Broadcom based, right ?
Adi
Old 12-01-2006, 06:00   #24 (permalink)
Member: 102577
Thanks Meter: 4
Thanks for the links ! Wow, wonder what Logitech is waiting for to post this officially on their website... anyways, at least they're providing firmware updates on a pretty regular basis and this is a Good Thing TM. Compare this to the other made in taiwan no name dongles that still ship with 2.1.33 :s
Adi
Old 12-01-2006, 07:17   #25 (permalink)
Member: 190415
There's a patching issue. Hope Phantasm will update his patcher.
Old 12-01-2006, 19:31   #26 (permalink)
Member: 79741
Adi
np ^^
And I wonder the same mate. Look at the date of the mod's post and go figure...
I mean, this version of the software is not the cure for all sores, but at least I can certify it completely kills the keyboard lag , so does it up with the "double keypress" problem when waking up the keyboard.
I still think the MX5000 combo is a nasty piece of work, but hopefully with this software version those of you who don't have a motherboard that absolutely hates the Logitech dongle (my DFI NFII UltraInfinity loathes it), will see their usage experience greatly improved.
For me is still the same. No pre-os keyboard usage (i need an additional wired keyboard for BIOS access etc. etc. ), erratic disconnects, all sorts.
Old 12-06-2006, 03:36   #27 (permalink)
Member: 102577
Thanks Meter: 4
Umm, you're willing to get rid of your MX5000 combo ? I'm willing to pick it up for a fair price
Adi
Old 12-06-2006, 17:39   #28 (permalink)
Member: 79741
Adi
Sorry mate, too late for when I read this lines... is already gone to the charity shop.
As soon as my new Raptor K1 and Razer Copperhead arrived (I'm so fed up of my experience with the MX5000 that I've gone wired again) I took it there.
Old 12-07-2006, 05:00   #29 (permalink)
Member: 222206
Won't work either
I am running Vista x64 with an ISSC dongle. It appears to install but can't use it. Under Network Connections it does not show up. When I try to connect my Palm Tungsten T3 PDA via Hot Sync through the BT it says ANOTHER PROGRAM IS ALREADY USING IT.
I was able to use the 5.0.1100 version on x86 Vista as previously reported on this website without any difficulties.
My other problem is that I have no drivers for my PDA for Vista x64. I would really like the BT to work so I can use it until PALM builds drivers for it.
Any thoughts??
TIA
BILL
Old 12-07-2006, 19:59   #30 (permalink)
Member: 40901
Thanks Meter: 2
So far I havent had much luck getting the more recent widcomm drivers to work correctly.
I have managed to make a version of the patcher which doesnt display license error messages, but it wont pair with my devices.
Not sure at this time whether or not this is some additional license checking or just hardware compatibility issues with csr devices.
Anyway ive attached my patcher 1.9pre and maybe some of you can have a play and see if you get any luck
[IMG] code is Off
Anycom 5.1.0.2500 - Windows ( Not Vista ) int03h Bluetooth-Software 3 07-04-2007 02:53
PC as headset with Widcomm 5.1.0.2500 xrapidx Bluetooth-Software 2 12-08-2006 09:58
Widcomm 5.1.0.1700 adisor19 Bluetooth-Software 81 09-25-2006 19:22
Widcomm 5.1.0.1700a adisor19 Bluetooth-Software 15 07-30-2006 15:47
Problem Serial Port in Widcomm 5.1.0.1100 Nuker5 Bluetooth-Software 3 07-04-2006 12:45
Page generated in 0.25846 seconds with 10 queries
