06-28-2006, 14:11 | #826 (permalink) | |
Major Poster Join Date: May 2006 Location: Nearby my COMPUTER Age: 41
Member: 274923 Status: Offline Thanks Meter: 1 | Quote:
If it is 2.00 of tornado software and 7.00 of flash for nokia make: -full backup of PM -full erase flash -write backuped PM -write flash -and post results Regards, GsmDemon | |
06-28-2006, 15:47 | #827 (permalink) |
Freak Poster Join Date: Nov 2002 Location: neverland Age: 45
Member: 18165 Status: Offline Thanks Meter: 12 | @gerico: you can try skip erase form area 1 by default its 9 its near product field but after you flas it once with higher version then you need to reflash it without the skip erase area because the phone will make problems |
06-30-2006, 00:38 | #829 (permalink) |
No Life Poster Join Date: Apr 2004 Location: london, united kingdom Age: 42
Member: 62602 Status: Offline Thanks Meter: 6 | 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x01FFFFFF,87CDB60A, Algorithm: u_intel.fia, Ver: 4.44.1 Algorithm Ok, MSID: 84A581166551D78216923EB542 Decoded MSID: 3E4EBAE9-005578A7-A8000000 Encoded FAID: 29C3B644-407D871C-6853E855 Erasing: 0x011FC000-0x011FFFFF ... Erasing Error: 10, at: 0x011FC000-0x011FFFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile problem in 2600 are there solution ??? |
06-30-2006, 09:58 | #830 (permalink) | |
Junior Member Join Date: Sep 2004
Member: 82907 Status: Offline Thanks Meter: 0 | Quote:
1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,0001267E,Amd 29BDS643HT Algorithm: u_amd_b.fia, Ver: 4.15.0 Erasing: 0x01000000-0x017FFFFF ... Erasing Error: 10, at: 0x01000000-0x0101FFFF, 940207, Time: 0:00 | |
06-30-2006, 10:03 | #831 (permalink) | |
Detected: V 5.52 13-04-04 NPL-1 (c) NMP. 1st Boot Ok, DCT4, UPP: 1120 Fl0: 0x01000000-0x017FFFFF,0001267E,Amd 29BDS643HT Algorithm: u_amd_b.fia, Ver: 4.15.0 Algorithm Ok, MSID: 84B3D25F96632C215B0CBAE1E5 Decoded MSID: F6D3BAE9-000C7C0F-A8000000 Encoded FAID: 8D3D95E8-F93E340C-A69FE238 Area1: 0x01000000-0x0100FFFF Erasure Skipped Area2: 0x01010000-0x015CFFFF Erasure Skipped Area3: 0x016B0000-0x017EFFFF Erasure Skipped BT MCM (26) Image Found & Skipped: 1211 BT MCM (26) Image Found: 22, 0x0002DA5C BT MCM Flashing Done, Time: 0:20 Write Error: hDat 14, at: 0x01000064:08 Process Failed, Repowering Mobile The phone is version 5.52 , compatibility problems ? another idea ? | |
06-30-2006, 14:28 | #832 (permalink) |
Member: 274923 Status: Offline Thanks Meter: 1 | @Gerico Is your telephone work fine now? If yes, check cable. If this don't help-i thikn that your flash chip is destroyed. Maybe try with other flasher(JAF, Griffin etc.) Regards GsmDemon |
06-30-2006, 17:53 | #833 (permalink) | |
Thanxs a lot for de help. | |
07-01-2006, 07:58 | #834 (permalink) | |
Insane Poster Join Date: Aug 2005 Location: bangalore -india Age: 45
Member: 167560 Status: Offline Thanks Meter: 1 | Quote:
flash it with JAF it will work 100 % vaheed | |
07-01-2006, 12:14 | #835 (permalink) |
Junior Member Join Date: Oct 2002 Age: 47
Member: 17301 Status: Offline Thanks Meter: 0 | Problem with UFS-3 flasher. When I trying to flash most of WD2 phones I got this error: Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088BE,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088BE,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.52.0 Alg Boot Error: 2 Error Data1: 00000000: 9B 00 04 00 20 00 BE 88 00 00 00 00 02 20 00 BE .... ........ .. 00000010: 88 00 00 00 00 04 20 00 BE 88 00 00 00 00 06 20 ...... ........ 00000020: 00 BE 88 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 ...........u...x 00000030: 01 00 EA 7B 01 00 EA 7E 00 00 00 00 00 00 00 00 ...{...~........ Error Data2: 00000000: F3 72 00 BE 88 00 00 00 00 02 20 00 BE 88 00 00 .r........ ..... 00000010: 00 00 04 20 00 BE 88 00 00 00 00 06 20 00 BE 88 ... ........ ... 00000020: 00 00 00 00 C6 00 00 EA 75 01 00 EA 78 01 00 EA ........u...x... 00000030: 7B 01 00 EA 7E D3 72 00 00 00 00 00 00 00 00 00 {...~.r......... Before taking screenshot, expand this window ! Process Failed, Repowering Mobile And the similar error when I trying to flash most of DCT-4 phones. Maybe someone knows how to solve this problem? |
07-01-2006, 14:17 | #837 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: pok wong malaysia
Member: 300886 Status: Offline Thanks Meter: 61 | power up phone manually Quote:
i hope this can solve ur problem | |
07-04-2006, 19:09 | #840 (permalink) |
Junior Member Join Date: Apr 2006
Member: 265552 Status: Offline Thanks Meter: 0 | Box_auth_error : 31 Hi..All senior..please help My UFS3 box :after use Twistertool v3.o.v4.1..upgrade to v2.6.7..my box have error :BOX_AUTH_ERROR : 31. only at Dctx_ufs(i use Dctx_ufs_13j or Twister_Dctx.i try other Version still same) Need Help ..Please..Thanks... BR dj3 |
Post here all successfuly flashed, unlocked and repaired phones with ATF software. | dr_aybyd | Advance-Box | 6048 | 02-04-2019 16:48 |
Post here all Nokia 1200,1208,1209 and 1650 Network problems | mobilecitycbk | Nokia Hardware & Hardware Repair | 12 | 09-20-2015 04:01 |
Post here all UFS 3 Tornado Box Tutorilas and videos?? | nofear99 | Nokia Base Band 5 ( BB-5 ) | 2 | 01-24-2015 06:12 |
all members can post here all moto L7.L6.V3 and more of problem and also post solutio | 786sunny | Motorola Hardware Repair | 3 | 04-12-2007 17:53 |
