03-12-2004, 19:17 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Hell Age: 50
Member: 28858 Status: Offline Thanks Meter: 1 | UFS2 Strange problems! pls check & post sugestions! I just bought a new UFS2 box from a reputed software dealer, i loaded the USB drivers and the box is detected well (checked in device manager in win98se) i doenload all the softwares and when i run the DCTX-m,l,k versions the Menu is completely disabled! only for the "connect", "update firmware" and the "Reset counter" options, all the others are disabled. and when i press connect! it gives me error's (pls see attachemnts) i hve gone thru the forum's, contacted my reseller and still awaiting help! WBR AE177 |
03-12-2004, 19:52 | #3 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Tallinn
Member: 40082 Status: Offline Thanks Meter: 3 | and about disabled buttons in Motorola Acer soft - it's ok that buttons are disabled, because box is not connected. after successful connection to box buttons will be active |
03-12-2004, 20:31 | #4 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Hong Kong, China
Member: 7866 Status: Offline Thanks Meter: 4 | @AE177 Try another PC's, seems the USB port problem, because I have seen that even the DCTx-1.2L cannot be run !!! You are using a USB HUB ? or a PCI add on card ? Try plug the UFS-2 directly to the PC's USB port, don't use a too long USB cable. Cables |
SE K770i Whats the problem, Pls check logs | dune2 | SETool2 | 4 | 03-29-2010 08:33 |
support problem pls check | beo_tech | FuriousGold | 3 | 02-19-2010 18:19 |
Update problem pls check Smart-clip Team | invite | Smart-Clip | 1 | 04-02-2009 08:07 |
6600 UEM Problem..Pls Check it.. | LoveLess | Nokia Hardware & Hardware Repair | 17 | 12-18-2007 12:56 |
3310,Funny problem PLs Check | Henry | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-10-2001 21:40 |
