Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
08-04-2005, 11:22 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Ngeria Age: 41
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | Codes regards |
The Following 2 Users Say Thank You to .::sly::. For This Useful Post: |
08-04-2005, 11:27 | #2 (permalink) |
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | Am starting with this You can format user area of WD2 Nokias. I have Tested it and 100% working on 6600 and 6260 hold dow * + 3 + Send button + Power button untill you see "Formatting" then release and let it complete formating. after finishing the reboot automatically and phone is 100% ok regards |
The Following 3 Users Say Thank You to .::sly::. For This Useful Post: |
08-04-2005, 17:27 | #5 (permalink) |
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | You can format Nokia wd2 with this code too. I have Tested it and 100% working *#7370# After the code, phone will ask you for security code use 12345(default) if the code has not been changed or ask if the owner know the security code insert it and phone will reboot automatically and phone is 100% ok * u cannot use this code if you dont know security code of phone then use the above * All data on the phone will be lost regards |
08-04-2005, 17:51 | #7 (permalink) |
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | you can add new ones that is what i have sorry ok we are here to share what we have so please post yours if you have any new |
08-04-2005, 17:52 | #8 (permalink) | |
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | Quote:
ok we are here to share what we have so please post yours if you have any new regards | |
08-04-2005, 18:05 | #9 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 41
Member: 153299 Status: Offline Thanks Meter: 59 | im sorry to.. thats ok.! here my share... CODES Alcatel IMEI number: * # 0 6 # Software version: * # 0 6 # Net Monitor: 0 0 0 0 0 0 * Bosch IMEI Number: * # 0 6 # Dafault Language: * # 0 0 0 0 # Net Monitor: * # 3 2 6 2 2 5 5 * 8 3 7 8 # Dancall IMEI number: * # 0 6 # Software version: * # 9 9 9 9 # SIMcard serial number: * # 9 9 9 4 # Information about battery status: * # 9 9 9 0 # Selftest (only Dancall HP2731): * # 9 9 9 7 # Show version configuration: * # 9 9 9 8 # Net Monitor: * # 9 9 9 3 # Ericsson 6xx/7xx/8xx IMEI number: * # 0 6 # Software version: > * < < * < * Default language: < 0 0 0 0 > Enter to phone menu without SimCard - after Wrong PIN press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 # Information about SIMLOCK: < * * < Ericsson A1018S/T10S/T18S/T28S IMEI number: * # 0 6 # Software version: > * < < * < * Default language: < 0 0 0 0 > Enter to phone menu without SimCard - after Wrong PIN press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 # Information about SIMLOCK: < * * < Hagenuk (Duet) IMEI number: * # 0 6 # Software version check: # # 9 1 4 0 * 8 3 # 7 5 * 2 # Motorola IMEI number: * # 0 6 # Net Monitor ON: * * * 1 1 3 * 1 * [OK] Net Monitor OFF: * * * 1 1 3 * 1 * [OK] * - press this until box shown up Maxon *#9988# Tetris Play *#9900# Software Version *#9911# L1 Debug on/off *#9916# Text (scroll trough with up/down) *#9937# Discharging battery *#9958# Watch stop *#9959# Watch start *#9960# Contrast set Lock status *#9917# NOKIA 5110/5120/5130/5190/6110/6120/6130/6150/6190 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off] Half Rate: * 4 7 2 0 # Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 1 Network lock status # p w + 1 2 3 4 5 6 7 8 9 0 + 2 Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 3 SimCard lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 4 1234567890 - MasterCode which is generated from IMEI Nokia 3110 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # or * # 9 9 9 9 # or * # 3 1 1 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # Philips IMEI number: * # 0 6 # Simlock info: * # 8 3 7 7 # Security code: * # 1 2 3 4 # (Fizz) or * # 7 4 8 9 # Samsung SGH600/2100DB IMEI number: * # 0 6 # Software version: * # 9 9 9 9 # albo * # 0 8 3 7 # Net Monitor: * # 0 3 2 4 # Chaning LCD contrast: * # 0 5 2 3 # Memory info: * # 0 3 7 7 # albo * # 0 2 4 6 # Reset memory (SIMLOCK`a removing!!!): * 2 7 6 7 * 3 8 5 5# Reset CUSTOM memory: * 2 7 6 7 * 2 8 7 8 # Battery state: * # 9 9 9 8 * 2 2 8 # Alarm beeper: * # 9 9 9 8 * 2 8 9 # Vibra test: * # 9 9 9 8 * 8 4 2 # Sagem IMEI number: * # 0 6 # Service Menu access: MENU 5 1 1 # Siemens C25/S25 IMEI number: * # 0 6 # Software version: put off sim card and enter: : * # 0 6 # and press LONG KEY Bunus screen: in phone booke: + 1 2 0 2 2 2 4 3 1 2 1 Net Monitor (S4 Power): Menu 9 8, left SoftKey, 7 6 8 4 6 6 6, Red phone, Menu 5 6 Sony IMEI number: * # 0 6 # Software version: * # 8 3 7 7 4 6 6 # Show list of product creator names (you must save this number in your Phone Book with "own phone no." record): + 1 2 0 2 2 2 4 3 1 2 1 b.r. |
The Following 2 Users Say Thank You to ANoNYMoUS_1 For This Useful Post: |
08-05-2005, 10:18 | #10 (permalink) |
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | ANoNYMoUS_1, Thanks for the codes Please i need Unlocking code for samsung phones Most xpecialy D500, E720 and some other new samsung please post it here Regards |
The Following User Says Thank You to .::sly::. For This Useful Post: |
08-07-2005, 19:31 | #12 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: in my PC of Montreal
Member: 43478 Status: Offline Thanks Meter: 33 | Quote:
G50 **00012*00000000# or **00032*00000000# dont write anything please | |
The Following User Says Thank You to SALNAI For This Useful Post: |
08-08-2005, 04:22 | #15 (permalink) | |
IMEI *#06# Version * # 2820 # hardware reset *73738# (send?) Lock info * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock SIM LOCK *#4960 # (send?) - info *4960*pass*pass#(send?) -lock #4960*pass#(send?) -unlock Lock Status * # 3210 # (send?) - SP lock * # 8140 # (send?) - Net lock Thanks for sharing | |
> All codes for samsung mobiles.......[check this out...] | kashem403342 | Nokia Base Band 5 ( BB-5 ) | 1 | 03-29-2010 14:54 |
code BLAUPUNKT SEAT SE 359 | iced_clarion | CAR Electronics | 2 | 03-29-2010 12:16 |
Need unlock CODE FOR 8900 CURVE | mbagen | BlackBerry (RIM) | 1 | 03-29-2010 12:16 |
All codes for samsung mobiles.......[check this out...] | kashem403342 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:09 |
BE2569 code from dump | balanel | CAR Electronics | 2 | 03-29-2010 10:37 |
