12-17-2004, 18:48 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 44
Member: 96356 Status: Offline Thanks Meter: 0 | anew problem in samsung (n620) i have aproblem with samsung (n620) it was working good sudenley when i give it power on it gives me astrange message it's ( seystem failur ) i think it's like (conntact servise) with nokia mobiles did any one see that message befor? and how could i fix it by software or hard ware plz help me with that problem thatnks friends |
12-17-2004, 21:09 | #2 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Lebanon / Nigeria Age: 52
Member: 42276 Status: Offline Thanks Meter: 47 | Quote:
in case did not work you have to do E2p reset and write IMEI. Good luck. | |
12-17-2004, 23:14 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Pakistan Age: 42
Member: 56561 Status: Offline Sonork: 100.114006 Thanks Meter: 41 | This is hardware problem. Just rehot the EEPROM, All will be ok. If not worked then this is the fault of EEPROM WBR Imran Khatri |
12-20-2004, 20:09 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | not hardware first of all check the imei of ur phone if it is not the same as that of phone or it has some 44 type number then using ust pro software to repair a system failure or use it to chane imei of ur phone ... this is common problem in samsung not a strange problem.. if this solution doesnot work then go to the hardware.. check the charging jack then go to eeprom.. |
Problem in samsung software in HWK | !!DiGiTaL!! | HWK | 9 | 05-27-2008 20:50 |
big problem in samsung!!! | manju | Samsung Hardware Repair | 1 | 11-19-2005 21:20 |
GPRS problem in Samsung C100 | wetwater | Trident/AGERE Platform | 1 | 09-06-2003 15:41 |
GPRS problem in samsung c100 | wetwater | VLSI, Conexant, Skyworks and Old Models | 0 | 08-15-2003 11:31 |
GPRS Problem in Samsung C100 | wetwater | Trident/AGERE Platform | 0 | 08-15-2003 11:29 |
