05-25-2005, 05:48 | #18 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2003 Location: ITALY
Member: 23994 Status: Offline Thanks Meter: 43 | Quote:
05-25-2005, 20:08 | #20 (permalink) |
Junior Member Join Date: Jun 2004 Age: 39
Member: 69007 Status: Offline Thanks Meter: 2 | i had this problem and gave it to the samsung repair centre and they said i have to pay 8000rs( us$200) to get it repaired!!! and so my c100 is lying idle since 6 months i am very much interested in trying this out but a complete noob...... also alongwith charging i do not get network can somebody plz explain the procedure of removing that component in details?what tools will i require??? |
05-30-2005, 16:32 | #24 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | i tryed but not work with me any slotion for i removed u202 but still same pause by tem..... i wnat help it's not working man *********************Azam********************* |
05-30-2005, 16:34 | #25 (permalink) | |
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | Quote:
******************Azam******************* | |
06-01-2005, 13:28 | #26 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Ionosphere Age: 47
Member: 101426 Status: Offline Thanks Meter: 1 | Quote:
06-01-2005, 18:49 | #27 (permalink) |
Freak Poster Join Date: Jul 2004 Location: nigeria Age: 41
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | pls can any 1 send 2 me d solution 4 T100 it see service but (call fail) wen i make call, [email protected] |
06-02-2005, 09:33 | #28 (permalink) | |
Sconde open the set and re heat the (FDK)vco and it will ok tested 100% it's working Good Luck And pls here post only problem like charging (Paused By Temperature) problem ******************Azam****************** | |
06-02-2005, 11:43 | #29 (permalink) | |
************Azam*************** | |
06-02-2005, 12:34 | #30 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | Solution is old and very good and is working, but one single mistake: after remove charging IC, replace it with a diode soldered in serial with a resistor between 5 - 10 Ohms BR, xyz |
c100 pause by temperature | sonetek | Samsung Hardware Repair | 0 | 06-27-2006 15:35 |
c100 pause by temperature | RAHUL12345 | Samsung Hardware Repair | 8 | 03-09-2006 12:03 |
c100 pause by temperature (diode problem) | akerejola | Samsung Hardware Repair | 0 | 09-17-2005 19:06 |
C100 paused by temperature | jetawo ademola | Trident/AGERE Platform | 0 | 01-26-2005 21:35 |
Samsung C100 Pause By Temperature. | japhetajayi | Trident/AGERE Platform | 0 | 12-08-2004 12:48 |
