Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-17-2015, 14:48   #1 (permalink)
Member: 2127758
Thanks Meter: 26
i9505 dead after power switch change
Hi guys,
I've a problem with 4x i9505...
After a power switch replacement, all the four i9505 stop working...
not power on...
Any idea? Any solution? What can i check?
Thanks...
The Following User Says Thank You to Sakalalina For This Useful Post:
Old 10-17-2015, 20:52   #2 (permalink)
Member: 144223
Thanks Meter: 10
what do u use to change hot air? how many A absorb? check u800 like troubleshooting
The Following 2 Users Say Thank You to pjk1980 For This Useful Post:
Old 10-18-2015, 12:23   #3 (permalink)
Member: 2127758
Thanks Meter: 26
Hi, thanks for reply...
I've check U501 output voltage (C835=1.225V, C838=1.05V) and is OK...
I've check the U800 output signal (R804=1.8V) and is OK...
I've check the OSC801, and is not working...no 32kHz signal...
Where i can find this OSC? In which other Samsung mainboard? i9100?
PS. I've use a classic solder...no hot air...
And...
When the mainboard is off is absorm 0.1mA, when i turn on it absorb 58mA
Old 10-18-2015, 20:45   #4 (permalink)
Member: 144223
Thanks Meter: 10
Bro, i can't help u
In elettrical spare list don't have specific of this oscillator but maybe u can try on s4 mini cause the supervisor is the same of i9505.... on my experience this problem seems typical on supervisor (u800).....
Old 10-19-2015, 06:52   #5 (permalink)
Member: 25662
Thanks Meter: 190
And...
any similar size 32khz oscillator work. if small size take from I9300,N7100 and if big then from I9100.
check volt & 32khz on tp809 ~.900v aprox.
Old 10-19-2015, 06:52   #6 (permalink)
Member: 2127758
Thanks Meter: 26
A rehot with hot air may help?
Or i need to replace it?
Old 10-19-2015, 18:58   #7 (permalink)
Member: 144223
Thanks Meter: 10
1) rehot with hot air
if not work replace it
pls keep us update
Old 10-20-2015, 07:48   #8 (permalink)
Member: 2127758
Thanks Meter: 26
I've check with the DSO on tp809, and there is the 32kHz clock...
So, what does mean? That all is ok?
Unfortunately the phone does still not working...
http://s11.postimg.org/6axfh6gf7/IMG...020_083752.jpg
I'll try to rehot u800...
Old 10-22-2015, 05:53   #9 (permalink)
Member: 25662
Thanks Meter: 190
Its not showing exact frequency 32.768khz. In DSO its showing 33.236khz.
change xtal or power ic. When you get exact frequency and still not on then do emmc procedure. you had changed switch so nearest part is wifi so check 1.8v on C214. If shorted then remove wifi IC. then check 1.8v.
Old 10-22-2015, 08:54   #10 (permalink)
Member: 2127758
Thanks Meter: 26
Thanks...
I've check C214 and i've found 2.95v!!!
So, i can try to remove the wifi IC or replace U800?
Edit.
I've try to connect the i9505 to a Octolus Jtag, and also the box doesn't recognize the chip...
Old 11-27-2015, 15:30   #11 (permalink)
Member: 2127758
Thanks Meter: 26
Problem still remain...
Any idea?
Old 11-28-2015, 15:54   #12 (permalink)
banalven1's Avatar
Member: 202941
Thanks Meter: 85
It power switch problem,remove power switch n try charging.
If can charging then replace the switch n solder it carefully.
Page generated in 0.26605 seconds with 8 queries
