Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
01-22-2013, 18:36 | #2131 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1278242 Status: Offline Thanks Meter: 2 | |
01-22-2013, 18:44 | #2132 (permalink) |
Member: 1278242 Status: Offline Thanks Meter: 2 | hi sir...help me please....can u tell me xperia X2 BSI voltage???my xperia X2 cant on with batery or PS ...but its not dead because i can charge it but not full like fake charging......i think BSI trouble...but i dont have scheme ....can u help me..sir???thanks sir |
01-30-2013, 10:49 | #2136 (permalink) |
Major Poster Join Date: Aug 2006 Location: Nigeria, osun state
Member: 330697 Status: Offline Thanks Meter: 2 | s312 not connecting to box i just flashed s312 and was successful but hanged on t mobile logo and i decided to remove the battery, but could not reconnect to the box since. it only shows light on the keypad and none on the screen. and it does not go off. |
01-30-2013, 10:52 | #2137 (permalink) |
Member: 330697 Status: Offline Thanks Meter: 2 | RUNNING v 1.1295/01.12/UNI CARD SERIAL 00175003 CFG:000000000000 PROCEDURE WAS STOPPED BY USER CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 40 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110100000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON ... PROCEDURE WAS STOPPED BY USER CAN'T LOAD IDENTIFICATION LOADER. Elapsed: 44 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110100000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON ... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:101110001000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON ... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 595 secs. SIGNED MODE (USING SERVER) CFG:101110001000 PLEASE SELECT "COM/UFS" AS INTERFACE Elapsed: 0 secs. SIGNED MODE (USING SERVER) CFG:101110001000 PLEASE SELECT "COM/UFS" AS INTERFACE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 PLEASE SELECT "COM/UFS" AS INTERFACE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 PLEASE SELECT "COM/UFS" AS INTERFACE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... Command CRC bad MALFORMED VERSION RESPONSE Elapsed: 20 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... Payload CRC bad MALFORMED VERSION RESPONSE FAILED TO SETUP PHONE Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Processing script "C:\Users\Abd rasaq\Desktop\Videos\s312\R3A_S312_CDF_1226_5790__ FS__T_Mobile_HR.software" ... PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... Payload CRC bad MALFORMED VERSION RESPONSE FAILED TO SETUP PHONE Elapsed: 13 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... Payload CRC bad MALFORMED VERSION RESPONSE FAILED TO SETUP PHONE Elapsed: 13 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. llbug: COM44 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:111110101000 Will backup GDFS now. PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY ... Payload CRC bad MALFORMED VERSION RESPONSE FAILED TO SETUP PHONE Elapsed: 15 secs. |
01-30-2013, 10:52 | #2138 (permalink) |
The Following User Says Thank You to oshidipe Rasaq For This Useful Post: |
02-01-2013, 10:56 | #2143 (permalink) |
Junior Member Join Date: Mar 2009
Member: 995872 Status: Offline Thanks Meter: 0 | sony r800i speaker problem pls help i have a sony r800i, when call speaker no sound but only heard noise, loud speaker n handsfree ok...I already change the speaker, but still the same.. can any one pls Help Thank you |
02-01-2013, 13:26 | #2144 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Cologne, Germany Age: 38
Member: 1695725 Status: Offline Thanks Meter: 10 | Hey there, i got a sony ericsson play. LCD was broken so i changed it. Now the bighlight isnt working. Just in some positions the backlight turns on. But if i slide 1mm in one direction the backlight turn off. Any solution? LCd maybe? |
02-01-2013, 13:26 | #2145 (permalink) |
..::Get ALL BB5 Problems I Solved In Only 1 hours::.. | 786786 | Nokia Repair Guide and FAQ | 4179 | 03-28-2014 18:56 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
Post urs problem here solves in 24 hrs by Javajohn | Javajohn | Nokia Hardware & Hardware Repair | 92 | 06-17-2006 07:43 |
problem and solve in SL45i | Ahmed Jundy | x1x to x45/x50 | 6 | 12-31-2003 00:42 |
