Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-30-2009, 18:49 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 903552 Status: Offline Sonork: rasfatzel Thanks Meter: 4 | c905 keypad problem |
The Following 2 Users Say Thank You to rasfatzel For This Useful Post: |
10-01-2009, 08:02 | #5 (permalink) |
Junior Member Join Date: Mar 2005 Age: 38
Member: 122830 Status: Offline Thanks Meter: 1 | 80% solution for the c905 keyboard i`ve got a s-e c905 and when i push on "6" key the phone ask me if i want to continue to play media in speaker? i hear c905 it`s a phone problem with keypad but with "c" key. i don`t open the phone because i think i can`t do anything if i don`t know where is the problem. can you help me with some picture please? try to change down keyboard first because try try it b4 many is coz down keyboard spoil.....i got this problem before got many phone like this n i slove with change down keyboard or flex or center ribbon only this problem sure no because montherboard problem.....try it all my buddies |
10-19-2009, 18:05 | #6 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | i push on "6" key the phone ask me if i want to continue to play media in speaker? same prob as peps above,,,,any1 fix this???? change keypad(bottom) or middle flex or top keypad???? any1 know please? |
11-20-2009, 14:55 | #7 (permalink) |
Junior Member Join Date: Oct 2008
Member: 889182 Status: Offline Thanks Meter: 3 | c905 key problem i've repaired 1 which have similar problem. either it's the slider ribbon or the upper key board problem. sometimes it's the key switch on the upper side of the lcd ( the left and right side of speaker). check whether there water damage ). |
The Following User Says Thank You to brynbryn For This Useful Post: |
12-02-2009, 13:36 | #8 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1174491 Status: Offline Thanks Meter: 0 | Fixed!!! HEY EVERYONE I FIXED THE PROBLEM. I dont know if sony erricsson have planned this hidden button but!! in the lcd screen on the top theres two buttons right when the key pad is broken the right key will work as a touch button when you slide your finger ower it and there you go its fixed. if it dosent work the first time it will work the other |
05-22-2010, 11:07 | #10 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1143112 Status: Offline Thanks Meter: 1 | Hi! I had the same problem with a c905 and there was broken ways at the buttons on the side. I manage to repair it by checking the schematics. There could also be the flex from keypad to board or the upper keypad. |
11-13-2010, 08:28 | #14 (permalink) |
Crazy Poster Join Date: Mar 2010
Member: 1268421 Status: Offline Thanks Meter: 4 | Cannot enter Menu button(center button)....on Upper keybord & some times 3,4,6,0 not woking.......... without down keypad connection Menu key is working......well. i think..... its down keypad board problem..... right? I tested............100% Replace the DOWN (Number) Keypad Board.......... 100% ok |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
C905 keypad problem | mobileshop-andy | Sony Ericsson Hardware Repair | 5 | 11-13-2010 08:25 |
C905 strange problem | R.I.P. | Sony Ericsson Hardware Repair | 6 | 08-09-2010 12:50 |
c905 speeker problem 100% solve | ^^^RAVI SOOD^^^ | Sony Ericsson Hardware Repair | 3 | 11-05-2009 12:59 |
c905 charging problems - battery drains quickly | wichi850262 | Sony Ericsson Hardware Repair | 1 | 08-28-2009 12:27 |
