Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 04-19-2005, 06:11   #1 (permalink)
Cheater -Don't Deal with him-
Member: 78619
Thanks Meter: 297
k700i joy stick
dear bro i have k700i whos joy stick doesnot work downwords(that is yes button) all right left up and down work fine anybody have schematic or joy stick ways????????
The Following User Says Thank You to uqbah For This Useful Post:
Old 04-21-2005, 04:51   #2 (permalink)
klair_di_sardari's Avatar
Member: 101657
Thanks Meter: 10
i am also having same problem with my k700i, my left joystick doesn't work.
help me.
The Following User Says Thank You to klair_di_sardari For This Useful Post:
Old 04-21-2005, 11:43   #3 (permalink)
Member: 96796
Thanks Meter: 2
I'm also having this problem on my 2 k700i I search for solution too.
I was said it was software but i tried to flash and it didnt change.
The Following User Says Thank You to toocool For This Useful Post:
Old 04-22-2005, 08:00   #4 (permalink)
Member: 23909
I had the same problem, and replaced it from T68i and it working now!
The Following User Says Thank You to dragc For This Useful Post:
Old 05-13-2005, 13:19   #5 (permalink)
Member: 101657
Thanks Meter: 10
hey dragc,
hav u changer ur k700i joystick with t68i.
Plzz tell me clearly.
Thanks
Old 05-13-2005, 21:00   #6 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
1.you can try flashing your phone to release, the joy stick from functioning.
2. you can replace, if you can.
try this ......
bestman
The Following User Says Thank You to bestman For This Useful Post:
Old 05-14-2005, 04:01   #7 (permalink)
Member: 101657
Thanks Meter: 10
thanks bestman,
I think that is hardware problem,
I will have to replace my k700i joystick with newer one.
Bye.
Old 05-14-2005, 08:20   #8 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
Thanks Meter: 143
First try sw if nt work then ...first thing is clean ur joyestick with CTC liquaid....if again no resultsss then check trackssss and linksss of joye stick...all ok ....at last change it with new good one....u got solution.....
The Following User Says Thank You to irfaN_vu For This Useful Post:
Old 05-31-2005, 09:28   #9 (permalink)
Member: 133247
a very easy solution is to remove the housing and clean off dirt near the joystick and under it.
The Following User Says Thank You to dreamzboy For This Useful Post:
Old 08-04-2005, 06:34   #10 (permalink)
Member: 62016
Thanks Meter: 48
can any one give jumper or track for joystick of K700i
The Following User Says Thank You to jignesh_1000 For This Useful Post:
Old 08-13-2006, 10:35   #11 (permalink)
Member: 241231
Thanks Meter: 16
i have also a problem in joy stick k700i all the terminal are gone and remove can any one help me in this problem thanks
The Following User Says Thank You to invert For This Useful Post:
SE k300i or for all SE joy stick desolding problem SA-Abbas Sony Ericsson Hardware Repair 8 02-13-2007 00:19
k500i joy stick & key pad malfunction g_works Sony Ericsson Hardware Repair 8 08-23-2006 11:46
Help:6600 joy stick not on work sheikhje Nokia Hardware & Hardware Repair 5 03-01-2006 05:29
k700i joy stick fanbang Sony Ericsson Hardware Repair 0 01-10-2006 18:25
T68 All Keys and joy stick not working kazwork Sony Ericsson Hardware Repair 3 08-21-2004 14:42
Page generated in 0.31613 seconds with 9 queries
