11-26-2007, 16:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Pakistan
Member: 49285 Status: Offline Thanks Meter: 51 | clip communication failed at 72% flashing three times |
11-26-2007, 16:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ kamransohail786, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. LPT port settings are set to EPP in BIOS 3. Your LPT cable works properly 4. You use a stable power supply with your clip (use power adapter 12V 750mA) 5. If you are using WinXP, log in as Administrator or any other account with administrative rights 6. Fully cahrge the battery. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-27-2007, 07:46 | #5 (permalink) | |
Member: 49285 Status: Offline Thanks Meter: 51 | Quote:
11-27-2007, 08:21 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ kamransohail786, U6 with the boot version 8.A1 supported for unlock\flashing procedures via Prepare cycle. In case if your handset has boot version 8.A1, try to perform Repair PDS and Full Flash procedures via Prepare cycle. In case if some error will appear, post log file without serial numbers. P.S. I have posted that reply, because "Clip communication Error" appears in case if the connection between Smart-Clip and the handset not stable. Those settings should be checked. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-02-2007, 15:47 | #7 (permalink) |
Freak Poster Join Date: Oct 2005 Location: GSM FREE SHOP Age: 44
Member: 190172 Status: Offline Thanks Meter: 45 | i have the same probleme with L6 sottpoed always at 68% on flashe procedure i have Good communication in LPT , Full battery charge , and i use the lastest update , I flashed many Moto today without probleme but this L6 stopped always in 68 % five times now need sollution best regards |
12-02-2007, 16:11 | #8 (permalink) |
Member: 190172 Status: Offline Thanks Meter: 45 | ////////////////////////////////////////////////////////////////////// Last edited by GSM_Support; 12-03-2007 at 09:02. Reason: Contained serial number |
12-03-2007, 09:04 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | To all users. Please remember to keep Smart-Clip serial number in secret at all times. The serial can be only posted to Smart-Clip support team via e-mail or Private message. Please be aware that all serials that are posted at any public forum will be immediately blocked for good. There will be no return for the blocked Clip. It will never become functional again. Best Regards GSMServer team |
Clip communication failed at 78%when flashing moto v80 | djouaka | Smart-Clip | 1 | 07-18-2007 08:23 |
smart-clip team; clip communication fail during v3 pds repair | GOODNESS | Smart-Clip | 2 | 08-17-2006 10:39 |
clip communication failed while flashing !!!! | bayleaf | Smart-Clip | 1 | 12-22-2005 23:50 |
reading flash id..clip communication failed | GuilleB | Smart-Clip | 10 | 11-23-2005 13:47 |
Motorola C350 smart-clip " clip communication failed | jamsab18 | Smart-Clip | 6 | 01-24-2005 23:58 |
