03-05-2009, 04:31 | #1 (permalink) |
Insane Poster Join Date: Nov 2006 Location: http://forum.gsmhosting.com
Member: 397097 Status: Offline Thanks Meter: 11 | Help V3r cant flash motorola v3r with power no display can acces bootloder flash via tp here logs Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... 0x90 - 0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 82089FF3AD3E6F5 IMEI OTP status: locked try repair pds logs Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 82089FF3AD3E6F5 IMEI OTP status: locked Error: "Repair PDS" unavailable due to incomplete chip identification please advise is flash chip damaged? thank you... |
03-05-2009, 09:15 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | "Reading flash id... 0x0090-0x0090" means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly - just to make sure please, repeat the tp procedure. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
help????i cant flash k800??? | peter829 | SETool2 | 1 | 04-21-2009 21:50 |
help i cant flash e398 | guilletelcom | Motorola P2k | 0 | 10-21-2007 04:16 |
help V3r repair/flash/unlock - but ON with 'flash mode' displayed | chris2007 | Smart-Clip | 17 | 02-28-2007 20:21 |
help V3r repair/flash/unlock - but ON with 'flash mode' displayed | ktele | Smart-Clip | 14 | 12-10-2006 11:40 |
help!! help!! help!! i cant flash anymore!! | ryumahon | Smart-Clip | 1 | 09-27-2005 16:27 |
