Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 11-29-2006, 20:10   #1 (permalink)
Member: 169579
Thanks Meter: 10
help V3r repair/flash/unlock - but ON with 'flash mode' displayed
A customer came with a V3 phone as indicated on the label, but when tried to unlock, when open seal to access test point, the layout of the components in the area for test point are of same as V3r.
So I tried with Mototool v1.2.9, to check, and of course it is not really V3, 'made in china' phone.
So my staff tried to unlock it with V3r selected via test point and thewy received a result
"this firmware version is not supported...",
then they try PDS repair, then flash, then unlock done, BUT the problem now is, when turn mobile on, it displayed in 'flash mode' with this message:
"Boot Loader
0A.30
SW Version:
R4515_G_08.BD.20I_GNPO_1_RFDI
OK to Program
Connect USB Data Cable"
Pls help me to solve this, give steps to restore this V3 new firmware, components layout as V3r, to fix and back to normal.
hear support from anyone.
//start of result 1
SmartMoto 1.23
Clip serial: xxxxxxxxx, version: 2.26, initializing... OK
Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.00
Reading flash id... ST-M30L0R8000B0
Reading flash id/2... OK, none
Phone group: V235,V360,V360v,V3i,V3r,L7,L7v
Hardware IMEI: 352509016099552
Security area saved to "S Blank Neptune LTE2 352509016099552 (1).pds"
Login request... OK
Writing section0 done
Writing section1 done
Restarting phone... OK
Repair PDS request... OK
Performing PDS repair... OK
Please write a corresponding Full_flash file to phone to accomplish repair
Security error, make sure clip is properly connected and powered
Login request... OK
Preparing... clip communication failed
//end of result 1
//start of result 2
Security area saved to "S Blank Neptune LTE2 352509016099552 (2).pds"
Login request... OK
Writing section1 730800/1FE0000... 22% 39.9 Kb/sec io timeout
Preparing... io timeout
Login request... OK
Security area saved to "S Blank Neptune LTE2 352509016099552 (3).pds"
Login request... OK
Flash completed!
Unlocking phone... OK
//end of result 2
hear support pls.
Old 11-29-2006, 23:19   #2 (permalink)
Member: 374714
Thanks Meter: 9
with usp smart or anather box
Old 11-30-2006, 16:34   #3 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
can u not see his screenshot???? he try it with smaartclip///...any way 2 ur problem i will check it ...and post results ..cos i got similar fone at hands
Old 11-30-2006, 18:47   #4 (permalink)
Member: 169579
Thanks Meter: 10
its smart clip, but its a V3 brought from USA, but components layout where TP is located are of V3r, not V3. Thats why I used V3r to unlock it, then firmware not supported, then pds repair, then flash, but appears as in Flash mode.
why? how to solve this?
i really need support on this.
Old 12-01-2006, 09:03   #5 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ ktele,
what boot and firmware versions the phone originally had?
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 12-01-2006, 10:42   #6 (permalink)
Member: 169579
Thanks Meter: 10
Originally Posted by Mr.Tinkertrain View Post
@ ktele,
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
here it is, as booted with Mototools v.1.2.9:
1 phone connected...
Open ok...
MSN: 18100CC00B0F092B193C1841B945
BOOT version: 000A30
SW version string: R4515_G_08.BD.20I_GNPO_1_RFDI
Flex version string: GMTV3xx050AA05A
Code group versions:
CG 0x00: 08BD
CG 0x01: 08BD
CG 0x03: 08BD
CG 0x04: 08BD
CG 0x06: 0002
CG 0x0F: 00B1
CG 0x12: 08BD
Check mobile selection before action...
Old 12-01-2006, 10:48   #7 (permalink)
Member: 229997
Thanks Meter: 636
@ ktele,
With what firmware version you flashed it?
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 12-01-2006, 18:08   #8 (permalink)
Member: 169579
Thanks Meter: 10
@ ktele,
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Sir, it was:
V3r_R4515_G_08.BD.44R_lp002E_full_flash
thanks for your kind support. hear solution from u soon.
Old 12-03-2006, 00:45   #9 (permalink)
eddiŽ's Avatar
Member: 10776
Thanks Meter: 240
"Boot Loader
0A.30
SW Version:
OK to Program
//start of result 1
SmartMoto 1.23
Login request... OK
Login request... OK
//end of result 1
//start of result 2
Login request... OK
Login request... OK
Login request... OK
Flash completed!
//end of result 2
hear support pls.
I have same problem with moto v3r
"Boot Loader
0A.30
SW Version:
OK to Program
Smart-clip CAN'T repair it
Old 12-03-2006, 02:58   #10 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
)2@ktele ur fone can not repaired with smaartclip ....if caan wait a bitt u will laugh with smaart team...just wait ....at @edi replaash ur fone aafter repaairs pds much fix ur problem ...regards
Old 12-03-2006, 03:14   #11 (permalink)
eddiŽ's Avatar
Member: 10776
Thanks Meter: 240
I'am reflash more times v3r with full flash PDS repair ok success with(smart-clip) and NOTHING v3r dead and show on display only boot loader and SW.
Old 12-03-2006, 22:47   #12 (permalink)
Member: 169579
Thanks Meter: 10
so it means, smart-clip is starting to die? cant support and fix the above problem?
@ Eddie, could u pls clarify what u meant for? I able to PDS repair the V3r, but how did u fix the problem with 'flash-mode display' on v3r?
Old 12-09-2006, 14:58   #13 (permalink)
GSM_N4H's Avatar
Member: 211652
Thanks Meter: 120
i have the same Proble like Ktele
but theset is V3i (tune)
"Boot Loader
0A.30
SW Version:
R4515_G_08.BD.2AR2
Old 12-10-2006, 02:09   #14 (permalink)
dipu's Avatar
Member: 177730
Thanks Meter: 11
I got it, GOT it, i have same problem. customer broght same problem like you and i tried to flash the phone as v3r and flashing stop at 12% with clip commuincation failed message. phone can connect to smartclip with tp method or without tp method even without battery or external power. i can make pds repair, unlock but not full flash. the phone sw version was R4515. am trying to flash lower version and lower boot version. I have opned one thread about it. mr.tinkertrain told tp shortened.but that was not the case. tp was good.
Old 12-10-2006, 11:40   #15 (permalink)
GSM_N4H's Avatar
Member: 211652
Thanks Meter: 120
i serach many time but didn`t find any soulation yet
Help Nokia 3310 Flash Ok But Not Power On sofiame2006 Nokia Hardware & Hardware Repair 20 01-28-2011 14:36
Repair For v3r r4515 repair pds only 'flash mode' displayed xiaoyuz Smart-Clip 30 09-21-2010 07:16
after v3r repair/full_flash/unlock done...no display chris2007 Smart-Clip 0 03-22-2007 05:20
help V3r repair/flash/unlock - but ON with 'flash mode' displayed chris2007 Smart-Clip 17 02-28-2007 20:21
how to fix 'flash mode' display on v3r LCD? ktele Smart-Clip 4 02-04-2007 14:08
Page generated in 0.28235 seconds with 9 queries
