11-29-2006, 20:10 | #1 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 169579 Status: Offline Thanks Meter: 10 | help V3r repair/flash/unlock - but ON with 'flash mode' displayed So I tried with Mototool v1.2.9, to check, and of course it is not really V3, 'made in china' phone. So my staff tried to unlock it with V3r selected via test point and thewy received a result "this firmware version is not supported...", then they try PDS repair, then flash, then unlock done, BUT the problem now is, when turn mobile on, it displayed in 'flash mode' with this message: "Boot Loader 0A.30 SW Version: R4515_G_08.BD.20I_GNPO_1_RFDI OK to Program Connect USB Data Cable" Pls help me to solve this, give steps to restore this V3 new firmware, components layout as V3r, to fix and back to normal. hear support from anyone. //start of result 1 SmartMoto 1.23 Clip serial: xxxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, none Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 352509016099552 Security area saved to "S Blank Neptune LTE2 352509016099552 (1).pds" Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Security error, make sure clip is properly connected and powered Login request... OK Preparing... clip communication failed //end of result 1 //start of result 2 Clip serial: xxxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, none Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 352509016099552 Security area saved to "S Blank Neptune LTE2 352509016099552 (2).pds" Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Writing section1 730800/1FE0000... 22% 39.9 Kb/sec io timeout Preparing... io timeout Preparing... io timeout Preparing... io timeout Login request... OK Preparing... io timeout Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, none Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 352509016099552 Security area saved to "S Blank Neptune LTE2 352509016099552 (3).pds" Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Writing section1 done Flash completed! Unlocking phone... OK //end of result 2 hear support pls. |
11-30-2006, 16:34 | #3 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | can u not see his screenshot???? he try it with smaartclip///...any way 2 ur problem i will check it ...and post results ..cos i got similar fone at hands |
11-30-2006, 18:47 | #4 (permalink) |
Member: 169579 Status: Offline Thanks Meter: 10 | its smart clip, but its a V3 brought from USA, but components layout where TP is located are of V3r, not V3. Thats why I used V3r to unlock it, then firmware not supported, then pds repair, then flash, but appears as in Flash mode. why? how to solve this? i really need support on this. |
12-01-2006, 09:03 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ ktele, what boot and firmware versions the phone originally had? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-01-2006, 10:42 | #6 (permalink) | |
Member: 169579 Status: Offline Thanks Meter: 10 | Quote:
1 phone connected... Open ok... MSN: 18100CC00B0F092B193C1841B945 BOOT version: 000A30 SW version string: R4515_G_08.BD.20I_GNPO_1_RFDI Flex version string: GMTV3xx050AA05A Code group versions: CG 0x00: 08BD CG 0x01: 08BD CG 0x03: 08BD CG 0x04: 08BD CG 0x06: 0002 CG 0x0F: 00B1 CG 0x12: 08BD ***************** Check mobile selection before action... | |
12-01-2006, 10:48 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ktele, With what firmware version you flashed it? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-01-2006, 18:08 | #8 (permalink) | |
V3r_R4515_G_08.BD.44R_lp002E_full_flash thanks for your kind support. hear solution from u soon. | |
12-03-2006, 00:45 | #9 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 52
Member: 10776 Status: Offline Thanks Meter: 240 | Quote:
I have same problem with moto v3r "Boot Loader 0A.30 SW Version: R4515_G_08.BD.20I_GNPO_1_RFDI OK to Program Connect USB Data Cable" Smart-clip CAN'T repair it | |
12-03-2006, 02:58 | #10 (permalink) |
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | )2@ktele ur fone can not repaired with smaartclip ....if caan wait a bitt u will laugh with smaart team...just wait ....at @edi replaash ur fone aafter repaairs pds much fix ur problem ...regards |
12-03-2006, 03:14 | #11 (permalink) |
Member: 10776 Status: Offline Thanks Meter: 240 | I'am reflash more times v3r with full flash PDS repair ok success with(smart-clip) and NOTHING v3r dead and show on display only boot loader and SW. |
12-03-2006, 22:47 | #12 (permalink) | |
@ Eddie, could u pls clarify what u meant for? I able to PDS repair the V3r, but how did u fix the problem with 'flash-mode display' on v3r? | |
12-10-2006, 02:09 | #14 (permalink) |
No Life Poster Join Date: Sep 2005 Location: manchester, uk
Member: 177730 Status: Offline Thanks Meter: 11 | I got it, GOT it, i have same problem. customer broght same problem like you and i tried to flash the phone as v3r and flashing stop at 12% with clip commuincation failed message. phone can connect to smartclip with tp method or without tp method even without battery or external power. i can make pds repair, unlock but not full flash. the phone sw version was R4515. am trying to flash lower version and lower boot version. I have opned one thread about it. mr.tinkertrain told tp shortened.but that was not the case. tp was good. |
Help Nokia 3310 Flash Ok But Not Power On | sofiame2006 | Nokia Hardware & Hardware Repair | 20 | 01-28-2011 14:36 |
Repair For v3r r4515 repair pds only 'flash mode' displayed | xiaoyuz | Smart-Clip | 30 | 09-21-2010 07:16 |
after v3r repair/full_flash/unlock done...no display | chris2007 | Smart-Clip | 0 | 03-22-2007 05:20 |
help V3r repair/flash/unlock - but ON with 'flash mode' displayed | chris2007 | Smart-Clip | 17 | 02-28-2007 20:21 |
how to fix 'flash mode' display on v3r LCD? | ktele | Smart-Clip | 4 | 02-04-2007 14:08 |
