02-23-2009, 17:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Java Age: 46
Member: 166000 Status: Offline Thanks Meter: 26 | V3x dead dear, got V3x dead, phone could connect with Scout or Smart Clip but no firmware or flex shown. Scout only show that phone bootloader is 3.10 The problem i'm confused which firmware must i used R25221LD, R26111LD or R26117LD, is there way to know which one is correct? or solution for this problem? Thanx. Last edited by y2y; 02-23-2009 at 17:45. |
02-24-2009, 09:13 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | Please find out what has previously happened to the phone, so it got to this state? Also, how does it get detected by SmartMoto? Please show the log file without serials. What is written on phone's screen when you try to power it ON? In order to have an idea what was the original fw version, please check the sticker under the battery. It usually it states the fw version. Best Regards GSMServer team |
02-26-2009, 02:42 | #3 (permalink) |
Member: 166000 Status: Offline Thanks Meter: 26 | problem for me, i don't know condition previously and how can be that state. phone shows nothing at display or keypad, looks like phone enter bootloader mode when battery inserted. try with scout flasher 1.16, scout show message need " ROM Superflash " here's log when do search and flashing with smart-clip use firmware RAZRV3x_R252211LD-AS_U_85.9B.D0R_lp0024_full_flash.mfw after that nothing changed. SmartMoto 3.18 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 352240013xxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 352240013xxxxxx (2).mbk" Writing flash section 2 of 2... 100% (87.2 Kb/sec) Flash completed! About original fw version, did u mean sticker at board that contain IMEI or sticker at behind battery? i don't know code at sticker board that show original fw version, i only see number like this : IMEI xxxxxxxxxxxxxxxxxxxxxx D67WHB2RHV MUT4 - 4411J11 T677 AS RAZR V3X FCC ID : BD_ADDR : 001 ADB34032E which one show ? Thanx for response |
02-26-2009, 09:36 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | Well, unfortunately the fw version is not specified on the sticker... Anyway, try performing Repair PDS, full flash with the same fw version, as you used, and right after flashing (don't disconnect the phone) apply IMEI Repair Firmware Patch. Inform me on result, please. Best Regards GSMServer team |
02-27-2009, 13:42 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi Ask your customer what the service provider of the phone is ...like Orange..Vodafone ..Amena ..etc ,as that may also provide a path to what the orig firmware was. It may also be printed on the phone housing...or maybe if the customer remembers how the phone booted up with its intro screen when it was in working state Something else to try....disconnect the display flex and power on...see what SmartMoto can find And something else...check that the TP resistor (must show a short of 0 ohms) is OK...if not ..solder a jumper to both points. Good Luck. ,smokin |
03-02-2009, 14:37 | #6 (permalink) |
Member: 166000 Status: Offline Thanks Meter: 26 | Here's my log when try repair PDS SmartMoto 3.18 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx, version: 4.08, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 3522400xxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 3522400xxxxxxxx (3).mbk" Login request... OK Writing flash section 2 of 2... 100% (108 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (27.9 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 24% (48.2 Kb/sec) clip communication failed Preparing... clip communication failed try to re-flash and search phone always show " phone not found " what should i do now? do need test point again when try to reflash after repair PDS completed ? thanx for response |
03-03-2009, 08:34 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | |
03-03-2009, 15:55 | #8 (permalink) | |
Member: 166000 Status: Offline Thanks Meter: 26 | Quote: when check again, seems phone can go to blank mode after switch press on now ( before repair pds, phone go to blank mode when cable power is attached ). flashing can completed after i check " use slower speed " but still can't alive. customer said that handset have vodafone branded before, what firmware i should choose for handset ? thanx for response | |
03-02-2009, 14:50 | #9 (permalink) | |
i check the TP resistor show about 30 ohm not 0 ohm. after repair pds, phone stop flashing at 24%, phone is dead now, ok i'll try jumper both points to ground like u said and post the result. | |
03-02-2009, 15:00 | #10 (permalink) |
Member: 88701 Status: Offline Thanks Meter: 381 | I did not say jump to GND ! Quote .. solder a jumper to both points You can solder a jumper over both connection points of the testpoint resistor. ,smokin |
03-04-2009, 18:32 | #13 (permalink) |
Member: 166000 Status: Offline Thanks Meter: 26 | Here's my log when repair pds again and tried to repair imei but got failed: Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 3522400xxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 3522400xxxxxxxx (1).mbk" connecting to server... cannot connect to the server Preparing... error A9 Turning phone off... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Boot version 0x310 is not supported for model 'V3x' Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 3522400xxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 3522400xxxxxxxx (2).mbk" Login request... OK Writing flash section 2 of 2... 100% (122 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (26.8 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (55.7 Kb/sec) Turning phone off... OK Flash completed! Connect phone to Smart-Clip before proceeding Connect phone to Smart-Clip before proceeding Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Phone is not in flash mode. Please enter flash mode before patching the phone. This can be done by pressing 'Enter flash mode' button on 'Flash' tab (for old boots only!). For newer boots, use 'Prepare phone' operation or TestPoint method. Reading phone boot version... 3.10 Reading flash id... AMD - S71WS512NE0 (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 3522400xxxxxxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 3522400xxxxxxxx (3).mbk" Preparing... error A9 i check " overwrite bootcore area " seems nothing change with phone boot version, tried to do " imei firmware patch " and get " error A9 ". is this sw or hw problem? |
03-05-2009, 08:59 | #15 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | In case of getting Error A9 during "imei firmware patch" means you connect the phone in Flash Mode instead of Powered ON state. Please repeat procedure once again with Power On handset. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
V3X DEAD AFTER UNLOCK only keypad blynks | ventoinhas | Motorola P2k | 2 | 05-29-2006 15:04 |
V3x dead after unlock | gsmsupport.net | Motorola P2K (USB-Smart) | 16 | 04-29-2006 18:37 |
v3x dead | teddeca | Motorola P2k | 0 | 04-22-2006 17:20 |
V3x dead | tikal | Smart-Clip | 6 | 03-16-2006 00:31 |
v3x dead after unloking | CherieCom | Smart-Clip | 3 | 02-20-2006 18:28 |
