06-21-2006, 08:17 | #16 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
Only posted here to warn off others from trying with this bootloader version. I should have known it would not work as I'd previously tried with victor mss4 and got program freeze when connected to server with this model. | |
06-21-2006, 21:14 | #17 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: URL - UnlockRepairLandia Age: 41
Member: 236218 Status: Offline Thanks Meter: 35 | Quote:
06-21-2006, 22:22 | #18 (permalink) | |
06-23-2006, 01:44 | #19 (permalink) |
Member: 236218 Status: Offline Thanks Meter: 35 | My SC working, when I connect phone, smartmoto says - unlock RSA is need for this phone, and phone connected to clip without tp now, maybe damaged boot??? Downgrade boot is not possible and IMEI is damaged How to do now? m. f. |
06-23-2006, 08:13 | #20 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mail0, what Boot and Firmware the phone originaly had? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 06-23-2006 at 15:21. |
06-23-2006, 15:05 | #21 (permalink) | |
SW R245_U_82.21.80I Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.36 Reading bus width... OK Reading flash id... 0x006C-0x00B1 (x2) Phone group: A835,A845,A920,A925 Reading OTP... error B8 Warning: OTP read failed Unlocking phone... error A0 After this, when I connect phone, smartmoto says - unlock RSA is need for this phone, and phone connected to clip without tp now, maybe damaged boot??? Downgrade boot is not possible and IMEI is damaged. When I power on, phone is switching in flash mode. How to do now? m. f. | |
06-23-2006, 15:22 | #22 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mail0, Reading flash id... 0x006C-0x00B1 means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-25-2006, 22:22 | #26 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | @ Mr.Tinkertrain Will try to write that boot that SC team says and see what happens. @ Afzaal Oh my *** :O..... there is barely space to move and solder well the TP let alone how to fix it that way . The main IC has to be removed to rebuild that line which is really hard to do damn |
06-26-2006, 04:47 | #27 (permalink) |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Yep Dude i m aware of this C975 thing dats y i said " if u can Do it." i Know its hella hard to Perform such action But for the sake of ur cell life u have to do it. if u want it / Not anyways Luck. BR |
06-29-2006, 16:40 | #28 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | @Afzaal and mates tried to flash the boot file as mentioned on smart clip site and am getting this .... (nothing looks good). This time the test point is 100% ok. Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... unable to retrieve flash id Reading OTP... error B8 Warning: OTP read failed Incomplete chip identification, restore & write functions unavailable anything else i can do (excpet trash it) ? thanks mate |
06-30-2006, 08:17 | #29 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Burnt Cobba, Flash chip can't be read. Most probably it is a hardware malfunction. Please check the mainboard of the phone. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
07-08-2006, 20:27 | #30 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Pluto Age: 44
Member: 135688 Status: Offline Thanks Meter: 1 | please can flashing fix the problem software not found B.L 0.6.3.6 SW R245_U_82.21.80I please need link to where i can download this version pls. guys BIGDADA |
how to unlock c975 motorola | prem2007 | Smart-Clip | 2 | 03-22-2008 09:11 |
help how to unlock c975 with smart moto | ARAB GSM | Smart-Clip | 3 | 12-19-2005 16:00 |
Here how to unlock C975 | vicky_ocean | Smart-Clip | 0 | 07-26-2005 03:06 |
