12-12-2007, 05:29 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: bacoor cavite Age: 42
Member: 375209 Status: Offline Thanks Meter: 14 | k3 moto succes unlock removing emecon thanks to gsm server,,,,and lord guide me to remove emecon SmartMoto 2.45 S-Card: 107****** Smart-Clip dongle, v 1.52, assigned Smart-Clip: 923***** Europe, initializing... OK Clip serial: 923*******, version: 3.25, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.10 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S29WS512P Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 355848010****** IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 35584801******.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_18A3080844B6D051.bk_ Restore OK Unlocking phone... OK make work safe removing emecon....... |
12-12-2007, 16:45 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Location: PH Age: 47
Member: 167930 Status: Offline Thanks Meter: 5 | make work safe removing emecon.......so how did you do that for us to succeed like you ,dont post logs your procedure on how to remove safely is better to post... |
02-23-2017, 11:21 | #5 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | moto k3 unlock hi, can please tell me did you remove any glue or surrounding adhesive at test point location ? i cant seem to connect to testpoint usb cable connected ok (to smclip) red wire going to + battery connector testpoint A wire (yellow) black wire = nothing connected am i do something wrong , thanks |
k3 dead during unlock | salama10 | Smart-Clip | 9 | 07-19-2009 09:45 |
E75 unlock error at the finish but Succes Unlock The phone | ServiceTEL | Universalbox | 0 | 05-12-2009 17:37 |
Succeful unlock L6 without tp | EMINEMGSM | Motorola P2k | 7 | 02-17-2009 18:19 |
