02-28-2009, 04:54 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 897798 Status: Offline Thanks Meter: 0 | Two SC with the same problem Help Smart-Clip update software 3.04 Warning: make sure you use power adapter! Reading clip info... Auto searching clip... Looking for clip on Smart Adaptor... OK Clip serial: xxxxxxxx Firmware not found Auto searching clip... Looking for clip on Smart Adaptor... OK Clip serial: xxxxxxxx Firmware not found login... denied European market Smart-Clip Clip warranty period: 10-Dec-2008 to 08-Jun-2009 (100 more days) EEPROM test successfull,reporting... OK Checking dongle... OK Smart-Clip dongle found, serial xxxxxxxxxxxx Update denied, save log and contact support the other says the same.... Last edited by GSM_Support; 02-28-2009 at 10:07. |
02-28-2009, 10:12 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Dear Customers, Considering our experience with updates we wanted to lay out some additional advices for update of your clips When you update make sure that: - firewall on your computer is disabled - you have good internet connection - LPT port settings are set to EPP in BIOS - you have a stable power supply to your clip (use adapter) - your IE version is not lower than v5.0 - if you use Win XP, log in as administrator - if you use Win XP please launch the SmartMoto tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. In case of still having difficulties while updating, please save a log file of the process and email immediately to support[at]smart-clip.com Best Regards GSMServer team Last edited by GSM_Support; 02-28-2009 at 10:23. |
the same problem with two 6230i help | bronks | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 03-13-2007 22:02 |
Two E398 dead, both of them have the same problem!!!! Pls help me | ..::Thanh_gsm::.. | Motorola P2k | 4 | 10-09-2006 04:39 |
The same problem,help pls ! | Shop RU | Panasonic | 0 | 08-12-2002 02:33 |
I have seen hundreds of Nok3210 with the same problems! let's discuss it! | sat | Nokia Hardware & Hardware Repair | 16 | 10-14-2001 21:27 |
