01-02-2007, 15:10 | #346 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 217328 Status: Offline Thanks Meter: 2 | Remove flash card from phone before unlocking The following models can be served avoiding a TestPoint connection: Model Boot version C975 6.36 C975 (fw … 91i) unlock procedureBefore starting the unlock procedure, please check the boot version of the phone. Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC). Connect S-Card to PC USB port. Connect power supply to Smart-Clip and power on the handset. Launch SmartMoto. Choose "Smart-Clip USB port" in phone connection window. Press "Search". Software should perform the following steps: SmartMoto detects S-Card; SmartMoto detects Smart-Clip; SmartMoto detects the handset and reads all information. Log to bookmark "Prepare". Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list. For unlock purposes, please make sure that "Unlock automatically" option is marked. Press "Prepare" button. The prepare cycle starts. SmartMoto creates a Temporary Backup File* from the handset firmware. For some models, SmartMoto will popup the following instruction to be performed: Remove phone’s battery; Insert battery back; Press power ON; Press ok in SmartMoto; The handset should be detected by SmartMoto as "S Blank..." SmartMoto restores the temporary backup file. Log to bookmark "Unlock". Pickup correct model from the scrolling list. Press "Remove RSA". Phone goes into boot mode. Reserve copy of security area is created. Part of phone firmware is reflashed. Phone doesn't power on after that. SmartMoto will give the message requiring to take phone into boot mode by pressing keys combination: *,#, PWR ON (at this moment the phone has to be connected with USB cable). Press "OK" button. Wait till the process finishes. Log to "Flash" tab. Press "Enter flash mode". The phone enters a flash mode (continue with the step 14, please). P.S. Alternatively, the handset can be connected using a TestPoint method. After that log to bookmark "Flash", press "Enter flash mode" and continue with the step 14. Log to bookmark "Unlock". Press "Unlock via patch" button. Wait for the process to complete. Phone is unlocked. NOTE Please, don’t use a "Forced boot mode cable" for unlock procedure, provided above. |
01-02-2007, 18:05 | #347 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
Paste link here i will translate it for u anyways Now GOT SC both r doing great job... BR. | |
01-02-2007, 20:07 | #348 (permalink) |
Junior Member Join Date: Oct 2006
Member: 375282 Status: Offline Thanks Meter: 0 | hehehe so this solution is on that forum;P hehehe I dont read this forum only this topic;-) I can only confirm that this solution works. This topic can now be closed. bye guys |
c975 Boot Loader 0.6.3.6 SW Version :R245_U_82.21.91I unlocking | mohit gulati | Motorola P2k | 8 | 12-21-2006 17:47 |
working solution for C975 boot loader 0.5.f.1,sw version not found | GOODNESS | Motorola P2k | 1 | 12-20-2006 21:24 |
C975 Boot Loader 0.6.3.6 SW Version :R245_U_82.21.91I | GOODNESS | Smart-Clip | 10 | 12-11-2006 01:00 |
C975 Boot Loader 0.6.3.6 SW Version :R245_U_82.21.91I is still not supported | irfan99 | Smart-Clip | 0 | 12-04-2006 18:08 |
UNLOCK C975 Boot Loader 0.6.3.6 SW Version :R245_U_82.21.91I | .::Zafar Communication::. | Main Sales Section | 0 | 07-24-2006 09:22 |
