02-14-2009, 04:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: iOS4
Member: 527421 Status: Offline Thanks Meter: 43 | w490 3 days unlocking a PROBLEM then i decided to flash in scout ..what is this problem,,,originally locked in T-mobile |
02-14-2009, 11:07 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | The handset has a hardware problem. More likely the flash chip is damaged. Best Regards GSMServer team |
02-16-2009, 04:25 | #3 (permalink) | |
Member: 527421 Status: Offline Thanks Meter: 43 | Quote:
02-17-2009, 03:22 | #5 (permalink) | |
Member: 527421 Status: Offline Thanks Meter: 43 | Quote: | |
02-17-2009, 09:50 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Not sure you can change the flash chip on this particular model. Try reheating it. See if it helps. Best Regards GSMServer team |
02-23-2009, 08:44 | #7 (permalink) | |
ive found out that the the two resistor in TP1 are an open circuit,,,my problem is what value of that resistor??? the resistor at TP2 when i tester and removed it likes an inductor it has a 0 ohms resistance.. thats why ill cant unlock because of that value...my question is WHAT was THAT VALUE..at TP1 and TP2 HELP... | |
Nokia At&T unlock codes 1-3 days 90% 5 days max | gsmlocksez | Wanted Products | 2 | 10-22-2009 21:32 |
15 days unlocking w490 success | sed_1982 | Smart-Clip | 7 | 02-24-2009 06:05 |
10 days unlocking w490 a bad move | sed_1982 | Scout | 6 | 02-23-2009 22:17 |
C980M no network after 3 days unlocked | Elioni | Smart-Clip | 2 | 03-24-2006 11:06 |
