Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 11-27-2014, 23:08   #1 (permalink)
Member: 2183370
Thanks Meter: 2
FURIOUS GOLD Pack 12 SM-G901F Unlock Help
Hello,
i have a G901F from UK i need to unlock, i follow the instructions in the Samsung Code Reader (software for pack 12) but i can't seem to get the menu to come up when i type in *#7284#
Phone android version is 4.4.4
When i press read info i get OK when BUILD INFO, BRAND, MODEL and VERSIONS but error at IMEI, BLUETOOTH INFO and MSL
Please help
Thanks in advance
Old 11-28-2014, 14:04   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,572
See SAMSUNG_G800x_G850x_G901F_UART_enable.jpg from support for the uart enable
Old 11-28-2014, 21:54   #3 (permalink)
Member: 2183370
Thanks Meter: 2
Sorry, i'm a bit dumb, i tried looking for the mentioned jpg in the support (via maintenance) which catergory is it under? also i tried looking for a support button in the code reader app too but still couldnt find it
looking forward to your reply
Old 11-29-2014, 10:56   #4 (permalink)
Member: 15022
Sonork: 100.53452
Must use maintenance, press go support, on the browser windoiws go Downloadable file, PINOUTS section
Old 11-30-2014, 22:19   #5 (permalink)
Member: 2183370
Thanks Meter: 2
Hello,
so i have done as the picture says but still no go on the *#7284# command
after plugging into the UART cable, i insert the battery and device turns on by itself. i then enter the code but no response
Old 12-01-2014, 09:20   #6 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 14,047
will check with coder and come back to you
Old 12-01-2014, 10:33   #7 (permalink)
Member: 15022
Sonork: 100.53452
You dont need to dial anything. Simply power on the phone like this and will work
Old 12-01-2014, 21:55   #8 (permalink)
Member: 2183370
Thanks Meter: 2
So after doing the battery trick, i proceeded to read the phone to see if i get anything
this is the result
this seems to be a false reading when it says "Searching for phone; ok"
any ideas?
Old 12-02-2014, 11:57   #9 (permalink)
Member: 15022
Sonork: 100.53452
If you use the cable from our set replace rx with tx. Some of them come with incorrect pinout so you need to swap the pins
br
Old 12-02-2014, 21:38   #10 (permalink)
Member: 2183370
Thanks Meter: 2
*sigh* i seem to have misplaced the cables that came with the furious gold box, the one i'm using is the one that came with the octoplus box..
is there anything else i can do?
might have to resort to submitting to a server for unlock code and hope it works
Old 12-02-2014, 22:28   #11 (permalink)
Member: 15022
Sonork: 100.53452
no idea of the pinout for that box
Old 12-03-2014, 01:26   #12 (permalink)
Member: 2183370
Thanks Meter: 2
do you guys have a service for this device to get unlock code via imei?
Old 12-03-2014, 08:29   #13 (permalink)
Member: 15022
Sonork: 100.53452
Yes. Go to the REMOTE UNLOCK section of the support area
Old 12-04-2014, 22:32   #14 (permalink)
Member: 2183370
Thanks Meter: 2
Hmm...i tried looking in the samsung section in remote unlock, the model SM-G901F doesnt seem to be in the supported phones list
Still trying to figure out the reason why my phone cannot be read by my computer?
Any ideas?
Old 12-05-2014, 12:11   #15 (permalink)
Member: 15022
Sonork: 100.53452
Any ideas?
You have
Samsung Europe Unlock Codes and this includes all the models. As for the detection im sure its cable fault. try swapping rx with tx
br
Page generated in 0.21249 seconds with 9 queries
