06-23-2014, 13:10 | #11881 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Online Thanks Meter: 580 | Samsung GT-S8300 unlocked ok |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
06-24-2014, 07:59 | #11882 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,006 | Motorola MB200 successfully unlock with Pack 5 Motorola MB200 successfully unlock with Pack 5 Here are logs Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : Jul 1 2010 14:27:00 RELEASE DATE : May 5 2010 02:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805036 IMEI : 356xxxxxxxxxxx-9 BLUETOOTH ADDR : 00 26 BA 90 D1 4C LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 42183763 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. SIM_LOCK REMOVED ! RESET ! |
06-26-2014, 12:34 | #11883 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 45
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | Zte orange tara unlock success MTK CODE READER 1.0.0.472 PORT COM USING GW300 UART PHONE OFF COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: ORA-FR-QB18S-P176A30V1.0.0B07 Hw Version: 11A EASTAEON76W_F120_512256_11A Reading phone info; IMEI: 358044-03-073XXX-X Reading simlock info; Unlock codes: Locked to: 208-01 code_cat_n: 3634136676 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:16 |
The Following User Says Thank You to ali42 For This Useful Post: |
06-26-2014, 16:22 | #11884 (permalink) |
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,006 | Telenor pakiatan Alcatel One Touch 990 Direct unlock Here are logs Software engine version: 1.0.0.8945 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Feb 20 2012 19:51:00 RELEASE DATE : Jun 20 2011 03:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6180 IMEI : 355xxxxxxxxxxxx-2 BLUETOOTH ADDR : 2F 38 CB AC 71 94 DONE; WORKING; SAVED: 728A27E94E451DE90E24684F228E7746.bin DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_26_06_2014_20_12_37.txt Time needed - 00:00:55 |
06-26-2014, 16:23 | #11885 (permalink) |
06-28-2014, 21:58 | #11886 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Tmn 1010 So lets go to the steps. 1 - First of all power on the phone 2 - Plug Furiousgold Box and open Pack 3 Vodafone Infineon Module 3 - Select model 4 - Select COM 5 - Select Job 6 - Conect RJ45 to Box 7 - Press Do Job 8 - It will apear a Info Box 9 - at this time conect the cable to phone and press the power buttom a few times (for me it was just once) And at the same time press enter to close INFO Box 10 After that the process will began automaticaly, and just follow the program instructions. Job Done |
The Following User Says Thank You to Rui Romano For This Useful Post: |
06-29-2014, 18:07 | #11887 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Alcatel OT-5020T Unlock. Code: Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (MTK USB Port) Preparing to start flash mode; Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 4c63598929642ae2112e0b2415441204 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM142; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, 05] HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xBE7F1058 0x8BA078DD [SIZE=0xE9300000] IMEI1 [OTP 0001]: 013778-00-741xxx-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020T-2ATBUS1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9E3B4000 Searching data; Locked to: 310-16 code_cat_n: 11265772 enabled: yes tries: 3 code_cat_ns: 05422011 enabled: no tries: 10 code_cat_sp: 19209352 enabled: no tries: 10 code_cat_c: 41043419 enabled: no tries: 10 code_cat_sim: 38598885 enabled: no tries: 10 code_cat_ns_sp: 13610576 enabled: no tries: 5 code_cat_sim_c: 02129326 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:08 |
The Following 2 Users Say Thank You to asad_nomy7 For This Useful Post: |
06-30-2014, 12:52 | #11888 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1648084 Status: Offline Thanks Meter: 11 | Orange Zilo (not Zali) unlock log Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Rid: 7405fb323b320d8918ee7888a2c67dd1 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM63; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA5010304 0x9BB04A24 [SIZE=0xE9C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x4A940000 SIZE: 0x9F2C0000 Searching data; Locked to: 226-10 code_cat_n: 87189771 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 1122FFFF enabled: no tries: 5 code_cat_c: 3344FFFF enabled: no tries: 5 code_cat_sim: 5566FFFF enabled: no tries: 5 code_cat_ns_sp: 7788FFFF enabled: no tries: 5 code_cat_sim_c: 9900FFFF enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:01:25 |
The Following 2 Users Say Thank You to empirion For This Useful Post: |
06-30-2014, 13:27 | #11889 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,132 | vodafone 785 unlock done Searching phone; Phone detected (@oem148.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM20); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P4 Hw Version: JRDHZ72_WE_VF_JB3_HSPA_HW Reading phone info; IMEI: 359729-05-00000-01 Reading simlock info; Locked to: 234-15 code_cat_n: 05607317 enabled: yes tries: 5 code_cat_ns: 15781903 enabled: no tries: 10 code_cat_sp: 14919068 enabled: no tries: 10 code_cat_c: 15343425 enabled: no tries: 10 code_cat_sim: 07373498 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:02:51 |
07-01-2014, 11:21 | #11890 (permalink) |
Freak Poster Join Date: Aug 2009 Location: DRC
Member: 1105110 Status: Offline Sonork: 02525 Thanks Meter: 13 | Alcatel OT-J320 from Unitel_Angola Unlocked by FG OT-J320 both Sim unlocked by furious gold, Best support for Alcatel android phones and much more |
07-07-2014, 17:25 | #11891 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | unlock sfr 1180 Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem142.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: V05_M131030_UL18_SFR1180_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 359562-05-073601-2 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:50 |
07-08-2014, 13:06 | #11892 (permalink) |
Member: 1648084 Status: Offline Thanks Meter: 11 | Vodafone 527 succes Press power on shortly ... Starting communication ... MCU ID: 26200305566700C20000000000009639 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000283C Algo: 05 Firmware: EVN,PH: 250408 0927 Imei: 351959021348562 Phone code: 0000 Prod. code: 254028126 Id calculation done; CODES: NET LO CODE: 3206721854 NET HI CODE: 4284658046 Done ! Time needed - 00:02:14 |
07-09-2014, 17:18 | #11893 (permalink) |
Freak Poster Join Date: Apr 2006 Location: BG Age: 46
Member: 255473 Status: Offline Thanks Meter: 49 | Lenovo TAB A3000-H unlock ok!!! Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM89); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6589 Sw version: MOLY.WR8.W1248.MD.WG.MP.V5.P8 Hw Version: LENOVO89_TB_TWN_S_JB2_MD1_HSPA_HW Reading phone info; IMEI: 862589-02-88xxxx-x Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:10:05 |
The Following User Says Thank You to jordan_antonov For This Useful Post: |
07-09-2014, 18:55 | #11894 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Alcatel 0t5020n unlock done Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (MTK USB Port) Preparing to start flash mode; Requesting authorization; Connecting; Downloading DA; Initializing; Rid: c6d68e68643c98295f5eebbdc1f6ca62 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM4; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, 05] HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xD91D1058 0x53B043FB [SIZE=0xE9300000] IMEI1 [OTP 0001]: 013912-00-******** IMEI2 [OTP 0001]: 000000-00-******** PROVIDER: 5020N-2AE4US1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9E3B4000 Searching data; Locked to: 219-01 code_cat_n: 02529372 enabled: yes tries: 10 code_cat_ns: 05904893 enabled: no tries: 10 code_cat_sp: 22000794 enabled: yes tries: 10 code_cat_c: 17526186 enabled: no tries: 10 code_cat_sim: 22000207 enabled: no tries: 10 code_cat_ns_sp: 07752794 enabled: no tries: 5 code_cat_sim_c: 19401817 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:15 |
07-09-2014, 22:59 | #11895 (permalink) |
Insane Poster Join Date: Mar 2008 Location: Ecuator QUito
Member: 731820 Status: Offline Sonork: lerouxito Thanks Meter: 236 | Samsung SM-T217A Unlocked OK FG Samsung Module v1.0.2.2 ~ AT&T SM-T217A ~ ~ DIRECT UNLOCK NEW ~ Start at 16:46:07 Please power on phone and connect to usb in android debug mode! If phone ask to allow usb debuging please accept! Searching for phone; ok Reading info; ok Checking root; ok (WAITING) Please grant SUPERUSER ACCESS on phone screen or from phone menu! Checking root; ok (ROOTED) BRAND: SAMSUNG MODEL: SAMSUNG-SM-T217A LT02LTEATT HWID: QCOM-9 BOOT LOADER: T217AUCUAMHC VERSION: ANDROID 4.2.2 BUILD JDQ39 T217AUCUAMHC T217AUCUAMHC T217AATTAMHC (PDA/CSC) FIRMWARE: LT02LTEUC-USER T217AUCUAMHC KERNEL: 3.4.0-1446028 (gcc 4.6.x-google) HARDWARE: REV0.1 PHONE SN: RF2F31ZMP0Z CPU TYPE: MSM8960 ARMv7 Checking if version supported by server; ok IN ANYCASE WHEN PROCESS IS DONE PLEASE VERIFY IF YOUR PHONE IS UNLOCKED AND REPORT TO US ON FORUM! Installing android tool; ok Running android tool; ok Please grant superuser access to android tool if requested! Reading data; ok Sending data to server; ok Calculating [by server] please wait; ok Disconnecting from server; ok Writing data; ok Restarting phone; ok End at 16:52:28 |
The Following User Says Thank You to lerouxito For This Useful Post: |
