03-30-2010, 14:09 | #3512 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Successfully unlock alcatel E230 Press power on ! Starting communication ... Authorisation passed ... Sending boot ... Sending EBOLA ViruS ! Phone infected. RSA Defeated ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Trying baud rate change ... Baud rate changed ok ! FLASH 1 ID: 0001:227E 0A01 MODE: E100/E105/E157/E158/E159/E160/E161 E200/E205/E220/E230/E252/E256/E257 E259/E260/E265/C61/C62 MCU ID: 2E30511FC11502C5 ALGO TYPE: 01 OTP IMEI: 352315011334345 PROVIDER: E230X-2ARGGB1 FW INFO: 92DAE90114 CODES: NCK: 2623359911 RESET: 3793728456 Operation completed. Phone reseted ! Time needed - 00:00:16 |
03-30-2010, 14:28 | #3513 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | t156 cy done here is log Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038040864 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_353081038040864_17.46.01_30. 03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:57 |
03-30-2010, 15:12 | #3514 (permalink) |
Banned Join Date: Mar 2004
Member: 58357 Status: Offline Thanks Meter: 27 | huawei U1000s unlock Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0076 Nand init done; Reading; Imei : 35288802283738-1 Reading; SP saved to: SP_35288802283738_A60_17.10.45_30.03.2010_HUAWEI.b in Erasing; Writing; Unlocked ! Done ! Time needed - 00:00:19 |
03-30-2010, 15:21 | #3515 (permalink) |
Banned Join Date: Nov 2009 Location: @ work Age: 16
Member: 1169642 Status: Offline Sonork: 1587581 Thanks Meter: 234 | ZTE E315 unlocked ok Connect phone powered on ! Start auth ! SW Ver: EF-RW-TIGO-P108E2FM(S)V1.0.0B01 Imei: 352463033116876 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_EF-RW-TIGO-P108E2FM(S)V1.0.0B01_352463033116876_15.24.46_30.0 3.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
03-31-2010, 06:49 | #3516 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Software engine version: 1.0.0.3590 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Oct 22 2007 10:32:00 RELEASE DATE : Jun 13 2007 00:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022T IMEI : 35778101006683-9 BLUETOOTH ADDR : F5 43 3E 40 12 00 MEMORY ID : 00EC:0078 MEMORY NAME : samsung_k91g08 MEMORY INFO : 0200:0020:16BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; UNLOCK CODE: 2272463823 RESET ! Time needed - 00:00:45 |
03-31-2010, 07:57 | #3517 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 8900 Unlock Done Searching for usb device ... Reading info ... IMEI: 355383031814347 Calculating ... MEP: MEP-07723-004 MEP2 CODE: 9512096405115153 MEP3 CODE: 8498586300101140 MEP4 CODE: 5317392633279514 MEP5 CODE: 8488962998870664 MEP6 CODE: 5027579801002253 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:39 |
03-31-2010, 07:59 | #3518 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 8520 Unlock Done searching for usb device ... Reading info ... IMEI: 354879019101863 Calculating ... MEP: MEP-07321-002 MEP2 CODE: 32485628 MEP3 CODE: 08225123 MEP4 CODE: 86708982 MEP5 CODE: 56241711 MEP6 CODE: 55263648 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:39 |
03-31-2010, 08:00 | #3519 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 8100 Unlock Done Searching for usb device ... Reading info ... IMEI: 359484026662190 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 8981399825009065 MEP3 CODE: 7093122576225521 MEP4 CODE: 1994180817632059 MEP5 CODE: 4063883758443381 MEP6 CODE: 4064252642678638 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:54 |
03-31-2010, 09:22 | #3520 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334038143973 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334038143973_13.17.01 _31.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
03-31-2010, 11:39 | #3522 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Sfr unlock by furious gold Quote:
03-31-2010, 11:55 | #3523 (permalink) |
Freak Poster Join Date: Mar 2007 Location: i love pakistan Age: 47
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334099903482 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334099903482_15.53.32 _31.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:52 |
03-31-2010, 11:58 | #3524 (permalink) |
Member: 458868 Status: Offline Sonork: 100.1597325 Thanks Meter: 27 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334099903334 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334099903334_15.56.43 _31.03.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:52 |
03-31-2010, 12:14 | #3525 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | voda fone 527 unlock done with fg Press power on shortly ... Starting communication ... MCU ID: 17C0020FEE6500C2000000000000FC21 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002910 Algo: 05 Firmware: EVN,PI: 060508 1555 Imei: 351959021984044 Phone code: 0000 Prod. code: 254053893 Id calculation done; CODES: NET LO CODE: 3585995251 NET HI CODE: 2508058291 DIRECT UNLOCK: Done Done ! Time needed - 00:03:17 |
