04-09-2010, 13:01 | #3661 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Press power on ! Starting communication ... Platform: E-Gold Voice2-64 ... Preloader sent .... Authorising ... Loader sent .... Flash ID(0): 0001:0110 Bypassing security ... LOCK: ACTIVE IMEI: 354686031082082 UNLOCK CODE: 97321852 Saved: INFINEON_EGV2_64_12.15.13_09.04.2010_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:01:10 |
04-09-2010, 14:03 | #3663 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Vadafone v527 direct unlocked:) Code: Press power on shortly ... Starting communication ... MCU ID: 12400005AAA346C10000000000001274 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00005900 Algo: 05 Firmware: E5N,PN: 110608 1555 Imei: 351960021004197 Phone code: 1234 Prod. code: 987023043 Id calculation done; CODES: NET LO CODE: 4201772631 NET HI CODE: 3123836439 DIRECT UNLOCK: OK Done ! Time needed - 00:02:42 WBR sahil2000ind |
04-09-2010, 14:52 | #3664 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | G1157 done HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039522985 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039522985_20.09.31 _08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
04-09-2010, 15:34 | #3665 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | siemen c65 unlocking Shutdown phone... Starting service mode Press POWER button shortly Can't init service mode. Try to restore Bootcore.. Shutdown phone... Press POWER button shortly FlashID: 0089:880D Set port speed. ESN: F733D224 OTPIMEI: 353910007925632 Memory size: 32Mb Read memory map. Reading EEFULL. IMEI[5009]: 353910007925632 Unlocking Writing back EEFULL Restoring Bootcore All done! |
04-09-2010, 15:41 | #3666 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | g1157 new done with fg here is log Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039550663 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_356334039550663_20.20.10 _08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:59 |
04-09-2010, 15:49 | #3667 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ZTE G-S315 UNLOCK DONE!! Connect phone powered on ! Start auth ! SW Ver: EF-CF-LEO-P108A29(S)V1.0.0B04 Imei: 355000032775158 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: ZTE_EF-CF-LEO-P108A29(S)V1.0.0B04_355000032775158_15.39.01_09.04 .2010_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:40 |
04-09-2010, 15:50 | #3668 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | t156 ayz here is log AYZ Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031870222 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.02_358146031870222_20.28.27_08. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:02:12 |
04-10-2010, 09:01 | #3669 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Dec 1 2008 09:33:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102519438-7 BLUETOOTH ADDR : 48 37 51 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:41 |
04-10-2010, 09:03 | #3670 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 22 2009 14:35:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102202957-8 BLUETOOTH ADDR : 5B 2B 4F 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:43 |
04-10-2010, 09:34 | #3671 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 9500 Unlock done......... Searching for usb device ... Reading info ... IMEI: 359484020361781 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 9469097923891671 MEP3 CODE: 1858866781074301 MEP4 CODE: 5289854802409965 MEP5 CODE: 1861007491883069 MEP6 CODE: 8141167654172479 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:01:01 |
04-10-2010, 09:35 | #3672 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 8320 Unlock Done 8320 Searching for usb device ... Reading info ... IMEI: 358281015130598 Calculating ... MEP: MEP-07723-003 MEP2 CODE: 0622674069942420 MEP3 CODE: 5301678048779864 MEP4 CODE: 6810658224657238 MEP5 CODE: 6948181162372259 MEP6 CODE: 7390992937543463 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:37 |
04-10-2010, 09:36 | #3673 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | ZTE-F866 Unlock Done.......... Software engine version: 1.0.0.3884 Searching phone ... MODEL : QCOM SERIES 6 COMPILED DATE : Dec 3 2005 16:34:00 RELEASE DATE : Sep 26 2001 01:30:00 FIRMWARE INFO : P600B2V4.0.0B11_SEC IMEI : 35753900223757-2 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : samsung_kag00j007m MEMORY INFO : 0200:0020:0800 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! RESET ! Time needed - 00:00:07 |
04-10-2010, 09:36 | #3674 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | u900 securty restore done Software engine version: 1.0.0.3884 Searching phone ... MODEL : U900 COMPILED DATE : May 10 2006 16:23:00 RELEASE DATE : May 10 2006 12:00:00 FIRMWARE INFO : U900-MSM6250A-V10b-MAY-10-2006-H3G-LatIT IMEI : 35930400258671-0 BLUETOOTH ADDR : 15 E2 3B 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400258671000 BLUETOOTH ADDR: [OK] 15E23B561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; UNAVAILABLE FEATURE SELECTED ! RESET ! Time needed - 00:02:18 |
04-10-2010, 09:37 | #3675 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | BB 9000 Unlock done........ 9000 Searching for usb device ... Reading info ... IMEI: 351846035940676 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 1201527018502184 MEP3 CODE: 8802337426262329 MEP4 CODE: 4691929765555635 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code |
