04-07-2010, 11:12 | #3631 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | t156 ayz unlock done Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031761538 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.02_358146031761538_15.05.38_07. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:30 |
04-07-2010, 13:10 | #3632 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 35435xxxxxxxxxxxxxxxx Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_354354xxxxxxxxxxx_05.09.26_07.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:42 |
04-07-2010, 14:11 | #3633 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | t156 ay done here is log Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081033308563 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU01V01.01_353081033308563_18.10.38_07. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 |
04-07-2010, 15:16 | #3634 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | AMOI S2 unlock done Software engine version: 1.0.0.3884 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Sep 5 2008 10:41:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 35422202042933-0 BLUETOOTH ADDR : 65 3F 52 40 12 00 MEMORY ID : 00EC:0078 MEMORY NAME : samsung_KAL00X00UM MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:42 |
04-07-2010, 15:25 | #3635 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 3543540xxxx6065 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_3543540xxxx6065_19.14.43_0 7.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:39 |
04-07-2010, 15:32 | #3636 (permalink) |
No Life Poster Join Date: Dec 2008 Location: PUNJAB Age: 41
Member: 914898 Status: Offline Sonork: 100.1597109 Thanks Meter: 117 | ke970 shine unlock done Press power on ! Starting communication ... Platform: S-Gold2 ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:88B0 0489 Flash ID(1): 0089:88B0 0489 Bypassing security ... LOCK: ACTIVE PHONE UNLOCKED ! REMOVE BATTERY AND PUT BACK ! Time needed - 00:06:26 |
04-07-2010, 16:04 | #3637 (permalink) |
No Life Poster Join Date: Nov 2008 Location: tunisia
Member: 898887 Status: Offline Sonork: ramazoti Thanks Meter: 210 | Successfully unlock vodafone 231 Bt Connect phone powered on ! Start auth ! SW Ver: ELI_IE_241208_0907 Imei: 354561021****** Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_17.01.55_07.04.2010_PARTIAL.bin Done ! Time needed - 00:01:37 |
04-07-2010, 18:56 | #3638 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | sagem my212x unlock done!! Press power on shortly ... Starting communication ... MCU ID: 1D1002089DA655C1000000000000DC49 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2B7E:3300 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my212X Hash: 00001840 Algo: 05 Firmware: LB5,PG: 210507 1715 Imei: 352492013327526 Phone code: 0000 Prod. code: 252963228 Id calculation done; CODES: NET LO CODE: 4134529579 NET HI CODE: 3064981867 Done ! Time needed - 00:02:08 |
04-08-2010, 07:24 | #3639 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Ufone T-156 (CY) Unlock Done Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 35308103xxxxxxxxxxxxxx Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_35308103xxxxxxxxxx_11.21.52_ 08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:27 |
04-08-2010, 07:25 | #3640 (permalink) |
04-08-2010, 09:09 | #3641 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | LG KS360 UNLOCKED LOG: Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 95198966 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 MIANLINKS |
04-08-2010, 10:53 | #3642 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | kg110 flash done Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0001:227E:2100 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: Aug 24 2006 OPERATOR: XXX-XX VERSION: V10d REVISION: 07 FIRMWARE: KG110P40 IMEI: 35470101852812000 LOCK: ON Writting flash data ... Operation completed. Phone reseted ! Time needed - 00:20:59 |
The Following User Says Thank You to naveedbutt For This Useful Post: |
04-08-2010, 10:54 | #3643 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | lg kg 110 imei wright done Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0001:227E:2100 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: Aug 24 2006 OPERATOR: XXX-XX VERSION: V10d REVISION: 07 FIRMWARE: KG110P40 IMEI: 35030526000000165 LOCK: ON Crushing routine Reading ... Phone repair completed. |
04-08-2010, 11:01 | #3644 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 356548311542122 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01__356548311542122_ 11.21.52_ 08.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:11 |
04-08-2010, 12:18 | #3645 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | T156 cy done HERE IS LOG Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 358146030018161 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_P1.2PU03V01.01_358146030018161_14.09.16_08. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:29 |
