04-11-2010, 06:39 | #3691 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3571800142924900 Requesting mepd info ... Saved: LOCOSTO_11.12.56_11.04.2010_SP.bin Direct unlock finished. 1 locks were cleared. Done ! Time needed - 00:00:16 |
04-11-2010, 07:17 | #3692 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | LG KC550 Unlock Done ........... Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 35917500 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
04-11-2010, 07:56 | #3695 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> BB 8520 & 8900 Unlocked Successfully <<< Searching for usb device ... Reading info ... IMEI: 35538303xxxxxxx Calculating ... MEP: MEP-07723-005 MEP2 CODE: 6610733380290497 MEP3 CODE: 1355496796865257 MEP4 CODE: 0113574646963877 MEP5 CODE: 8742246599418673 MEP6 CODE: 7640977908740432 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:57 ---------- Searching for usb device ... Reading info ... IMEI: 3594300xxxxxxx Calculating ... MEP: MEP-04103-001 MEP2 CODE: 2576556057902339 MEP3 CODE: 3403043490563725 MEP4 CODE: 1403407008358309 MEP5 CODE: 7664022140878110 MEP6 CODE: 3962485464733125 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:53 |
04-11-2010, 08:43 | #3696 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : U960 COMPILED DATE : May 14 2007 14:23:00 RELEASE DATE : May 14 2007 17:00:00 FIRMWARE INFO : U960-MSM6280-V10a-MAY-14-2007-H3G-IT IMEI : 35577301037803-5 BLUETOOTH ADDR : E4 6D 7C 91 E0 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:0343 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 |
04-11-2010, 09:19 | #3697 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Lg gb102 unlock ok with fg Quote:
04-11-2010, 11:21 | #3698 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Sonyericsson X1 unlocked Successfully Starting cab upload; Preparing to install; Checking installed file; Library found; Reading data; Saved: D:\FG Box\HTC_BEAST_v1.0.0.842\HTC_15.17.49_11.04.2010.b in UNLOCK CODE: 56325698 Time needed - 00:00:27 Thanxs |
04-11-2010, 11:42 | #3699 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | F188 unlock successfull Software engine version: 1.0.0.3884 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 17 2009 13:13:00 RELEASE DATE : Oct 29 2008 02:00:00 FIRMWARE INFO : YOG_ES_P622C1V1.0.1B02-S IMEI : 35786401230948-8 BLUETOOTH ADDR : 17 DE 89 93 22 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 8474799934180739 ENTER USING: *983*865625# RESET ! Time needed - 00:00:40 |
04-12-2010, 11:57 | #3701 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfullu unlock t156 cy Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037731208 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_00.45.56_13.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:15Connect phone powered on ! BR |
04-12-2010, 12:41 | #3702 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 3563340xxxx2458 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_REL_P1.2PU04V01.04_3563340xxxx2458_16.39.48 _12.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:06 |
04-12-2010, 14:13 | #3703 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 3543540xxxx3827 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S) V1.0.0B10_3543540xxxx3827_18.10.43_12.04.2010_PART IAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 |
04-12-2010, 17:58 | #3704 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 567925 Status: Offline Thanks Meter: 15 | t-mobile htc shadow Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: EC0034D3D38132313235303002020907 Doing sp area internally backup; Please wait; Saved: C:\Archivos de programa\FuriouS-Gold\HTC_EC0034D3D38132313235303002020907_11.56.57 _12.04.2010.bin IMEI: 359xxxxxxxx NCK CODE: 67046785 Time needed - 00:00:36 |
04-12-2010, 23:05 | #3705 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | succesful unlock after flash ke590 Press power on ! ASIC ID: 00040105 JTAG ID: B619 Platform: OMAP V1030 ... Baud rate change request ... Flash ID(0): 00EC:0078 Unlocking ... Reading ... Saved: OMAP_21.49.51_12.04.2010_EEP.bin IMEI: 35872201018389200 Writing ... Unlocked ! Resetting ... Done ! Time needed - 00:00:31 br gsm.magic |
