04-13-2010, 08:05 | #3706 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:8815:0101 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: Mar 03 2006 OPERATOR: 234-33 VERSION: V10b REVISION: 44 FIRMWARE: KG220P40FL IMEI: 35910100047346500 LOCK: ON Phone unlocked. Phone reseted ! Time needed - 00:00:43 |
04-13-2010, 08:16 | #3707 (permalink) |
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | lg kp170 unlock done...???????? Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:22 |
04-13-2010, 08:17 | #3708 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : KF310 COMPILED DATE : Dec 11 2008 11:43:00 RELEASE DATE : Nov 28 2008 08:00:00 FIRMWARE INFO : KF310-MSM6245-V10b-NOV-28-2008-XX IMEI : 35423902707214-5 BLUETOOTH ADDR : 6E 43 8C FB 21 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02FD INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
04-13-2010, 09:11 | #3709 (permalink) |
No Life Poster Join Date: Nov 2008 Location: nakodar
Member: 903492 Status: Offline Sonork: 1590666 Thanks Meter: 571 | lg ku990i successfull unlock lg ku990i unlock Software engine version: 1.0.0.3884 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 22 2009 14:51:00 RELEASE DATE : Mar 12 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10c-MAR-12-2009-XX IMEI : 35469303596347-3 BLUETOOTH ADDR : BE 79 65 83 24 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 354693035963473 BLUETOOTH ADDR: [OK] 0024836579BE PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:06:51 |
The Following User Says Thank You to ^^^RAVI SOOD^^^ For This Useful Post: |
04-13-2010, 10:01 | #3710 (permalink) |
Banned Join Date: Apr 2004 Location: **NEDROMA** Age: 51
Member: 63194 Status: Offline Thanks Meter: 59 | Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 0000000000000000000000000000000000 Doing sp area internally backup; Please wait; Saved: C:\Documents and Settings\mohamed\Bureau\MAINTAINANCE\HTC_BEAST_v1. 0.0.1032\HTC_0000000000000000000000000000000000_09 .56.32_14.04.2010.bin IMEI: 35953400625076 NCK CODE: 50798606 Time needed - 00:00:25 spv c100 |
04-13-2010, 10:18 | #3711 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | HTC E650 unlocked, Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 0000000000000000000000000000000000 Doing sp area internally backup; Please wait; Saved: C:\Program Files\FuriouS-Gold\HTC_0000000000000000000000000000000000_14.10. 35_13.04.2010.bin IMEI: 35525701152099 NCK CODE: 57332903 Time needed - 00:00:48 --------------------------------- wr khawar |
04-13-2010, 15:58 | #3713 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Where Dreams Comes True...S4U
Member: 755709 Status: Offline Sonork: 100.1592000 Momo... Thanks Meter: 6,635 | vodafone 331 is ok : Connect phone powered on ! Start auth ! SW Ver: ELI_IE_220908_1309 Imei: 354561020360627 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_14.23.11_13.04.2010_PARTIAL.bin Done ! Time needed - 00:01:41 ---s@nsari--- |
04-13-2010, 16:36 | #3714 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | 8100 pearl here is log Searching for usb device ... Reading info ... IMEI: 351961027753795 Calculating ... MEP: MEP-04103-001 MEP2 CODE: 4099210653160140 MEP3 CODE: 6233424549179814 MEP4 CODE: 5051273786203576 MEP5 CODE: 0532462060346572 MEP6 CODE: 5892431555285833 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:01:36 |
04-14-2010, 05:25 | #3716 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034482474 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_P1.2PU02V01.01_353081034482474_09.23.02_14. 04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:54 |
04-14-2010, 05:34 | #3717 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 66094006 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
04-14-2010, 11:41 | #3718 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | Software engine version: 1.0.0.3884 Searching phone ... MODEL : KU250 COMPILED DATE : Aug 13 2007 19:06:00 RELEASE DATE : Apr 29 2007 17:00:00 FIRMWARE INFO : KU250-MSM6245-V10a-MAY-30-2007-XX IMEI : 35638501******-7 BLUETOOTH ADDR : 5E DE 0D 75 1E 00 MEMORY ID : 00AD:0076 MEMORY NAME : hynix_hyc0ueh0mf3p MEMORY INFO : 0200:0020:0996 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:22 |
04-14-2010, 12:43 | #3719 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | ZTE A 316g unlocked Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030939147 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_354354030939147_16.41.35_1 4.04.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:03:57 |
04-14-2010, 13:16 | #3720 (permalink) |
Banned Join Date: Mar 2004
Member: 58357 Status: Offline Thanks Meter: 27 | KU380 unlock Software engine version: 1.0.0.3884 Searching phone ... MODEL : KU380 COMPILED DATE : Dec 7 2007 13:40:00 RELEASE DATE : Sep 5 2007 04:00:00 FIRMWARE INFO : KU380-MSM6245-V10b-SEP-14-2007-XX IMEI : 35839001802664-4 BLUETOOTH ADDR : 54 38 0B 6B 1F 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:030F INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 |
