06-17-2010, 08:34 | #4411 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_12.20.39_17.06.2010_PARTIAL.bin Done ! Time needed - 00:00:49 |
06-17-2010, 09:20 | #4412 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | messenger 251 sfr zte here is log sfr241 select 251 messenger > IMEI: 357930030380502 > NCK: 978984980548 > SPCK: 173967910577 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. |
06-17-2010, 10:06 | #4413 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Software engine version: 1.0.0.4558 Searching phone ... MODEL : KF310 COMPILED DATE : Dec 11 2008 11:43:00 RELEASE DATE : Nov 28 2008 08:00:00 FIRMWARE INFO : KF310-MSM6245-V10b-NOV-28-2008-XX IMEI : 3542xxxxxxxxxxx BLUETOOTH ADDR : 53 E1 09 A9 22 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02FD INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
06-17-2010, 12:33 | #4414 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | BB 9530 unlocked successfully Searching for usb device ... Reading info ... IMEI: 9800020038***** Calculating ... MEP LOCK: MEP-15326-001 MEP1 [SIM]: 4098936304563238 MEP2 [NETWORK]: 9036901545066845 MEP3 [NETWORK SUBSET]: 8294229496017698 MEP4 [SERVICE PROVIDER]: 5400270159073934 MEP5 [CORPORATE]: 9146228636900193 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 |
06-17-2010, 14:14 | #4415 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | zte f102 unlock ok FG Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003163194-9 BLUETOOTH ADDR : E9 B6 29 ED 26 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:22 |
06-17-2010, 15:32 | #4416 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145036162346 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145036162346_REL_P1.2PU04V01.04_19.05.33 _17.06.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
06-17-2010, 15:35 | #4417 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: Software engine version: 1.0.0.4558 Searching phone ... MODEL : U880 COMPILED DATE : Feb 20 2006 09:02:00 RELEASE DATE : Jul 3 2005 16:00:00 FIRMWARE INFO : U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK IMEI : 35705000755437-5 BLUETOOTH ADDR : D5 20 0C 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 357050xxxxxxxxxx BLUETOOTH ADDR: [OK] D5200C561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: OFF NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:16 |
06-18-2010, 04:09 | #4419 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | kp170 unocking Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:31 |
06-18-2010, 04:51 | #4420 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145036160365 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145036160365_REL_P1.2PU04V01.04_08.50.09 _18.06.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:42 |
06-18-2010, 06:07 | #4421 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038318930 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081038318930_P1.2PU03V01.01_10.05.13_18. 06.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
06-18-2010, 06:08 | #4422 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145035881953 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145035881953_REL_P1.2PU04V01.04_10.08.21 _18.06.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 |
06-18-2010, 10:15 | #4423 (permalink) |
No Life Poster Join Date: Jul 2007 Location: philippines
Member: 556768 Status: Offline Thanks Meter: 157 | b-mobile u526 Searching phone ... MODEL : D618 V1.0 Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Init nand made; Reading; Imei : 35638700058889-8 Unlock code: 1362441983819628 Done ! Time needed - 00:01:09 |
06-18-2010, 11:26 | #4424 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09 Imei: 354354030282654 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354030282654_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B09_15.25.02_18.06.2010_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
06-18-2010, 14:31 | #4425 (permalink) |
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039053262 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039053262_P1.2PU01V01.01_18.28.53_18. 06.2010_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:35 |
