03-14-2011, 20:33 | #8191 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | power on phone,download drivers from support and install,launch latest AMDO.exe select diag port,press unlock |
03-15-2011, 07:31 | #8192 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | G2200c unlocked ============ Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 353100030567276 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:15:11 |
03-15-2011, 07:32 | #8193 (permalink) |
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | F102 unlocked ============= Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003246036-3 BLUETOOTH ADDR : 9F 5C 3F 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 |
03-15-2011, 07:33 | #8194 (permalink) |
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | my411X unlocked =============== Press power on shortly ... Starting communication ... MCU ID: 15300113A88857C1000000000000FE41 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RF: 280607 1805 Imei: 351628020141803 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 0976217353 NET HI CODE: 2062542537 DIRECT UNLOCK: OK Done ! Time needed - 00:02:51 |
03-15-2011, 09:42 | #8195 (permalink) |
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | vodafone 725 unlocked ================= Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00EC:0078 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Checking for password presence ... Found 5 password(s) ! Password (0): 3869 Password (1): 3869 Password (2): 3869 Password (3): 3869 Password (4): 3869 Done ! Time needed - 00:00:40 |
03-15-2011, 12:10 | #8196 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | t156 ay unlock done............ t156 unlock done Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 35308103960?????? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_35308103960????_P1.2PU01V01.01_16.01.27_15. 03.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:33 br:. shabir97 |
03-15-2011, 13:50 | #8197 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033680339 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033680339_REL_P1.1PU01V01.06_11.57.57 _15.03.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:57 |
The Following User Says Thank You to gsmcrazy1 For This Useful Post: |
03-15-2011, 13:51 | #8198 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock G2158 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892031730516 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892031730516_REL_P1.1PU01V01.03_11.37.57 _15.03.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:17 |
03-15-2011, 13:52 | #8199 (permalink) |
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock T156 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038746486 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_353081038746486_P1.2PU03V01.01_14.38.11_14. 03.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 |
03-15-2011, 14:16 | #8200 (permalink) |
No Life Poster Join Date: Nov 2010 Location: pakistan
Member: 1453428 Status: Offline Sonork: 100.1596919 Thanks Meter: 146 | successfully unlocked alcatel ot-s210 successfully unlocked alcatel ot-s210 with furious here is log Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3524090250582600 Requesting mepd info ... Saved: LOCOSTO_04.40.49_15.03.2011_SP.bin Direct unlock finished. 1 locks were cleared. Done ! Time needed - 00:00:26 and screen shot |
03-15-2011, 17:20 | #8201 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | LG A133 Unlock Done. Press power on ! Starting communication ... Platform: A-GOLDRadio XMM2130 ... Preloader sent .... Loader sent .... Flash ID(0): 0089:8881 Bypassing security ... UNLOCK CODES: NETWORK: 5278078131012220 NETWORK SUBSET: 0924089934771940 SERVICE PROV.: 3854135380476820 CORPORATE: 0782361243100343 SIM/USIM: 7410297222441163 Saved: INFINEON_XMM2130_21.16.35_15.03.2011_EEP.bin REMOVE BATTERY AND PUT BACK ! Done ! Time needed - 00:00:41 |
03-15-2011, 20:40 | #8202 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Fuengirola-Malaga
Member: 994585 Status: Offline Sonork: bombastic Thanks Meter: 240 | palm pixi plus unlock done in 00:00:01 sec Software engine version: 1.0.0.6421 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Mar 26 2010 19:27:00 RELEASE DATE : Mar 26 2010 19:16:00 FIRMWARE INFO : XU1.5.8(3109) IMEI : 35195604035816-8 BLUETOOTH ADDR : 00 00 00 00 00 00 WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 Thank you |
03-16-2011, 08:06 | #8203 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | Zong Z100 Successfully Unlocked. Software engine version: 1.0.0.5720 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040499634 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 34 84 91 5B 0A 0E 05 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040499634_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.04.18_16.03.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:49 |
03-16-2011, 09:40 | #8204 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock done zte f102 with furious-gold>>>> Here is log: Software engine version: 1.0.0.6404 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003248992-5 BLUETOOTH ADDR : 79 89 41 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 Br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
03-16-2011, 10:39 | #8205 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Software engine version: 1.0.0.5478 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145032129802 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145032129802_REL_P1.2PU04V01.04_14.09.36 _16.03.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:49 |
