06-28-2011, 19:32 | #8941 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | LG T320 Unlock Done With Furious Gold Phone detected; USB Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: DD; Ebl_ver: NOT RELEASED 65535..65535; Sending loader config; Done; Flash ID is: 00AD:00BA Reading eeprom; Reading calibration; Saved: T320_T320e_T320q_T325_23.28.52_28.06.2011_EEP_CAL. bin UNLOCK CODES: NETWORK: 9363801440882349 NETWORK SUBSET: 6762723139604982 SERVICE PROV.: 3955256355348621 CORPORATE: 6557831202824580 SIM/USIM: 1117982282191828 Power on phone with accepted sim. Type 2945#*320# and enter code. Time needed - 00:00:16 |
06-29-2011, 04:32 | #8942 (permalink) |
Freak Poster Join Date: Nov 2010 Location: south africa
Member: 1453345 Status: Offline Thanks Meter: 17 | zong z100 unlock successfully zong z100 unlock successfully Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504243???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 19 65 28 5A F4 67 08 01 07 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042433???_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_08.13.17_29.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:54 |
06-29-2011, 07:57 | #8943 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | Blackberry 9700 unlocked. Searching for usb device ... Reading info ... IMEI: 35196804375**** Calculating ... MEP LOCK: MEP-04104-007 MEP1 [SIM]: 2745135441288644 MEP2 [NETWORK]: 7578294305467478 MEP3 [NETWORK SUBSET]: 6169173362586261 MEP4 [SERVICE PROVIDER]: 0035908486417310 MEP5 [CORPORATE]: 1363868753033803 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:55 |
06-29-2011, 10:19 | #8944 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.06 Imei: 358892033763101 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Reading ... Saved: HUAWEI_358892033763101_REL_P1.1PU01V01.06_20.53.39 _28.06.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00C2:22A7 Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:14 |
06-29-2011, 10:21 | #8945 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5881 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 6A 64 49 21 C1 B0 83 00 1B 07 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:55 |
06-29-2011, 10:21 | #8946 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 004999010640000 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 6A 64 49 21 C1 B0 83 00 1B 07 Flash ID(0): 00C2:22A7 Saved: ZTE_004999010640000_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.14.37_29.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
06-29-2011, 10:22 | #8947 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041497306 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 32 04 97 A0 06 85 07 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041497306_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.41.21_29.06.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:43 |
06-29-2011, 10:30 | #8948 (permalink) |
Freak Poster Join Date: Apr 2006 Location: P A K I S T A N (RWP)
Member: 267787 Status: Offline Thanks Meter: 71 | Vodafone 546 unlock Done Vodafone unlock Done Via Furious Gold via this INSTRUCTIONS CONNECT CABLE TO THE PHONE WITH BATTERY INSIDE (IN THIS MOMENT PHONE WILL START SHOWING CHARGING ANIMATION). START PHONE, PRESS ‘DO JOB’ ON APPLICATION AND WHEN SOFTWARE IS LOOKING FOR THE DEVICE KEEP END CALL PRESSED UNTIL IT POWERS OFF AND BOOTING PROCESS WILL START And UNLOCK DONE Here is Log Software engine version: 1.0.0.5881 Press power on shortly or insert the cable in the powered off phone ... COM Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: BB; Ebl_ver: XMM2130_RAM_Bootloader_B9.3_V 1..1; Sending loader config; Done; Memory Info: 0001:007E [0x02000000] Reading calibration; Reading static eeprom; Reading dynamic eeprom; Saved: 546_545_13.51.39_29.06.2011_EEP_CAL.bin Checking version; Detected: EFSPAZ-PT-P160A61(SPA)V1.0.0B05 Reading; Writing; Direct unlock finished. Time needed - 00:02:21 Thanks Great Teem FURIOUS GOLD Br. Anees-ur-rehman |
The Following User Says Thank You to Anees-ur-rehman For This Useful Post: |
06-29-2011, 10:44 | #8949 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030809001 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354030809001_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_14.40.00_29.06.2011_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:40 |
06-29-2011, 14:37 | #8950 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | Starting communication ... MCU ID: 13300113A7A346C10000000000008A60 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411Cv Hash: 00002291 Algo: 05 Firmware: EVN,SE: 230707 1109 Imei: 356540013465740 Phone code: 0000 Prod. code: 252961761 Id calculation done; CODES: NET LO CODE: 0698832977 NET HI CODE: 1768381329 DIRECT UNLOCK: OK Done ! Time needed - 00:02:59 |
06-29-2011, 15:14 | #8951 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5349 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031492269 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:12 |
06-29-2011, 22:46 | #8952 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Dominican Republic Age: 49
Member: 92317 Status: Offline Sonork: 100.1591991 Thanks Meter: 223 | palm pre att unlock done Software engine version: 1.0.0.6727 Searching phone ... MODEL : QCOM SERIES 15 COMPILED DATE : Jul 21 2010 20:41:00 RELEASE DATE : Jul 21 2010 20:23:00 FIRMWARE INFO : CU0.5.48(259) IMEI : 012145000xxxxx-0 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:033C WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:01 thanks FG |
06-30-2011, 06:44 | #8953 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Press power on shortly ... Starting communication ... MCU ID: 2B50011962A75DC1000000000000AC17 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: Sagem my511X Hash: 00002786 Algo: 05 Firmware: EON,DF: 010408 1801 Imei: 356867014416392 Phone code: 0000 Prod. code: 253045884 Id calculation done; CODES: NET LO CODE: 0091499202 NET HI CODE: 1161046530 Done ! Time needed - 00:02:12 |
06-30-2011, 06:53 | #8954 (permalink) |
Banned Join Date: Feb 2008 Location: GSM Nowshera
Member: 713374 Status: Offline Sonork: 100.1597179 Thanks Meter: 223 | f102 Software engine version: 1.0.0.6688 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003264234-1 BLUETOOTH ADDR : 5C F9 43 4A 15 D0 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:49 |
06-30-2011, 06:54 | #8955 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | segam 511x. Press power on shortly ... Starting communication ... MCU ID: 2B50011962A75DC1000000000000AC17 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: Sagem my511X Hash: 00002786 Algo: 05 Firmware: EON,DF: 010408 1801 Imei: 356867014416392 Phone code: 0000 Prod. code: 253045884 Id calculation done; CODES: NET LO CODE: 0091499202 NET HI CODE: 1161046530 Done ! Time needed - 00:02:12 |
