08-24-2011, 19:17 | #9316 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892032378737 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892032378737_REL_P1.1PU01V01.03_21.44.09 _23.08.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:19 |
08-25-2011, 07:31 | #9317 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | INQ1 unlocking done. Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 2 [KYUZ] COMPILED DATE : Apr 22 2009 14:35:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 354xxxxxxxxxx-x BLUETOOTH ADDR : 73 2C 51 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:11 wbr, rajesh_ch |
08-25-2011, 08:32 | #9318 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | z100 ok Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865043456516 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 F9 65 28 5A F4 67 08 0B 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043456516_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.28.46_25.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
08-25-2011, 11:52 | #9319 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042080887 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 99 65 28 DA F4 82 06 10 01 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042080887_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_18.13.54_23.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:36 |
08-25-2011, 11:53 | #9320 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865042080887 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 99 65 28 DA F4 82 06 10 01 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042080887_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_17.48.17_23.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:38 |
08-25-2011, 23:12 | #9321 (permalink) |
Freak Poster Join Date: May 2009
Member: 1027923 Status: Offline Thanks Meter: 19 | FIRST ORANGE ZTE TACTILE MESSAGING UNLOCKED WITH FURIOUS Software engine version: 1.0.0.6813 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 10:17:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_FR_P671A80V1.0.0B18-S IMEI : 35635304007041-2 BLUETOOTH ADDR : 7C B4 C5 C7 64 C6 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 208 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:48 |
08-26-2011, 05:00 | #9322 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Palm Tre successfull unlocked log: Quote:
MIANLINKS | |
08-26-2011, 11:33 | #9323 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | Alcatel OT808x 808X-2BVDES2 unlock ok I use RJ45 universal C7xx cable (2x5 pins) Make your handset power off, plug in the UART cable! Product: OT-808 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 35638903200mask last 4 digits Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\808 X-2BVDES2 Read security information successfully! Start code calculate... Product: OT-808 IMEI: 35638903200mask 4 digits Security file: C:\Program Files\FuriouS-Gold\PACK8\Alcatel\Security\BackupSecurityFile\808 X-2BVDES2 NCK:1194683190 NSCK: SPCK: PCK: Code calculate finished successfully! |
08-27-2011, 11:54 | #9325 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | oftware engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043407261 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 32 84 97 E2 05 8E 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043407261_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.55.45_26.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:51Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865042377085 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 35 04 97 26 02 1C 0C Flash ID(0): 00C2:22A7 Saved: ZTE_352865042377085_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_11.07.53_27.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:57 |
08-27-2011, 11:55 | #9326 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865043187756 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 64 32 84 97 41 04 87 02 Flash ID(0): 00C2:22A7 Saved: ZTE_352865043187756_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_15.56.25_26.07.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:54Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031677585 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031677585_P1.2PU01V01.02_13.34.11_31. 07.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
08-27-2011, 11:55 | #9327 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | oftware engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031705733 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031705733_P1.2PU01V01.02_14.34.50_26. 07.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01 |
08-27-2011, 11:55 | #9328 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 9Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 FLASH CID: 17 PHONE COLOR: BROWN Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J OTP CID: 17 IMEI: 35511600581976-3 Settings made ... Bypassing restriction ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Settings Done ! Certificate sent ... Boot info: HACK3R2K.COM GSM DEVELOPEMENT Flash 1: 0089:880D Flash 2: 0089:8810 Firmware version: U8120_v105 Working. Please wait ... Operation finished ! Time needed - 00:00:32 |
08-27-2011, 11:56 | #9329 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 1Make your handset power off, plug in the UART cable! Product: Vodafone345 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 351760046527101 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\V34 5X-2AVDGB1 Read security information successfully! Start code calculate... Product: Vodafone345 IMEI: 351760046527101 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\V34 5X-2AVDGB1 NCK:1505655217 NSCK: SPCK: PCK: Code calculate finished successfully! |
08-27-2011, 11:57 | #9330 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 352865041986266 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 79 65 38 DA F4 05 02 0E 0B Flash ID(0): 00C2:22A7 Saved: ZTE_352865041986266_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_12.04.19_19.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:01Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040832206 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 29 65 38 DA F4 60 00 0F 01 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040832206_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.53.19_22.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:5 |
