08-16-2011, 11:03 | #9271 (permalink) |
No Life Poster Join Date: Dec 2007 Location: shirdi..sai baba.. Age: 36
Member: 662678 Status: Offline Thanks Meter: 2,539 | Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 2 [KYRZ] COMPILED DATE : Sep 2 2008 00:34:00 RELEASE DATE : Sep 2 2008 00:33:00 FIRMWARE INFO : O'zapft is000Athens1.08ATHB1A_1.08P0 IMEI : 35********** BLUETOOTH ADDR : 27 30 5A CA 17 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_HYC0SEH0AF3P MEMORY INFO : 0200:0020:06ED INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; DATA FOUND; PHONE CODE: 1234 RL STARTED; RL DONE; UNLOCK CODE(S): 67932472 MASTER CODE: 45369488 ENTER CODE(S) NOW ! DO NOT RESTART THE PHONE ! IF PHONE DOESN'T ASK ANY CODE OR YOU RESTART IT THEN REPEAT THE OPERATION ! Time needed - 00:00:12 |
08-16-2011, 15:59 | #9272 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | vodafone v546 successfully unlock... today is lucky day...... successfully unlock vodafone 546 by Furious gold thx to Fg team.... logs....... Software engine version: 1.0.0.5881 Press power on shortly or insert the cable in the powered off phone ... COM Port opened; Boot-loader Alive; Sending loaders; Done; Boot Mode: BB; Ebl_ver: XMM2130_RAM_Bootloader_B9.3_V 1..1; Sending loader config; Done; Memory Info: 0001:007E [0x02000000] Reading calibration; Reading static eeprom; Reading dynamic eeprom; Saved: 546_545_15.52.19_16.08.2011_EEP_CAL.bin Checking version; Detected: EFSPAZ-GH-P160A61(SPA)V1.0.0B03 Reading; Writing; Direct unlock finished. Time needed - 00:02:18 |
The Following 2 Users Say Thank You to louisgsm For This Useful Post: |
08-16-2011, 20:08 | #9273 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334038279058 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334038279058_REL_P1.2PU04V01.04_15.34.16 _16.08.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:48 |
08-16-2011, 20:11 | #9274 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041940842 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 19 65 38 DA F4 D1 08 8D 04 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041940842_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.37.45_15.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:56 |
08-17-2011, 09:54 | #9275 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Software engine version: 1.0.0.6761 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Feb 1 2010 19:08:00 RELEASE DATE : Nov 10 2009 00:00:00 FIRMWARE INFO : TEL_AU_P607C4V1.0.0B08-S IMEI : 35883403076446-8 BLUETOOTH ADDR : FF 9B AA C7 64 C8 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 1 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:43 |
08-17-2011, 10:09 | #9276 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | LG GS290 unlock ok Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... UNLOCK CODES: NETWORK: 5323252719444165 NETWORK SUBSET: 0838131490023869 SERVICE PROV.: 1244840448257003 CORPORATE: 6780828339837895 SIM/USIM: 2311526060552733 Power on phone with original sim. Type 2945#*290# and enter code. Done ! Time needed - 00:00:56 |
08-17-2011, 17:42 | #9277 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Romania Age: 44
Member: 724928 Status: Offline Sonork: 100.1581257 Thanks Meter: 225 | HTC Elfin Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: FFFFFFFFAAFFFFFFD9940FF20900D97F00 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - La demande réseau n'est pas prise en charge. error initializing flash Trying alternative scanning method; Scanning 0 Scanning 1 Saved: C:\Program Files (x86)\FuriouS-Gold\HTC_FFFFFFFFAAFFFFFFD9940FF20900D97F00_16.38. 49_16.08.2011.bin IMEI: 356786xxxxxxx NCK CODE: 79271888 Time needed - 00:00:56 |
08-18-2011, 08:40 | #9278 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | ANOTHER HUAWEI U1280 UNLOCK DONE ! Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35529103194140-0 READING; SP_SAVED_TO: SP_35529103194140_EA1_10.36.35_18.08.2011_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: FFF-FF MCC-MNC [1]: FFF-FF MCC-MNC [2]: FFF-FF MCC-MNC [3]: FFF-FF MCC-MNC [4]: FFF-FF MCC-MNC [5]: FFF-FF MCC-MNC [6]: FFF-FF MCC-MNC [7]: FFF-FF MCC-MNC [8]: FFF-FF MCC-MNC [9]: FFF-FF MCC-MNC [10]: FFF-FF MCC-MNC [11]: FFF-FF MCC-MNC [12]: FFF-FF MCC-MNC [13]: FFF-FF MCC-MNC [14]: FFF-FF MCC-MNC [15]: FFF-FF MCC-MNC [16]: FFF-FF MCC-MNC [17]: FFF-FF MCC-MNC [18]: FFF-FF MCC-MNC [19]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:03:23 |
08-18-2011, 14:01 | #9279 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | T156 unlocked Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031420341 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031420341_P1.2PU01V01.02_05.58.10_18. 08.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 |
08-18-2011, 18:55 | #9282 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334037179788 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334037179788_REL_P1.2PU04V01.04_22.41.33 _18.08.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:45 |
08-19-2011, 16:35 | #9283 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Online Thanks Meter: 162 | ZTE F160 ATLANTA ORANGE Software engine version: 1.0.0.6X00 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : May 3 2011 18:10:00 RELEASE DATE : Apr 1 2011 04:00:00 FIRMWARE INFO : ORG_UK_P622F2V1.0.0B07-S IMEI : 35734104002XXX-X BLUETOOTH ADDR : B2 E1 A6 C7 64 C8 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 THE GREAT FURIOUS UNLOCKED IT |
08-20-2011, 04:49 | #9284 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334039241925 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334039241925_REL_P1.2PU04V01.04_18.51.33 _19.07.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
08-20-2011, 04:50 | #9285 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Software engine version: 1.0.0.5881 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1PU01V01.03 Imei: 358892032275164 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Reading ... Saved: HUAWEI_358892032275164_REL_P1.1PU01V01.03_15.13.10 _19.07.2011_PARTIAL.bin Erasing ... Press reset button ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:235D Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:08 |
