08-11-2011, 10:10 | #9256 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | INQ MINI 3G unlock done.... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35406903047118-6 READING; SP_SAVED_TO: SP_35406903047118_E54_14.35.13_11.08.2011_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 234-20 MCC-MNC [1]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:27 |
08-11-2011, 10:28 | #9257 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | vodafone 246 unlock done with fg Software engine version: 1.0.0.5907 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A2V1.0.0B10 Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B10_01.01.25_11.08.2011_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:47 |
08-12-2011, 15:04 | #9258 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | HUAWEI U1280 UNLOCK DONE !!! Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35529103236949-4 READING; SP_SAVED_TO: SP_35529103236949_EA1_16.59.07_12.08.2011_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 259-05 MCC-MNC [1]: FFF-FF MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:02:06 |
08-13-2011, 06:03 | #9259 (permalink) |
No Life Poster Join Date: Jul 2010 Location: serai naurang pakistan
Member: 1352180 Status: Offline Sonork: 100.1605782 Thanks Meter: 61 | kg 290 imei change by fg itry with hwk infinity and z3x soft show changed ok but when check imei still same . done with fg Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:8816:0101 READING INFO ... WAIT ! (CAN TAKE ~60s) IMEI: 356211414996556 LOCK: ON Crushing routine Phone repair completed. Phone reseted ! Time needed - 00:00:27 |
08-13-2011, 10:46 | #9260 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Z100 unlocked Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865040446957 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 15 57 09 31 45 90 C0 01 1D 07 Flash ID(0): 00C2:22A7 Saved: ZTE_352865040446957_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_02.44.41_14.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:50 |
08-13-2011, 11:45 | #9261 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Searching for usb device ... Reading info ... IMEI: 358263017858434 Calculating ... MEP LOCK: MEP-16472-001 MEP1 [SIM]: 7097854545402910 MEP2 [NETWORK]: 7370926176125541 MEP3 [NETWORK SUBSET]: 4857246141242433 MEP4 [SERVICE PROVIDER]: 3452243423448216 MEP5 [CORPORATE]: 1308592958243502 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:41 |
08-13-2011, 13:47 | #9262 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Z100 unlocked Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042006551 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 00 99 65 28 DA F4 53 00 98 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042006551_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_05.43.02_13.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:02:01 |
08-13-2011, 13:49 | #9263 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | z100 unlock..................................... Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504363???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 38 84 98 D6 06 92 0B Flash ID(0): 00C2:22A7 Saved: ZTE_35286504363????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_13.37.39_13.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 br:. shabir97 |
08-13-2011, 13:51 | #9264 (permalink) |
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | z100 unlock............................ Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 Imei: 35286504364???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 9B 36 04 97 52 00 12 0C Flash ID(0): 00C2:22A7 Saved: ZTE_35286504364????_E-PK-CMPAK-P108A34FM(S)V1.0.0B04_13.40.14_13.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 br:. shabir |
08-13-2011, 13:52 | #9265 (permalink) |
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | z100unlock............................ Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 35286504323???? Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 35 44 98 53 05 8F 0A Flash ID(0): 00C2:22A7 Saved: ZTE_35286504323????_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_13.51.50_13.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:46 |
08-13-2011, 16:52 | #9266 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | LG KP500 Unlock Done With Furious Gold Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 11083323 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:18 |
08-15-2011, 10:11 | #9267 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Alcatel VLE5 (E259X-2ASNDK1) unlock done.............. Press power on shortly ... Starting communication ... BootRom v04.11 Sending certificate ... Sending preloader ... Sending EBOLA ViruS ! Phone infected. RSA Defeated ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Trying baud rate change ... Baud rate changed ok ! FLASH 1 ID: 0001:227E 0A01 MODE: E100/E105/E157/E158/E159/E160/E161 E200/E205/E220/E230/E252/E256/E257 E259/E260/E265/C61/C62 MCU ID: 2406948DFC9603B1 ALGO TYPE: 00 OTP IMEI: 359074003652007 PROVIDER: E259X-2ASNDK1 FW INFO: 43DBED0101 Phone unlocked. Phone reseted ! Time needed - 00:00:12 |
08-15-2011, 10:49 | #9268 (permalink) |
No Life Poster Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | F107 Software engine version: 1.0.0.6794 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jun 17 2010 15:58:00 RELEASE DATE : Dec 8 2009 23:00:00 FIRMWARE INFO : H3G_GB_P607C5V1.0.0B11-S IMEI : 35804803230316-3 BLUETOOTH ADDR : 5A 0F 79 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:11 |
08-15-2011, 12:06 | #9269 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | VF527 unlock ok Press power on shortly ... Starting communication ... MCU ID: 2D800102EC6500C2000000000000D449 ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 0000283C Algo: 05 Firmware: EVN,PH: 250408 0928 Imei: 35195902279mask last digits Phone code: 0000 Prod. code: 254028126 Id calculation done; CODES: NET LO CODE: 3962298296 NET HI CODE: 2892750840 Done ! Time needed - 00:02:11 Thanks Furious-Gold team! |
08-16-2011, 08:09 | #9270 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | ufone g2201 Software engine version: 1.0.0.5931 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031602545 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:06 |
