08-03-2011, 18:48 | #9226 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041431610 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 DB 35 04 97 58 00 89 0F Flash ID(0): 00C2:22A7 Saved: ZTE_352865041431610_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.30.08_03.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:03:31 |
08-03-2011, 18:48 | #9227 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034786767 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081034786767_P1.2PU02V01.01_14.56.10_03. 08.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:44 |
08-03-2011, 18:59 | #9228 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Unlock ZTE X760 Done : > IMEI: 352353024229541 > NCK: 408116260404 > SPCK: 543038680757 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. |
08-04-2011, 06:42 | #9229 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | vodafone 527 unlock done with fg Press power on shortly ... Starting communication ... MCU ID: 1AA00205576700C2000000000000067A ROM HASH: 731C27AB2AE00189FBD4FD3013B53252 ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: VF527 Hash: 00002143 Algo: 07 Firmware: EVN,PL: 050808 1806 Imei: 359262022116712 Phone code: 0000 Prod. code: 254060244 Id calculation done; CODES: NET LO CODE: 2295591626 NET HI CODE: 4155590460 Done ! Time needed - 00:02:04 |
The Following User Says Thank You to niceraees For This Useful Post: |
08-04-2011, 08:56 | #9230 (permalink) |
Member: 354975 Status: Offline Sonork: Love For All Thanks Meter: 462 | my 411x unlock done with fg Press power on shortly ... Starting communication ... MCU ID: 2CC0020A15A463C10000000000004446 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411X Hash: 00002054 Algo: 05 Firmware: LO5,RF: 280607 1806 Imei: 351628021545457 Phone code: 0000 Prod. code: 252925020 Id calculation done; CODES: NET LO CODE: 0483590205 NET HI CODE: 1544750077 Done ! Time needed - 00:01:56 |
08-04-2011, 14:19 | #9231 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 00000000D20E0103222413540E0706CD00 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - UNKNOWNERROR: 0x00000032 error initializing flash Trying alternative scanning method; Scanning 0 Saved: C:\Program Files\FURIOUS-GOLD\PACK6\HTC_00000000D20E0103222413540E0706CD00_ 12.21.48_04.08.2011.bin IMEI: 35846 NCK CODE: 30200672 Time needed - 00:00:31 |
08-04-2011, 15:50 | #9232 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | blackberry 8520 unlock done!!!! Searching for usb device ... Reading info ... IMEI: 353486049794187 Calculating ... MEP LOCK: MEP-05277-005 MEP1 [SIM]: 1727754352235826 MEP2 [NETWORK]: 6706851765181974 MEP3 [NETWORK SUBSET]: 0772501383481199 MEP4 [SERVICE PROVIDER]: 7448305486408180 MEP5 [CORPORATE]: 6496111835543915 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:40 |
08-05-2011, 08:27 | #9233 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | vodafone 345 unlock wit rs ts ...........Make your handset power off, plug in the UART cable! Product: Vodafone345 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 351760046195768 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\V34 5X-2AVDGB1 Read security information successfully! Start code calculate... Product: Vodafone345 IMEI: 351760046195768 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\V34 5X-2AVDGB1 NCK:3455319416 NSCK: SPCK: PCK: Code calculate finished successfully |
08-05-2011, 11:49 | #9234 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Software engine version: 1.0.0.6761 Searching phone ... MODEL : LGC320 COMPILED DATE : Sep 13 2010 20:57:00 RELEASE DATE : Jun 22 2010 18:00:00 FIRMWARE INFO : LGC320-QSC6270-V10a-SEP-13-2010-XX IMEI : 35461304008571-6 BLUETOOTH ADDR : C6 54 53 D3 17 5C ENTERING DOWNLOAD MODE; ENTERED; BOOT VERSION: BS/LGC320/V10a LOADING DATA; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! INFO HASH WRITTEN; UNLOCKING PASSED ! LOCK HASH WRITTEN; SEC DATA 1 WRITTEN; SEC DATA 2 WRITTEN; UNLOCKED ! Time needed - 00:00:49 |
08-05-2011, 19:20 | #9235 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034724453 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081034724453_P1.2PU02V01.01_22.48.56_05. 08.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 |
08-05-2011, 19:20 | #9236 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865042443499 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 38 84 97 04 02 16 09 Flash ID(0): 00C2:22A7 Saved: ZTE_352865042443499_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_14.43.59_04.08.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:41 |
08-05-2011, 19:21 | #9237 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 38 84 97 04 02 16 09 Flash ID(0): 00C2:22A7 PARTIAL: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 RANGE(S): 00000000:003E0000 00000000:003E0000 Restored ! Remove battery and put back ! Time needed - 00:06:58 |
08-06-2011, 10:41 | #9238 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Software engine version: 1.0.0.5907 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620031533294 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 00EC:0106 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:18 |
08-06-2011, 11:36 | #9239 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: not available Age: 42
Member: 90366 Status: Offline Thanks Meter: 15 | vodafone ot-455 successfully unlock ok vodafone ot-455 successfully unlock ok Quote:
08-07-2011, 04:08 | #9240 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 297936 Status: Offline Thanks Meter: 201 | Huawei U5700 unlock done... Searching phone ... MODEL : M6275A-OEMSBL Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Imei : 35795501044331-9 Reading; SP saved to: SP_35795501044331_649_10.57.09_07.08.2011_HUAWEI.b in LOCKED_TO: MCC-MNC [0]: F2F-F2 Erasing; Writing; Unlocked ! Done ! Time needed - 00:00:40 |
