02-01-2012, 13:29 | #10351 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | zte s501 AZUR unlock 100% OK COMM OPENED 146 ! BAUD SET ! AUTH MADE ! SW VERSION: EF-CF-BINTEL-P118A12(S)V1.0.0B01 AUTH DONE; TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 864626000104510 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:28 |
02-01-2012, 15:37 | #10352 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | VDF 246 with easy pinout Software engine version: 1.0.0.6304 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A2V1.0.0B12 Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B12_15.37.16_01.02.2012_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:53 |
02-02-2012, 10:26 | #10353 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Online Age: 18
Member: 368697 Status: Offline Thanks Meter: 223 | Zte g s510 done comm opened 38 ! Baud set ! Auth made ! Sw version: E-zm-mtn-p118a10(s)v1.0.0b03 test mode status: Off sim status: Off imei: 355609045928552 sn: 0 auth done; config done; defeating protection; defeated; working; sim_lock removed ! Time needed - 00:00:28 |
02-02-2012, 16:40 | #10354 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | ZTE S510 unlocked with success Hi,All ZTE G S510 from Airtel Madagascar unlocked with Pack11 Code: COMM OPENED 6 ! BAUD SET ! AUTH MADE ! SW VERSION: EF-MG-BHARTI-P118A10(S)V1.0.0B03 AUTH DONE; TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 355609046437900 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:28 http://imageshack.us/photo/my-images/848/s510.jpg/ |
02-02-2012, 17:27 | #10355 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | Vodafone 255 unlock done Software engine version: 1.0.0.6364 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A16V1.0.0B08 Saved: ZTE_NONE_ED-DE-P118A16V1.0.0B08_19.20.16_01.02.2012_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:47 THANKS FURIUS TEAM |
02-03-2012, 01:54 | #10356 (permalink) |
Freak Poster Join Date: Sep 2006 Location: medellin colombia
Member: 350892 Status: Offline Thanks Meter: 40 | zte 990 unlock ok Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Aug 25 2011 19:52:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 35680004057079-1 BLUETOOTH ADDR : 50 33 DC B2 1A 68 TAG_ID:P736TB14G DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:45 ftm mode, keys power+volume down |
02-03-2012, 22:32 | #10357 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Unlock One Touch 585 Done : Product: OT-585 Provider ID: 585X-2[X=A,B,C,D]LPFR1 IMEI: 356888041479799 Start code calculate... NCK:3656662553 NSCK: SPCK: PCK: Code calculate finished successfully! |
02-04-2012, 02:42 | #10358 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | ZTE F951E unlock done.. Code: Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 21 2010 18:26:00 RELEASE DATE : Nov 18 2009 00:00:00 FIRMWARE INFO : ORG_ES_P608A1V1.0.0B21-S IMEI : 35871803055327-0 BLUETOOTH ADDR : 7C 21 E1 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 214 MNC: 3) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:12 |
02-04-2012, 02:44 | #10359 (permalink) |
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | Htc arte 100 Code: Starting cab upload; Preparing to install; Preparing to do application unlock; Application security unlock performed; Starting cab upload; Preparing to install; Checking installed file; Library and exe found; Reading data; DOC ID: 00000000C0060104340F12470C09062300 Doing sp area internally backup; Please wait; Simlock area read failed ! ERROR: kioctl(FLASH, init1) - La petición de la red no está permitida. error initializing flash Trying alternative scanning method; Scanning 0 Saved: C:\Program Files\FURIOUS-GOLD\PACK6\HTC_00000000C0060104340F12470C09062300_20.17.01_08.09.2011.bin IMEI: 35169501210585 NCK CODE: 45704501 Time needed - 00:00:53 |
02-04-2012, 07:58 | #10360 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | g 2157 unlock done Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334038714245 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334038714245_REL_P1.2PU04V01.04_11.54.35 _04.02.2012_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:39 |
02-04-2012, 09:38 | #10361 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | ufone g 2201 unlock done Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: 09.03.03:21.38.01:09.04.00:ULC2GPRS Imei: 359620033324676 Done; Press power on ! Starting communication ... Platform: E-Gold Voice3-64 [00 12] ... Preloader sent .... Loader sent .... Flash ID(0): 0001:0110 STARTING FLASH WRITE ... PERFORMING A FULL FLASH ... SENDING CFG... ERASING ... WRITING ... ERASING ... WRITING ... FINISHING ... Done ! Time needed - 00:04:01 |
02-04-2012, 12:44 | #10362 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | TDS-12 done Software engine version: 1.0.0.6331 Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 39 05 96 04 09 1E 0B Flash ID(0): 0001:22C4 PARTIAL: TDS12_X17EV1.0.0B15-EnRu RANGE(S): 00000000:001F0000 00000000:001F0000 Restored ! Remove battery and put back ! Time needed - 00:04:14 |
02-04-2012, 15:18 | #10363 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | ZTE f-102 successfully unlocked. Software engine version: 1.0.0.7687 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003220**** BLUETOOTH ADDR : AF CF E4 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:10 |
02-06-2012, 09:56 | #10364 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Huawei u2800 unlock done Searching phone ... Phone detected ... MODEL : Q62xx-OSBL- STARTING; OK; LOADING; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 35663104505251-3 READING; SP_SAVED_TO: SP_3566310xxxxxx1_E77_14.52.39_06.02.2012_HUAWEI.b in ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:01:44 |
02-06-2012, 14:31 | #10365 (permalink) |
No Life Poster Join Date: Feb 2009 Location: https://jabaunlock.com/
Member: 975275 Status: Offline Sonork: 100.1607001 Thanks Meter: 221 | Palm Pre Unlocked Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jun 11 2010 17:22:00 RELEASE DATE : Jun 11 2010 17:11:00 FIRMWARE INFO : XU1.6.12(3124) IMEI : 01216600113808-5 BLUETOOTH ADDR : 00 00 00 00 00 00 WORKING; UNLOCKED; POWER OFF PHONE TO COMPLETE UNLOCK AND AFTER DISABLE THE DIAG; Time needed - 00:00:02 |
