02-06-2012, 22:15 | #10367 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Kp106A UNLOCK DONE Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 007F:22F6 Bypassing security ... LOCK: ACTIVE IMEI: 01144********** UNLOCK CODE: 63568676 Saved: INFINEON_15.57.49_06.02.2012_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:18 |
02-07-2012, 00:18 | #10368 (permalink) |
Major Poster Join Date: Jul 2008
Member: 814444 Status: Offline Thanks Meter: 4 | Software engine version: 1.0.0.7709 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Mar 16 2011 21:10:00 RELEASE DATE : Jun 24 2010 21:00:00 FIRMWARE INFO : MVL_VE_P622F2V1.0.2B04-S IMEI : 8650080019******-4 BLUETOOTH ADDR : A4 59 AF C7 64 C8 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: 22A1C634B97F0FEDFD3CB949533C3CA2.bin ERASING; WRITING; READING; AFTER BACKUP: E918BFC93F6EDEEE6E45A0587521F8D6.bin UNLOCKED; RESET ! Time needed - 00:00:11 el telefono quedo 100% |
02-07-2012, 05:35 | #10369 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Huawei u1251 unlock done Searching phone ... Phone detected ... MODEL : Q62xx-FSBL STARTING; OK; LOADING; OK; DONE; STARTING AUTHORISATION; AUTHORISATION PASSED; INIT NAND ROUTINES; NAND INIT MADE; LOOKING SENSITIVE DATA; OK; DONE; IMEI : 3558510xxxxxxxx-1 READING; SP_SAVED_TO: SP_35585103028730_EA1_10.34.22_07.02.2012_HUAWEI.b in CHECKING; LOCKED_TO: MCC-MNC [0]: 505-02 MATCHED; ERASING; WRITING; SIM_LOCK REMOVED ! RESET ! DONE ! Time needed - 00:02:01 |
02-07-2012, 09:59 | #10370 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Ufone G 1000 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820041162414 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! |
02-07-2012, 10:00 | #10371 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | G 1000 unlock done COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820041162414 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! |
02-07-2012, 10:00 | #10372 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | vodafone 248 unlock done TIME NEEDED - 00:00:19 COMM OPENED 3 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820040585490 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:19 |
02-07-2012, 10:02 | #10373 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Zte A 316 unlock done Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 Imei: 354354030924495 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0106 Reading ... Saved: ZTE_354354030924495_EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10_13.15.53_07.02.2012_PARTIA L.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:09 |
02-07-2012, 10:02 | #10374 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Ufone G 1157 unlock done Software engine version: 1.0.0.6364 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 356334038759398 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_356334038759398_REL_P1.2PU04V01.04_13.19.48 _07.02.2012_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:36 |
02-07-2012, 13:00 | #10375 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Software engine version: 1.0.0.6331 Connect phone powered on ! Start auth ! SW Ver: EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08 Imei: 353894032073438 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00EC:0103 Reading ... Saved: ZTE_353894032073438_EFSPI-FR-SFR-P108E10FM(S)V1.0.0B08_16.45.00_07.02.2012_PARTIAL. bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:41 |
02-07-2012, 13:48 | #10376 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | tmn a7unlock 100% 100% tested and working Software engine version: 1.0.0.7704 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Nov 25 2011 02:01:00 RELEASE DATE : Oct 26 2010 14:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-6050 IMEI : 86079001xxxxxxxx-8 BLUETOOTH ADDR : 8C E5 CC B2 1A 68 TAG_ID:727TMN02Q DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:52 |
02-07-2012, 15:48 | #10377 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | blackberry 7290 unlock done BBPIN: 2055D876 Detected: RIM 7200 Series Colour GPRS Handheld Platform version: 1.8.0.147 NET Unlock Code (254) : 21330264 (Active) Operator: 3027200 Time needed - 00:00:02 |
02-07-2012, 16:20 | #10378 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Motorola wx 180 unlock done Make your handset power off, plug in the UART cable! Product: MotorolaWX180 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 358330033509786 Security file: C:\Program Files\FuriouS-Gold\Alcatel\Security\BackupSecurityFile\M180X-2AVRGB1 Read security information successfully! Start code calculate... Product: MotorolaWX180 IMEI: 358330033509786 Security file: C:\Program Files\FuriouS-Gold\Alcatel\Security\BackupSecurityFile\M180X-2AVRGB1 NCK:0132757211 NSCK: SPCK:1518772342 PCK: Code calculate finished successfully! |
02-08-2012, 09:11 | #10379 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 258525 Status: Offline Thanks Meter: 44 | zte z990 unlocked successfully Software engine version: 1.0.0.7687 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Aug 25 2011 19:52:00 RELEASE DATE : May 11 2011 02:00:00 FIRMWARE INFO : M76XX-TSNCJOLYM-60503001 IMEI : 3568000xxxxxxx-4 BLUETOOTH ADDR : 4B 73 DC 50 4B 34 TAG_ID:P736TB14G DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; CONTINUE DIRECT UNLOCKING; SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:35 |
02-08-2012, 15:03 | #10380 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | acer s-100 successfully unlocked. Software engine version: 1.0.0.7687 Searching phone ... MODEL : QCOM SERIES 16 COMPILED DATE : Oct 6 2010 16:43:00 RELEASE DATE : Mar 29 2010 13:00:00 FIRMWARE INFO : 8650B-SDCAOLYM-4075 IMEI : 35350803043**** BLUETOOTH ADDR : 00 16 D4 51 75 43 LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 97602013 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. RESET ! Time needed - 00:00:50 |
