Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 07-28-2008, 20:39   #1 (permalink)
rotelcam's Avatar
Member: 698210
Sonork: 100.1578921
Thanks Meter: 3,591
Arrow Nspro Axalato Card Not Found..help
When launch software, displays this mesage,
help please....
Old 07-28-2008, 20:53   #2 (permalink)
Member: 392373
Sonork: 100.1575353
Thanks Meter: 75
NsPro Axalto card not found (error 0x01) = Smartcard is not detected by windows.
Solutions:
1.Check if smartcard drivers are correctly installed. A new version of smartcard drivers can be found HERE
2.Check if the card is correctly connected into the card reader inside the box.
NsPro Axalto card not found (error 0x02) = corrupted card
NsPro Axalto card not found (error 0x03) = corrupted card
Solution:
Can be repaired by using this software
NsPro Axalto card not found (error 0x04) = damaged card
Solution:
Send the card back to reseller or distribuitor www.unlockcellular.com for replacement
Old 07-28-2008, 20:54   #3 (permalink)
UnlockCellular's Avatar
Member: 75209
Thanks Meter: 165
or dont push the card to deep inside the smartcard slot
or make sure you install schlumberger driver correctly
Old 07-28-2008, 21:08   #4 (permalink)
Member: 592460
Thanks Meter: 110
or just push the card in a little. unplug and plug in again. then start soft again *sometimes 2/3 times...always works on mine
Old 07-29-2008, 14:44   #5 (permalink)
rotelcam's Avatar
Member: 698210
Sonork: 100.1578921
Thanks Meter: 3,591
Thumbs up correct axalato card not found.
Solutions:
Solution:
Solution:
Thanks alot to all who gave assistance. but this should be taking care of by all members in futuer.
KIDS SHOULD NEVER BE LEFT TO ACCESS THE LAB.
the card was removed and inserted the oposite way by my boy.
after several tries from ur assistance then i though and look well and realised the card was oppositly inserted.
Thanks to all who gave assistance.
The Following User Says Thank You to rotelcam For This Useful Post:
Nspro Axalto card not found (error 0x01) ! evaireland NSPRO 11 07-05-2013 12:41
“NsPro Axalto card Not found (error 0X01)! ranjit2003 NSPRO 14 06-24-2013 20:02
nsPro Axalto card not found (error 0x01|) sunrise gsm NSPRO 2 11-03-2011 22:27
NsPro Axalto card not found!! nandger NSPRO 4 03-18-2009 06:11
NsPro Axalto card not found (error 0x01)! johnmene NSPRO 1 06-01-2008 20:57
Page generated in 0.26480 seconds with 9 queries
