09-11-2012, 19:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: United Kingdom
Member: 1638915 Status: Offline Thanks Meter: 432 | Successfuly Repair Imei SIII I9300 Successfuly Repair Imei SIII I9300 |
The Following 4 Users Say Thank You to bux_harun For This Useful Post: |
09-11-2012, 22:25 | #3 (permalink) |
Member: 1638915 Status: Offline Thanks Meter: 432 | Repair Imei SIII I9300 2nd phone With Prof Hay I M Repair 2nd Phone With Prof Nice work NS Pro Preparing Phone... Resetting IMEI... Connecting to phone UART... Reading MSL... Using Advanced MSL... Bypasing Security... Writing IMEI... Resetting Phone... Operation successfully completed |
09-12-2012, 16:28 | #4 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Hi, I got same work to do tomorrow, if activation of box is done, so I have few questions if you don't mind : what cable did you use ? how did you flash patch file ? is there specific step I should know to not waste most time ? Thank you, BR |
09-16-2012, 18:36 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | if u change imei and after that update firmware and dont loose network.then nespro first in the world. there is no box sport not loose network after update firmware. |
09-28-2012, 14:17 | #14 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Preparing Phone... Resetting IMEI... Connecting to phone UART... Using Advanced MSL... Bypasing Security... Setting Serial Number... Writing IMEI... Resetting Phone... Operacao com sucesso concluida |
09-28-2012, 18:24 | #15 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Better use I9300 Root file from NsPro support area to root the phone Then select "I9300 Rooted" on Nspro to perform IMEI Write operation. . Last edited by Elco; 10-04-2012 at 18:13. |
The Following 6 Users Say Thank You to Elco For This Useful Post: |
